Viglen CRT monitor intermittent jumping
  • roadrash
    • Oct 2015
    • 490
    • U.K.
    #101
    Re: Viglen CRT monitor intermittent jumping
    Ive got it all back together and powered up and it seems quite happy and tube lit up. Still no picture when connected to PC though. I had a another go at testing for a video signal on the pins that carry the RGB signals. I used the Isotech scope this time and I got this display that does look different to what I get from the pins on the dsub connector. I read a article online that covered measuring video signals on a anolouigue and digital scop[e and it says its very hard to get a decent display with out something call a video trigger which I dont think this scope has. Anyway does this picture look anything even remotely useabe?
    • R_J
      • 9542
      If you really want the video to be stable and triggered you are just looking to see where it is being lost.
      If you really want a stable video signal for one video frame or one line, feed the vertcal sync pulse from the pc into channel 2 of the scope and have the scope set to trigger on channel 2
      That could be good video? what is the pc outputing? a single c:> prompt a bios menu?
      Adjust the variable on the trigger control should provide a single frame of video.
      Type stuff on the keyboard and you should see the waveform change
      Remember this is a video signal that has NO sync pulses within it so it is hard to display a steady pattern. It is NOT like a regular broadcast composite video signal, that has the sync as part of the video waveform.
      On the computer the vertical and horizontal sync pulses are on seperate pins.
      I will take a guess at the video displayed on the scope and also guess that the scope trace did not start at the start of the scan (likely triggerd by some part of the video)
      • R_J
        • 9542
        Check if there is any video on the neck board, R in, G in, and B in. also check if you have voltages on Q807 e-b-c.
        • roadrash
          • Oct 2015
          • 490
          • U.K.
          #104
          Q807 has between 2.4 & 3.6v on all pins
          The RGB wires conected around the tube dont show any signal. The scope screen goes blank. (There is a Red, Green, Blue, & Yellow on that group of wires, is the yellow a sync or something?
          The PC boots straight to a graphical type desktop call GEM (graphical environment manager)
          • R_J
            • 9542
            You say the scope screen goes blank when checking for a signal on these 3 points? What is the input voltage range on the scope set to and is it also set to AC and NOT DC.
            You should have a similar signal on the neck board as you measured where the DB9 connector connects to the mainboard, only the amplitude would likely be larger.
            I am starting to suspect there are no or low voltages to the area that does the signal processing on the main board.
            I also don't see any yellow wire going to the neck board, The r,g,b wires between the neck board and main board are thin coax cables.
            There are no sync signals that go to the crt board.
            • roadrash
              • Oct 2015
              • 490
              • U.K.
              #106
              Looks like a misunderstanding, I was thinking when you said neck you meant around the base of the tube where where are 4 wires RGBY solderd on. These come up from the 4 pin connector on the pcb. Sorry about that I ested the right 3 coax wires on the tube pcb and they do have the same signal as that on the 9 pin D connector.
              • R_J
                • 9542
                So you are getting the video signal to the crt neck board (the board that plugs onto the crt). Now see if you are getting it to the transistors on that board.
                On the plug that goes to the neck board that has the 3 video signals, there is also a red wire, what is the voltage on it?
                That picture you provided is the side of the deflection yoke, you don't need to check anything on it.
                • petehall347
                  • Jan 2015
                  • 4426
                  • United Kingdom
                  #108
                  wondering if the power has been knocked out for the neck board . wouldn't think it was all dead otherwise .
                  • R_J
                    • 9542
                    I had him check the +115 and he said it was there, I also asked about Q807 "Q807 has between 2.4 & 3.6v on all pins" which seems low?
                    So now I am asking about a lead (red wire)that goes from the main to the neck board as I think it could be a supply for the board.
                    Its hard to trace based on the pictures that are obscured by wires, and no schematic.
                    • petehall347
                      • Jan 2015
                      • 4426
                      • United Kingdom
                      #110
                      all i was thinking in the past i have seen a lost colour because of bad transistor . on that board . its been a long time since i played around with crt though .
                      • roadrash
                        • Oct 2015
                        • 490
                        • U.K.
