KDS K-92BW Turns off
  • slcomputer
    • 18
    • new zealand
    #41
    Re: KDS K-92BW Turns off
    when I test the s1 s2 s3 s4 do I put the positive on s1 and negative on s2 and same with the s3 s4 for testing or how do I do this?
    • slcomputer
      • 18
      • new zealand
      #42
      when I put the positive on s1 and negative on s2 I get 763 when i put the positive on s3 and negative on s4 i get 763 is this ok?
      • slcomputer
        • 18
        • new zealand
        #43
        should i replace the caps in the badcaps pdf picture
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          #44
          Ok Inverter Transformers are good.
          Components inside the yellow boxes in my pic are Mosfets
          I attach the datasheet.
          Attached to retiredcaps post is a guide on 2 seconds to black - in there it tells you how to test Mosfets You do not need the board powered to that.
          It also mentions testing ccfl bulbs -do you have anything you can plug the lamps into to test them?
          The board does go black sometimes - it does get hot but it may be from the K3615s that was why I was asking if the lower one looked burnt.
          You can replace the caps - I was only getting you to test
          other components first to save money as for a 19 in screen it is relatively expensive to replace the inverter transformers or the bulbs
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • Rick_1234
            by Rick_1234
            Good evening, gentlemen.
            Things I tried
            06-22-2024, 04:44 PM
          • penangit
            Hp v193 monitor power supply board
            by penangit
            Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
            I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
            I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
            Steps taken so far:
            Checked all...
            02-21-2023, 04:00 AM
            by momaka
            03-15-2023, 10:17 PM
