KDS K-92BW Turns off
  • chrimeg
    • Jun 2009
    • 7
    Hello Everyone,
    I've done a few LCD repairs in the past usually the normal capacitor repair and few times I've had to diagnose shorts in diodes etc.
    Anyhow, this time I have an 19" LCD that turns on for two/three secondsand the screen lights perfectly then turns off and the LED stays solid meaning the monitor is still detecting a signal. Turning the monitor of and on again provides the same result. Comes on for 2/3 secs then off.
    I've removed the board and all the caps look good (blue HEC 105 degree's). All the solder joints etc also look good.
    The board states Proview Electronics 200-000-1700TLBM-BH Version: B
    PI-1900TLB REV: A Date: 03, 12, 2007
    Any ideas on whats causing this? How would I test the backlights? I read somewhere that some units turn off the monitor when a backlight fails to prevent damage. If it is a bad backlight why would the screen look fine when first turned on. Wouldn't it just be dark from the get go.
    Also, I have another 19" LCD screen here that I know the back lights are good in. However, it is a different model. Can I connect it to the KDS power board with just the 4 power connectors or will I also have to connect it to the ribbion cable for testing.
    Thx for all the help.
  • chrimeg
    • Jun 2009
    • 7
    Re: KDS K-92BW Turns off
    Just noticed the board is actually 200-000-171DTLBMH or ETL-XPC-204. A search on the net turned up a few pics but no schematics.
    • Toasty
      • Jul 2007
      • 4171
      It's most likely the backlight inverter detecting either a tube failure/excess current draw on the inverter.
      There are MANY posts/threads on here regarding these types of failures. You could have anything from bad caps on the inverter board to failing output transformers. I would check the tubes and caps first as outlined in the other threads.
      As the tubes heat up and draw more current this may be why it comes on briefly and then shuts down.
      Shining a flashlight on the screen, can you still see the picture? If yes, then you're dealing with the backlight problem. If no, you may have a failure earlier on in the circuit.
      Once you open it up, post some pics of the inverter board.
      Toast
      veritas odium parit
      • chrimeg
        • Jun 2009
        • 7
        Well I tried the flashlight thing but could not see an image. However I don't think the flashlight was bright enough as it was LED.
        Anyhow I disconnected the screen from the ribbion cable and left only the HV connections. Powered on the screen and got a white background light for a few seconds and it went dark again.
        I then took another 19" screen I had laying around out of another brand, connected it to the HV only and get the white background lights only this time is remains on.
        I assume it must be a failing CCFL as the second screens lights remain on. Just no picture obviously becuase I cannot connect it to the LCD electronics.
        What next. How to I determine when backlight to purchase. Is there a number or anything on them once removed from the unit?
        • PlainBill
          • Feb 2009
          • 7034
          When you disassemble the panel (carefully!!!) and gain access to the CCFLs measure their diameter and length. Then match that.
          PlainBill
          • EGuevarae
            • Nov 2008
            • 1336
            Absolutely.
            There are 10 kind of people in this world: those that understand binary, and those who don't.
            • ASUS ROG Maximus IX Code
            • Intel Core i5-7600K 3.8GHz
            • 16gb GSKILL TridentZ RGB DDR4-3200
            • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
            • Windows 10 Pro x64
            • GeForce GT1050
              2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
            • chrimeg
              • Jun 2009
              • 7
              I got the backlights out...four of them.
              They seem to be 16 inches long and really thin. Not sure how I'm going to measure the diameter.
              Anyhow, while shopping online for a match I notice alot of places need the voltage and running amps etc. How do you know these things? Will this make a difference?
              • chrimeg
                • Jun 2009
                • 7
                Well got a better measurement this morning.
                16.6 inches (419mm) by about 2mm diameter.
                Again not sure of what the voltages are such as startup and running peak, current, amps, watts. How do I find these out.
                Also where is the best place to buy these lamps. Should I replace all 4 as 3 of them look dark in the corners.
                • EGuevarae
                  • Nov 2008
                  • 1336
                  For amp/voltage, sometimes it is written on the PSU/inv board. Black/dark ends are kind of normal. If you want to replace them all, go ahead, but I doubt all are failing (it could happen).
                  • GeForce GT1050
                  • PlainBill
                    • Feb 2009
                    • 7034
                    I believe voltage is a function of the length while current is a function of diameter.
                    PlainBill
                    • agrawalr
                      • Aug 2010
                      • 5
                      Hey, I'm a first time poster!
                      I have the same problem. My monitor turns off after a few seconds. However, the color is also a bit weird upon startup and takes a while to "warm up" to its normal color. Is the color a function of a capacitor, or could that also be a function of the ccfl?
                      Thanks!
                      • smason
                        • 1652
                        Thanks!
                        Is it reddish/pinkish? If so, that's a classic sign of impending lamp failure.
                        • agrawalr
                          • Aug 2010
                          • 5
                          Yeah, it is a bit reddish pinkish.
                          Do you guys have any recommendations of where to purchase these lamps from?
                          Thanks again!
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            http://ccflwarehouse.com/
                            http://www.ccfldirect.com/
                            --- begin sig file ---
                            --- end sig file ---
                            • agrawalr
                              • Aug 2010
                              • 5
                              perfect! thanks for the prompt replies!
                              • EGuevarae
                                • Nov 2008
                                • 1336
                                Dead lamps.
                                • GeForce GT1050
                                • agrawalr
                                  • Aug 2010
                                  • 5
                                  So, I got the lamps and installed them. The lights come on and everything looks great for 2 - 3 seconds (no more reddish hue), but the lamps still turn off after. Could it be some kind of capacitor issue? Again, thanks for the help!
                                  • EGuevarae
                                    • Nov 2008
                                    • 1336
                                    • GeForce GT1050
                                    • agrawalr
                                      • Aug 2010
                                      • 5
                                      any ideas which capacitor I should be looking for?
                                      • EGuevarae
                                        • Nov 2008
                                        • 1336
                                        Post a list of all the caps on your board and replacements would be suggested accordingly
                                        • GeForce GT1050
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • Rick_1234
                                          by Rick_1234
                                          Good evening, gentlemen.
                                          Things I tried
                                          06-22-2024, 04:44 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • penangit
                                          Hp v193 monitor power supply board
                                          by penangit
                                          Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
                                          I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
                                          I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
                                          Steps taken so far:
                                          Checked all...
                                          02-21-2023, 04:00 AM