                        #111
                        Oh sorry that is called the deflection yolk. There is video signal on the power transistors but I can ony measure 1.0v DC on the red wire (next to orange wire) on the neck board. The tube heater light is a orange glow shouldnt it be a bit brighter than that?
                        • R_J
                          • 9542
                          That was one of the first voltages I asked about (back in post #26), you said there WAS 115 volts on that red wire
                          Quote:
                          Check if you have the 115 volt screen supply on the neck board (it is marked)
                          Yes it is. It did get detached and unsoldered during removing a cap but i resoldered it back.
                          Using "the picture", point to the wire you unsoldered during cap removal.
                          But that is still not the voltage I asked you to measure. but that 115v needs to be there because it is the supply voltage for the R,G.B driver transistors (the big to220's on the neck board)
                          • roadrash
                            • Oct 2015
                            • 490
                            • U.K.
                            #113
                            I forgot to change the scale on the meter to 200v, I am measuring 125v now on this wire.
                            • R_J
                              • 9542
                              Ok thats good, now whats the voltage on the other RED wire I asked about? It supples a lower voltage to the video circuit on the main baord and also up to the crt neck board
                              On one of your pictures that regulator ic looks like it could be a 7812, so the red wire should have 12 volts on it
                              • roadrash
                                • Oct 2015
                                • 490
                                • U.K.
                                #115
                                The other red wire on the neck board has 11.8v.
                                • R_J
                                  • 9542
                                  Ok thats good, one more voltage to check would be the G1 voltage (green wire on crt neck board next to R82?) If my memory is correct it should be a negative voltage
                                  • roadrash
                                    • Oct 2015
                                    • 490
                                    • U.K.
                                    #117
                                    G1 is a brown wire. It measures 63.3v
                                    • R_J
                                      • 9542
                                      ok brown, I don't think that voltage is correct, If I remember it should be a negative voltage, check where the wire leads back near the high voltage transformer, and check the few components that are there, I can't really see where it goes.
                                      • roadrash
                                        • Oct 2015
                                        • 490
                                        • U.K.
                                        #119
                                        I am not being very observant because it is -63.3v. So sorry but maybe i can be excused as i got your reply when i was in bed and got up and went to test it quickly so it didnt have to wait until the next day. That brown wire connects into the main pcb right next to a little coil/tranformer and there are only a couple of resistors next to it.
                                        • R_J
                                          • 9542
                                          I thought that was the problem. oh well onward and upward.
                                          Near the brightness control is a transistor marked Q212 check its voltages and see if they change when the brightness control is varied. that transistor conects to a wire at (C1) near q204 and I think goes to (C2)the area of the G1 voltage.
                                          The brightness control should vary that -63 volts if I am correct
                                            by momaka
                                            03-15-2023, 10:17 PM
                                          • wattage
                                            AOC AG493UCX 49-inch monitor - Firmware request
                                            by wattage
                                            Hello Badcaps Community,
                                            The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                            07-13-2025, 04:41 PM
                                          • ant3202
                                            HP 27es - LED monitor - Monitor Flashing On - Off
                                            by ant3202
                                            Hi Everyone
                                            Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                            https://www.badcaps.net/forum/troubl...lashing-on-off
                                            The monitor is HP 27es LED Monitor
                                            https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                            The monitor will randomly blackout and display no signal and will recover again.
                                            Sometimes need to power and off again to restore the display but...
                                            03-20-2025, 07:30 PM
                                            Wise Wing F199 19'' LCD monitor - recapped
                                            by momaka
                                            Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                            I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                            When I saw the Craigslist post, I wasn't...
                                            08-24-2020, 10:58 AM
                                          • sew333
                                            Pc shutdown, monitor flickered with no signal after 10 seconds
                                            by sew333
                                            My pc:
                                            10850K stock 4800mhz stock Kraken X73 good temps
                                            2x16 GB DDR4 GSKILL 3000mhz XMP
                                            Seasonic Tx-850 Ultra Titanium
                                            Gigabyte Rtx 3090 Gaming OC
                                            Aorus Z490 Pro Gaming
                                            1 TB SSD
                                            4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                                            Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                                            Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                                            Power...
                                            02-22-2022, 10:27 AM
