Operating system not found, cannot enter bios or boot to usb
  • gagarasta
    • Mar 2019
    • 20
    • Indonesia
    Hello everyone, I had issues on my laptop acer 4752G
    I'm using windows 10 until I decided to install windows 7 because of old hardware limitation, then I just found I cannot access my bios anymore. So far I already try these:
    1. On system information its uefi not bios/legacy
    2. Advanced restart but there's no uefi setting
    3. Try to reinstall my pc using fdd but cannot enter boot selection
    4. Press f2 f8 f10 only beep but straight into boot
    5. Try reflash bios using fdd fn key+esc+power not success
    6. Take the cmos battery off and wait 5 minutes and reinsert, no success
    7. Reformat hdd in hope bios can boot into another device, this is where I messed up
    8. Clone hdd with windows 10 to my laptop still not detected
    After acer logo boot "text operating system not found" text appeared
    I really avoid reflashing bios chip since I work far away from home.
    Any suggestion to try everyone? Thank you.
  • petehall347
    • Jan 2015
    • 4427
    Re: Operating system not found, cannot enter bios or boot to usb
    remove battery and try again pressing f2 ..if no go reseat the memory
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Try legacy seetings in bios.
      • gagarasta
        • Mar 2019
        • 20
        • Indonesia
        still cannot enter bios, I reseat memory too even change them.
        • gagarasta
          • Mar 2019
          • 20
          • Indonesia
          Yes but the main problem is I cannot enter bios
          • adamski1952
            • Oct 2021
            • 93
            • england
            If you try booting up with the cmos battery removed you may get the option to hit f1 to continue. or f2 to enter set up.
            • Sephir0th
              • Oct 2020
              • 1283
              Try with external keyboard
              FairRepair on YouTube
              • gagarasta
                • Mar 2019
                • 20
                • Indonesia
                Nice suggestion, I removed the cmos battery after 30 minutes turn it on without battery, but still booting like before cant enter bios ony beep when I press f2. Thanks anyway
                • gagarasta
                  • Mar 2019
                  • 20
                  • Indonesia
                  Yes I did
                  • gagarasta
                    • Mar 2019
                    • 20
                    • Indonesia
                    Ok guys, in the end I flash the BIOS Chip and everything is ok now, I really don't understand why the BIOS corrupted though, maybe about efi/uefi - mbr/gpt missmatch installation. There is a way that I miss to try, that is editing efi/uefi from cmd.
                    again, thank you everyone, this problem solved.
                    • eltano4i20
                      [HELP] SAMSUNG NP270E4E-K01AR
                      by eltano4i20
                      1) Error trying to enter the BIOS
                      --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
                      Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
                      BOOT PRIORITY ORDER (img-05)
                      1- Windows Boot Manager
                      2- SATA HDD
                      3- NETWORK
                      4- Debian
                      2) Error trying to access the BOOT MENU
                      --> I restarted the notebook and pressed [F10] but the BOOT...
                      07-04-2025, 12:39 AM
                    • throwaway327
                      by throwaway327
                      Model No: RC72LA
                      Serial No: SBNVKD001014459
                      06-18-2025, 05:52 PM
                    • q2v5
                      Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                      by q2v5
                      Lenovo T480s
                      Model 20L8-S3TE00
                      Board ET481-U10
                      Chip MX25L12873F
                      Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                      2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                      The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                      08-15-2024, 10:40 PM
                    • Neddsme
                      Bios partially corrupted somehow and now warm boot doesn't work which is critical
                      by Neddsme
                      Hie.
                      I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
                      Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
                      I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
                      I managed to run Windows troubleshooting and...
                      02-04-2022, 05:57 AM
                    • Max029
                      Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
                      by Max029
                      I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
                      I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
                      TY,
                      08-18-2024, 08:28 PM
