Dell 1703fps backlight problem
  • mu2
    • Oct 2009
    • 217
    I have a Dell 1703 fps where the backlight turns on for about a second. Turning the monitor off and on again causes the light to repeat the cycle.
    The monitor has a Lien Chang inverter board (LI-2070) and the power board is numbered BN41-00296B. I've replace 3 1000 mf 25v Capxon and 3 1000 mf 16v Capxon electrolytics on the power board. The caps showed no signs of bulging and also tested good with an esr meter. There are two other caps on the power board and one on the inverter board that check good (with esr meter) that I have not replaced.
    If I monitor pins 1 and 12 on the connector going to the inverter board (I'm pretty sure this is supposed to be the 12 volt line) I get 17.70 volts when plugged in but not turned on - after turning on and the backlight comes up the voltage is 15.26. The backlight goes off and the voltage increases to 19.47 volts.
    Seems like this backlight issue is common for this monitor - anyone have a fix for it?
    Mike
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dell 1703fps backlight problem
    Mike
    Post good quality pictures of the boards. I'm not familiar with that monitor. The symptom you describe (often refered to as the 'two seconds to black' problem) has several causes. It can be a problem with either the inverter or the backlights (CCFLs).
    PlainBill
    • mu2
      • Oct 2009
      • 217
      I'll work on getting some photos over the weekend, if my digital camera is still working.
      Does the fact that the 12 volt input is high have any significance? Could the inverter be shutting down due to a too high voltage condition?
      Mike
      • PlainBill
        • Feb 2009
        • 7034
        Mike
        It could be. Most inverter controllers monitor the output voltage and current and shut down if either go out of limits. But that raises other questions - what is the voltage supposed to be? (Not all inverters use a 12V supply). What is the voltage going to the logic board? Is it correct?
        PlainBill
        • mu2
          • Oct 2009
          • 217
          My information on the 12 volt input came from this link.
          http://www.lcdparts.net/InverterDeta...ProductID=2233
          My inverter board (the Lien Chang LI-2070) doesn't look like this one although the CCFL connectors, inverter transformers and input connector are the same.
          Since this is supposed to be a sub and 12 volts is mentioned as the input voltage, I figured my supply voltage was high. There is a KA431LZ which is supposed to be a programmable shunt regulator on the power board, but I haven't looked at the voltages in that area. Not sure if the 12 volts comes from there.
          Mike
          • mu2
            • Oct 2009
            • 217
            Here is a photo of the power and inverter boards. I found that a connector on the power card is marked "14v" and "5v". My 5 volt supply is pretty close (5.1) but the 14 volt supply is high.
            Mike
            • Dgtech
              E. Technician
              • Apr 2009
              • 1462
              • Steeler
              I just bought this same exact monitor and it has the same exact problem. The power board is the same as above. It had 3 X 1000uF 25V and 3 X1000uF 16V. Recapped to all six new 1000uF 25V caps. Same problem exists still. I have yet to go through the checklist of "2 seconds to black" procedure. Has anyone ever found a solution to this problem with this monitor?
              • retiredcaps
                • Apr 2010
                • 9271
                One case was traced to bad a CCFL post #16.
                https://www.badcaps.net/forum/showth...t=Dell+1703fps
                --- begin sig file ---
                --- end sig file ---
                • hoadle
                  • Jul 2010
                  • 174
                  I work on Dell 1703 fps the problem you had is Lien Chang inverter board (LI-2070), take close look on bottom hight volt transformer on both side on hight volt transformer is burn up need replace (one side had 6 legs & another had 2 legs got to backlight)
                  check is out website last time I paid $39.95 + shipping or send you inveter they can repair
                  http://www.lcdpart.com/Products/li2070.html
                  • hoadle
                    • Jul 2010
                    • 174
                    Here another website & cheap too
                    http://www.lcdrepair.us/1703fps-inverter.html
                    • Dgtech
                      E. Technician
                      • Apr 2009
                      • 1462
                      • Steeler
                      Wow, only $30? lol Just kidding. Thats way too much for a board that will repair a monitor that I bought for $20. I just went ahead and scrapped that monitor for a good pair of test CCFL's. Oh and other parts too.
