KDS K-92BW Turns off
  • retiredcaps
    • Apr 2010
    • 9271
    Re: KDS K-92BW Turns off
    It is time for a clear focused picture using manage attachments function. Please do not post pictures inline as they slow down the loading of pages.
    For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
    Here is an example of the pictures we want.
    https://www.badcaps.net/forum/showpo...94&postcount=1
    --- begin sig file ---
    --- end sig file ---
    • slcomputer
      • 18
      • new zealand
      hi I have a problem with my lcd monitor when i turn it on it goes white for a few seconds and then goes black.
      I have a 200-000-1700tlbmh board the caps look fine.
      any help would be appreciated
      • selldoor
        Slow Learner
        • 7870
        Read the post above yours and do as it says.
        • slcomputer
          • 18
          • new zealand
          [QUOTE=slcomputer;300073]hi I have a problem with my lcd monitor when i turn it on it goes white for a few seconds and then goes black.
          • EGuevarae
            • Nov 2008
            • 1336
            [QUOTE=slcomputer;300133]
            Green caps, third picture. Those need to be changed.
            • ASUS ROG Maximus IX Code
            • Intel Core i5-7600K 3.8GHz
            • Windows 10 Pro x64
            • GeForce GT1050
            • slcomputer
              • 18
              • new zealand
              #26
              do you mean the the caps on the powerboard?
                You may have more than one problem, one is that your power supply has bad caps, another one is that your LCD panel T-CON may not be getting the voltage feeding from the main board or the T-CON itself may have problem. You need to at least replace the bad caps first, bad cap can look normal without having domed top.
                • EGuevarae
                  • Nov 2008
                  • 1336
                  Yes. For a start. You can't really diagnose accurately with those caps in there.
                  • GeForce GT1050
                  • slcomputer
                    • 18
                    • new zealand
                    #29
                    where do i but the caps do you know?
                    how do i check the fuses? do i use my multimeter?
                    • slcomputer
                      • 18
                      • new zealand
                      #30
                      sorry I meant where do I buy the caps?
                      • slcomputer
                        • 18
                        • new zealand
                        #31
                        I have check the fuses with dmm and they both read 000 so im guessing they aren't blown. Is this correct?
                        • slcomputer
                          • 18
                          • new zealand
                          #32
                          can I check tha capacitors with a multi meter?
                          • selldoor
                            Slow Learner
                            • 7870
                            #33
                            Hi
                            1where do i but the caps do you know?
                            http://www.activecomponents.com/Page-Contact-Us_3.aspx
                            appear to sell good make caps
                            A lot of NZ members mention Jaycar?
                            Digikey
                            Mouser
                            RS direct.
                            2how do i check the fuses? do i use my multimeter?
                            Yes - as you have done - but was not required as it would not work as much as it does if the fuses were bad.
                            3 can I check the capacitors with a multi meter?
                            No, unless your meter has a capacittance test on it -
                            even then its not a good test.
                            I think you will need to change all the caps except the large one
                            BUT before you buy caps I want you to test the secondary resistance on the inverter transformers as the board looks
                            a bit browned I will post where you have to test soon.
                            • selldoor
                              Slow Learner
                              • 7870
                              #34
                              Right Power off meter on ohms 2000 measure S1 >S2 and S3 >S4
                              and post the results.
                              I have also marked in yellow two components Q5 Q6 What is the part Number on them and is the bottom one in your picture burnt or is it just the picture.
                              If you take more try not to use flash and more natural light.
                              • slcomputer
                                • 18
                                • new zealand
                                #35
                                which components are marked yellow please
                                how do i test s1>s2 and s3 >s4 are they on the board if so where?
                                The two rectangle like parts on the board say they are T1 at top and t2 at bottom does that help?
                                • slcomputer
                                  • 18
                                  • new zealand
                                  #36
                                  730-703-1900tlm-lh eel19-a01700 hl 7118 is written on the rectangle square components does that help Im not sure are these the transformers how where do i test these do I use a multimeter?
                                  • slcomputer
                                    • 18
                                    • new zealand
                                    #37
                                    how do I test the secondary resistance on the inverter transformers
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      #38
                                      Sorry - forgot to attach the picture
                                      • slcomputer
                                        • 18
                                        • new zealand
                                        #39
                                        when I test s1 s2 s3 s4 they all come up with 000 the part number on the resistors in yellow is k3615
                                        • slcomputer
                                          • 18
                                          • new zealand
                                          #40
                                          there seems to be some black by the T1 but I was told that is just because these get quite hot so its normal is that right?
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • Rick_1234
                                            LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                            by Rick_1234
                                            Good evening, gentlemen.
                                            I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                            To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                            https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                            Things I tried
                                            - Bought a new AC adapter thinking that was the problem but the problem...
                                            06-22-2024, 04:44 PM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • penangit
                                            Hp v193 monitor power supply board
                                            by penangit
                                            Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
                                            I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
                                            I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
                                            Steps taken so far:
                                            Checked all...
                                            02-21-2023, 04:00 AM
