c5707 or 2sc5707 replacements found
  • dmbj
    • May 2009
    • 23
    I just found this place earlier today and have been reading all morning. first off thanks for all the help so far. anyway while working on some hp 1740 monitors i have found that the c5707's on benq inverter boards (in this case 48.L1G02.A01) often fail. While looking for replacements I contacted a Mouser tech and was directed to this as a upgraded replacement http://www.mouser.com/Search/Product...bbdniJVM8qc%3d
    I just ordered them and thought I would share this info with the rest of the class.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: c5707 or 2sc5707 replacements found
    not even close!
    • dmbj
      • May 2009
      • 23
      Well thanks
      I already ordered them on there advice, Looks like i'm off to ebay to get them then.
      • Toasty
        • Jul 2007
        • 4171
        You can return them, or if they were all you ordered, just refuse the package (leave BIG note for delivery service). Contact them and relate the info that their tech misguided you.
        Toast
        veritas odium parit
        • EGuevarae
          • Nov 2008
          • 1336
          Toast
          I agree with Toasty. It is not your fault, as you didn't pull out the "replacement" out of nowhere. Talk to them before the package arrives, and then refuse it.
          • ASUS ROG Maximus IX Code
          • Intel Core i5-7600K 3.8GHz
          • Windows 10 Pro x64
          • GeForce GT1050
          • dmbj
            • May 2009
            • 23
            I also ordered other stuff so i'll return them after a quick conversations with them. I'm sure it wont be a problem.
            • George Ortiz
              • Oct 2009
              • 51
              dmbj,
              here's a picture of the inverter/power supply board used in one of the four
              hp L1740 lcd monitors.
              George
              • Krankshaft
                • Jan 2007
                • 2328
                I hope that board darkening is from the C5707s and not from shorted turns in the transformer which caused them to blow.
                • jarapunga
                  • Jan 2015
                  • 6
                  • Zimbabwe
                  does this mean the c5707 has no equivalent?
                  • CapLeaker
                    Leaking Member
                    • 8327
                    why? Digikey has tons of these 2sc5707, the parts status is still active.
                    • B2L_Repairs
                      Huawei D15 no power found corrosion damage
                      by B2L_Repairs
                      I got a huawei D15 that came in for no power repair. Device charges , charging led flashedms but doesn't turn on. I found corrosion on an IC (ic name is BDJCY1...I can't find out much info about it online). I removed this ic and two pads are corroded but they can be repaired. To my knowledge inductors never short to ground (i might be wrong and please those that are more knowledgeable than me can correct me). I found few inductors short to ground when my multimeter is in beep mode ,indicating a short in the line of those inductors...but I don't know how to go about to find the shorted component...
                      02-06-2025, 01:05 PM
                    • Grouickman
                      Hofmann geodyna 6300 Wheel balancer
                      by Grouickman
                      Hi there,
                      First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
                      Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
                      I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
                      I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
                      03-31-2025, 05:29 AM
                    • slybunda
                      Gemcon capacitor replacements?
                      by slybunda
                      taken from my thread about car alarm siren here: https://www.badcaps.net/forum/troubl...rm-siren-issue
                      there are 2 caps which im looking to get replacements for.
                      Branded as Gemcon
                      single 100uf 16v 6.5mm x 11.5mm
                      single 100uf 50v 8mm x 11.5mm
                      lead spacing is around 3mm
                      there is space for 16mm tall caps
                      rs components is good place for me to go since its close by, what replacements do you suggest and do these need to be low esr?
                      the caps have...
                      02-05-2024, 03:36 PM
                    • gagarasta
                      Operating system not found, cannot enter bios or boot to usb
                      by gagarasta
                      Hello everyone, I had issues on my laptop acer 4752G
                      I'm using windows 10 until I decided to install windows 7 because of old hardware limitation, then I just found I cannot access my bios anymore. So far I already try these:
                      1. On system information its uefi not bios/legacy
                      2. Advanced restart but there's no uefi setting
                      3. Try to reinstall my pc using fdd but cannot enter boot selection
                      4. Press f2 f8 f10 only beep but straight into boot
                      5. Try reflash bios using fdd fn key+esc+power not success
                      6. Take the cmos battery off and...
                      11-05-2023, 11:23 AM
                    • dropfry
                      Dead t480s, trying to troubleshoot. May have found something.
                      by dropfry
                      Hello. I have a lenovo that will not show any indication of life. No led, sound or anything really. So I took the motherboard out and started testing points according to the advice in this thread: https://www.badcaps.net/forum/showthread.php?t=102409
                      PU201 is Showing 6v
                      VREG3/5 show a high value (around 20v) for a split second then drop down very quickly. Hold around 1v but then continue to drop to zero. One is showing .2v.
                      Fuse PF1 is showing very low voltage (which according to the thread deals with docking and is expected)
                      09-29-2023, 02:38 AM
