Dell E178FPb - white screen
  • cjmclellen
    Banned
    • Oct 2008
    • 8
    Re: Dell E178FPb - white screen
    not even fit for the vip room.POOF!
    • cjmclellen
      Banned
      • Oct 2008
      • 8
      much nonsense snipped...
      • EGuevarae
        • Nov 2008
        • 1336
        Originally posted by cjmclellen
        Oh damn it! I posted to the wrong forum.
        He he.
        Just kidding guys.
        Try operating your panel under water,
        it will remedy the intermittent issues you are having.
        Not funny and out of place.
        You should try to breathe underwater, I guess it will solve the dumb posts you do ...
        There are 10 kind of people in this world: those that understand binary, and those who don't.
        • ASUS ROG Maximus IX Code
        • Intel Core i5-7600K 3.8GHz
        • 16gb GSKILL TridentZ RGB DDR4-3200
        • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
        • Windows 10 Pro x64
        • GeForce GT1050
          2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
        • cjmclellen
          Banned
          • Oct 2008
          • 8
          byebye troll
          • EGuevarae
            • Nov 2008
            • 1336
            ...... embarrassing MYSELF .....
            Congratulations. You made it!
            ...Forgive me, I forgot about the possibility of you not using your own picture...
            I apologize for not using my own picture. I guess your avatar is your real picture. At least it is brainless, so it might be related in some way .....
            ...maybe that's the main character in your favorite video game....
            In fact it is. I apologize for thinking you are a complete idi... never mind, I guess you just got lucky on that one.
            Except I'll get in my car and drive to your house and beat the living shit out of you if you talk to me like that again.
            In your dreams.
            Please post something either useful or at least funny. No, I'm sorry. You should not post at all. We all get along pretty well here.
            • GeForce GT1050
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              #26
              problem fixed.
              now back to the o.p's issue.
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16956
                Wow, what got up his ass!
                In the 7 years this forum has operated, that was the first non-spammer troll we've had to ban! Bring a tear to the eye!
                Resume fellas, sorry for the interruption!
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • Scenic
                  o.O
                  • Sep 2007
                  • 2642
                  Capxon GL is replace on sight (like fuhjyyu), white display problem and it being intermittent sounds like a flex cable issue or the Genesis controller not getting it's voltage (defective regulator on the controller board? usually one 3.3V and another one with 2.5V or 1.8V))
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Originally posted by kc8adu
                    problem fixed.
                    That may not be so easy to resolve. By the symptoms, it's a bad solder joint. Given the extreme small size of the components, the lack of schematics, and even pin-outs of some of the ICs, this is NOT easy. And an honest question is "How much time and effort should be spent on a 17" monitor?" Unfortunately, my frugal upbringing won't allow me to discard it!!!
                    PlainBill
                    • PlainBill
                      • Feb 2009
                      • 7034
                      No, if I haven't made it clear, let me correct that. The panel circuit board contains a set of power supplies which generate the voltages needed by the LCD panel. That supply is dead. At one point yesterday it WAS working and the test points showed voltages ranging from approximately + 25 volts to - 10 volts (using an oscilloscope). Before I could grab a DMM, the power supplies had failed again.
                      And before someone else says 'Fuse!' let me repeat - there is 5 volts present on the panel card at all times.
                      PlainBill
                      • EGuevarae
                        • Nov 2008
                        • 1336
                        PlainBill
                        I have seen that before and yesterday I revisited my notes. I have three Hanns-G panels with that symptoms/problems. One, sadly, got broken while I was extracting the lamps to fix a Samsung (how, I don't know. I promise I was as careful as always...). The other two ad their lamps removed too, but I did not discard them. Someone here suggested that one of the DC-DC converters on the board in the panel itself was failing, but due to the fact that I have no electronics background, and I don't have (contrary to Bill, and others around here) a scope, I just left them stored.
                        • GeForce GT1050
                        • PlainBill
                          • Feb 2009
                          • 7034
                          I've seen pictures of other panel cards that had a single IC to generate the voltages. This one appears to use multiple ICs. I've been able to read the part numbers of a few of them. One does not appear to have a datasheet available. I was unable to match the part number of the other; probably a reading error on my part.
                          PlainBill
                          • alexanderjohn
                            • Dec 2007
                            #33
                            PlainBill,
                            Any progress on this? I have an E178fpb and the boards don't match the physical description of yours. or the pictures. I can't tell anything that's wrong with the boards.
