Lenovo T480s completely dead
  • Andreasbest
    • Aug 2014
    • 1188
    • Hellas ( Greece )
    Hello!
    Today i received a T480s that is completely dead, the MB is quite sophisticated from what i'm used to repair (4th and 5th gen) so i need your help before i touch anything.
    No liquid damage, no visual damage at all.
    All caps in red square are shorted to GND, not sure what and if means something.
    I'm all ears
    Thank you in advance!
    Link to schematic - https://www.badcaps.net/forum/showthread.php?t=81061
  • khaahk
    • Dec 2013
    • 806
    • Estonia
    Re: Lenovo T480s completely dead
    How do you define a short? (In ohms)
    Do you have a USB-C tester?
    • Andreasbest
      • Aug 2014
      • 1188
      • Hellas ( Greece )
      I set the ohmeter in beep and it's beeping in both sides, when i set it on Ω i get 0.4Ω in one pin and 8Ω on the other.
      So propably no short.
      If you suspect the charger i have tried multiple but no luck.
      • khaahk
        • Dec 2013
        • 806
        • Estonia
        This model has a known thunderbolt controller issue, the firmware of it gets corrupted. So USB-C tester might give an idea if the USB-C controller is communicating with charger and receiving full 20V. You can measure it with multimeter, but you have to find a spot where to take measurement.
        https://support.lenovo.com/ee/en/sol...dates-thinkpad
        • Andreasbest
          • Aug 2014
          • 1188
          • Hellas ( Greece )
          Didn't know that, thank you!!
          Can you suggest a point for measuments?
            • 21451
            Made a thread a while ago about the thunderbolt issue https://www.badcaps.net/forum/showthread.php?t=82558
            https://nadim.computer/posts/2018-10-26-thinkpad.html
            • Andreasbest
              • Aug 2014
              • 1188
              • Hellas ( Greece )
              Wow, that's exactly what we need.
              Can i do the whole procedure with the CH341A?
                • 21451
                I`m not saying thats the issue,neither is @khaahk ,just pointing out a known issue.You can try it though
                • Andreasbest
                  • Aug 2014
                  • 1188
                  • Hellas ( Greece )
                  Yes i will but can i do it with CH341A or i need Raspberry?
                    • 21451
                    You sure can,use NeoProgrammer,Colibri or ASProgrammer software.
                    • Andreasbest
                      • Aug 2014
                      • 1188
                      • Hellas ( Greece )
                      I tried 0 filled TB bios and system MB flashing but no luck at all, it's completely dead, no response at all.
                      So now we know it's not a bios issue and proceed with measurements i guess.
                      Any advice welcomed
                      • khaahk
                        • Dec 2013
                        • 806
                        • Estonia
                        Start with basics as usual, PU201 - VREG3/5, how much current is drawn...
                        But i suggest to purchase USB-C tester anyways, it is cheap and gives useful info about power consumption.
                        • Andreasbest
                          • Aug 2014
                          • 1188
                          • Hellas ( Greece )
                          i bought one but it will take some days to arrive, meanwhile we must measure what we can.
                          You want voltage on all pins of PU201 ?
                          • Andreasbest
                            • Aug 2014
                            • 1188
                            • Hellas ( Greece )
                            PU201 has no voltages at all, all 20 pins are 0v
                              • 21451
                              Check the fuses and mosfets, on page 70 .
                              • Andreasbest
                                • Aug 2014
                                • 1188
                                • Hellas ( Greece )
                                PF1 and PF2 are fine.
                                How should i check the mosfet?
                                • Andreasbest
                                  • Aug 2014
                                  • 1188
                                  • Hellas ( Greece )
                                  PF2 fuse reads 5v on both pins, however PF1 shows only 0.4mv.
                                  Perhaps a problem with upper mosfet?
                                  • khaahk
                                    • Dec 2013
                                    • 806
                                    • Estonia
                                    PF2 is most likely fuse for USB-C port input and PF1 is fuse for docking port. So it is normal that PF1 is 0.
                                    As PF2 has only 5V you have a problem with USB-C controller and charger not communicating. They should bring it up to 20V. You can try the docking port, does it give higher voltage (on PF1 then). This may be a port problem (visual check?), comm lines to PD controller, PD controller, anything else sitting between them.
                                    • Andreasbest
                                      • Aug 2014
                                      • 1188
                                      • Hellas ( Greece )
                                      I asked a friend to brink a dock the next days, meanwhile how can we proceed?
                                      Visually everything is perfect, like new.
                                      Charge port is in excellent condition too, i measure 5v in some of it's pins, nowhere 20v.
                                      • Andreasbest
                                        • Aug 2014
                                        • 1188
                                        • Hellas ( Greece )
                                        Bump
                                          Lenovo ThinkPad T480s Notebook T Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad T480s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480s boardview and T480s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                          09-06-2024, 02:34 PM
                                          09-06-2024, 02:30 PM
                                          09-06-2024, 12:00 PM
                                          09-06-2024, 11:50 AM
                                          09-06-2024, 11:40 AM