                      • hoadle
                        • Jul 2010
                        • 174
                        I sorry to hear that, last time I had to buy ist & only one website sale cheap. You can save the Lien Chang inverter board (LI-2070) for future use, because only one hightvolt transformer go bad (they had 2 hightvolt transformer) you can use good hightvolt transformer to replace another board on Dell 1703fps.
                        • hoadle
                          • Jul 2010
                          • 174
                          Or you can find inverter transformer on ebay, to replace bad one
                          • Rtech
                            • Jul 2010
                            • 1095
                            I understand the same Inverter is also used in the following units,so perhaps some of them may yield you a spare transaformrt,if you can find a 'scrapper' monitor.
                            Compaq
                            TFT1701
                            17" TFT Panel
                            Dell
                            1703FPS
                            17" LCD Monitor
                            Dell
                            1703FP
                            17" LCD Monitor
                            Dell
                            1702FP
                            17" LCD Monitor
                            Dell
                            1701FP
                            17" LCD Monitor
                            Dell
                            1900FP
                            19" LCD Monitor
                            Dell
                            E171FP
                            17" LCD Monitor
                            IBM
                            6657-HG2
                            17" LCD Monitor
                            Samsung
                            SyncMaster 171P
                            17" LCD Monitor
                            Samsung
                            SyncMaster 171B
                            17" LCD Monitor
                            Samsung
                            SyncMaster 181T
                            18.1" LCD Monitor
                            Samsung
                            LTM170E04-L01
                            17" TFT Panel
                            Samsung
                            SyncMaster 192MP
                            19" LCD Monitor
                            • bullwinkle
                              • May 2009
                              • 107
                              have a same dell model and same problem.
                              • sabre504
                                • May 2010
                                • 449
                                • United Kingdom
                                Had this problem to but took an inverter transformer off a dell 172
                                difference being that these are thro hole and the 1703 uses surface mount
                                but trimmed right they do fit but a deft bit of soldering required unless you are lucky enough to have a hot air station
                                not the prettiest of jobs but works the only real greif is removing the black glue from the transformer (hard as concrete)
                                • uligli
                                  • Aug 2006
                                  • 139
                                  I have two 1703FPs, 2 secs to black symptom, both of them have Li-2070, with a burned transformer on each, took out a SIC1803 inverter from a 1702FP, and did fix the problem.
                                  Those transformers have some tough plastic glue really difficult to disolder.
                                  • Dgtech
                                    E. Technician
                                    • Apr 2009
                                    • 1462
                                    • Steeler
                                    Dude, very nice pics. Great job. That will indeed help people. As for myself, I now hate Dell monitors more than Samsung.
                                    • sabre504
                                      • May 2010
                                      • 449
                                      • United Kingdom
                                      Strange that the transformer that has burnt out on the firt pic is the exact same one that i had to change be interesting to hear from others if the transformer is the one that has gone on theirs not that it probably makes a lot of difference but its the one closest to the psu board
                                      • truckerron
                                        i have the same monitor and same problem but don't know nothing about fixing eletronics where could i take it or send to get fixed thanks ron
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Borse2008
                                          Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                          by Borse2008
                                          Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                          I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display β€” it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                          • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                          • There’s
                                          07-15-2025, 04:55 AM
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • Zilicon
                                          NEWSYNC B27F165 MONITOR HAS NO BACKLIGHT. board no: JY85QS_UPH_LS_R10.3
                                          by Zilicon
                                          Greetings everyone.
                                          Please I need help with the above monitor.
                                          Below is the summary of what happened and what I have done:
                                          The monitor started by turning off 2 seconds after it was turned on. It displayed with a backlight when it turned on. However, the standby light remains on after it is turned off on its own, I have to press the power button again to turn it on, but it will go back to standby after 2 seconds.
                                          The backlight driver IC is 0b3350cp.
                                          I applied a 370k SMD resistor on the CMP pin which is pin 6, while the other...
                                          11-07-2023, 09:12 AM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