                            • PlainBill
                              • Feb 2009
                              • 7034
                              Originally posted by alexanderjohn
                              PlainBill,
                              It's a slow process. I HAVE found a lighted magnifier so reading part numbers on ICs is now possible. Unfortunately, the numbers I come up with don't generate hits with Google. The input to the inductor is a steady 5V DC,obviously it should be switched on and off. The next step is to try to trace it back to the driver.
                              I had considered the 'poke and prod' approach on the assumption it was a bad solder joint. However, that seems dubious when it would involve shorting IC pins together....
                              PlainBill
                              • PlainBill
                                • Feb 2009
                                • 7034
                                Good news / bad news on this monitor. My wife teaches computer skills in a Middle School. One of the modules is base on the Lego Mindstorm robotics system. The NXT controllers are unreliable, the problem is often poor solder joints on the display assembly. Currently I have half a dozen of them in a box waiting for repair. Sadly, my venerable Ungar 27 watt soldering iron just isn't up to the task - the tip is too big. So yesterday I went down to Frys and picked up a Weller SP12. That worked much better, and I was able to cope with SMD devices.
                                Next, I pulled this monitor off the shelf and began touching up the components in the power supply area of the tcon. I hit paydirt when several resistors moved when I touched one end with the soldering iron (obviously the other end was not soldered). The display panel now works perfectly.
                                Unfortunately, I have misplaced the screws that hold everything together.
                                PlainBill
                                • ComputerGeek
                                  • Oct 2011
                                  • 262
                                  LOL Congrats, I Like it when you find the problem!
                                  Do you think the solder joint cracked from heat?
                                  BTW, I wish I could get a hold of some of those NXT controllers!
                                  • sand3881
                                    • Mar 2013
                                    • India
                                    #37
                                    I have one Dell E178FPc. When I power one the Monitor it shows the Full Screen Test pattern like images. It doesn't get affected with or without VGA cable connectivity
                                    • Amraks
                                      • Nov 2011
                                      • 725
                                      Plainbill I had a heap of smd transistors on a kenwood head unit for the car do this, it took out the lcd display.
                                      obviously sometimes the conditions in the room these are manufactured changes.
                                      cause I have this other head unit the same and it never done.
                                      • PantherDave
                                        by PantherDave
                                        Hi all!
                                        05-29-2024, 02:01 PM
                                      • domu
                                        Viewsonic VS16217 strange problem - white flickering screen on power up
                                        by domu
                                        As per subject, on power up display shows no image, but white
                                        flickering screen. Strangely, it only happen after power was lost
                                        when it was on. After power returns - white screen only, but if
                                        disconnect power for 12-24 hrs, and connect then again monitor
                                        works normally.
                                        Any clues how to go about it would be greatly appreciated.
                                        07-18-2023, 04:57 AM
                                      • noipi
                                        DELL INSIPRON 14 No power blinking orange/white
                                        by noipi
                                        i have DELL INSIPRON 14 5410 2-IN-1 blinking orange and white when charger connected, i tried to find Boardview or schematics but cannot find. i opened the unit and the motherboard model number is 203071-1 Watchmen that i found written on motherboard. Where should i start because when i press power on, nothing happens. but i checked the main power rails voltages are enabled and the charging for battery LDO is 3.3 volts.
                                        05-06-2025, 08:08 PM
                                      • cekcons
                                        Dell G15 5510 Power on no screen. No cpu heat.
                                        by cekcons
                                        Motherboard number gdl55 la-k661p
                                        I don't see any short on cpu power mosfets. If i inject 1v to cpu side draws 0.5 A.
                                        When i plug the charger it starts atuomaticly and only gpu and hm heats up. (nothing too hot.)
                                        Anything i am missing ?
                                        12-14-2024, 02:56 AM
                                      • tmcw
                                        Dell P2217 - White screen
                                        by tmcw
                                        I picked one of these monitors out of the trash at work, it looked a bit dusty, but newish, and the screen wasn't gouged or cracked as far as I could tell, always a good start.
                                        Brought it inside and found that the screen was pure white when switched on. Pressing buttons seemed to make the brightness a little dimmer (menu screen popping up?) and pressing other buttons made the backlight go off for a second or two, and then come back on again (input switching?).
                                        I did a quick google on the model, but no threads or pages with any issues for this model coming up. It's a relatively...
                                        01-05-2022, 09:38 AM
