MAG 900W - red backlight
  • mladen82
    • Mar 2009
    • 39
    • Montenegro
    MAG model:900W product no:T906W
    inside lcd panel is Proview PV190WLCM
    i tried to light up CCFLs with good inverter but color is red/pink and after 2 sec shut down
    i need someone to confirm that CCFL are full dead, no any fix?
    Thanks in advance.
  • PlainBill
    • Feb 2009
    • 7034
    Re: MAG 900W - red backlight
    That is the failure mode of CCFLs, according to what I have heard.
    PlainBill
    • EGuevarae
      • Nov 2008
      • 1336
      The pink/red hue means the CCFL is dying. You must replace them. If you have another set of lamps, that could help (normally, only one of the two lamps on each pair is damaged). Maybe just one of your four lamps is dying, or two (one of each pair). I repaired one of that LCDs like 10 days ago. Same symptoms, the fix was the replacement of the lamps.
      There are 10 kind of people in this world: those that understand binary, and those who don't.
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • 16gb GSKILL TridentZ RGB DDR4-3200
      • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
      • Windows 10 Pro x64
      • GeForce GT1050
        2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
      • mladen82
        • Mar 2009
        • 39
        • Montenegro
        Ok thanks, i found this czech/korean company which sell lcd spare parts, and ccfl so i will contact for price
        http://www.lcdparts.eu/ccf-lamps-ccfl/
        if you have to reccomend any other company which sell ccfls, please post
        thanks again
        • EGuevarae
          • Nov 2008
          • 1336
          https://www.badcaps.net/forum/showpo...83&postcount=2
          Read the full thread here
          • GeForce GT1050
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            replace all the lamps.
            if 1 is bad the rest are soon to fail .they have the same number of hours on them.
            • EGuevarae
              • Nov 2008
              • 1336
              Good point.... like when one of your car's headlights go out, and you change them both. Sounds logical.
              • GeForce GT1050
              • mladen82
                • Mar 2009
                • 39
                • Montenegro
                unfortunately repair is not payroll, new 19'' wide monitor you can buy for 90euros
                4 CCFLs about 40-50e + shipment
                • Scenic
                  o.O
                  • Sep 2007
                  • 2642
                  that's why i've bought a 19 non-wide panel on ebay.
                  other option would be to find a 19" Widescreen LCD on ebay with a cracked screen.
                  BTW: i've found out that the brightnes you can set in the monitors OSD is waaay too high.
                  brightness doesn't change much at 60% and up. so i guess the CCFLs died because they get too high voltage because of the brightness range in the OSD is way too wide.
                  i've set the Proview to 20% brightness now. it's still very bright.
                  any setting higher than 30% is waaay too bright.. especially while surfing the net on white/gray sites like the badcaps forum..
                  • EGuevarae
                    • Nov 2008
                    • 1336
                    That is a good option (getting a 19" wide on eBay, just with a cracked screen, or if you want to experiment a little more, a dead one....). Also, I normally set the brightness around 50% (high...) and then I use the Video card drivers/control panel to adjust the gamma and other settings (temp, etc.).
                    • GeForce GT1050
                    • Bobdee
                      • Jun 2008
                      • 461
                      Nice one, that makes a lot of sense now you mention it,
                      Will be doing revised settings on mine, thanks
                      • mladen82
                        • Mar 2009
                        • 39
                        • Montenegro
                        Thanks for advice!
                        anyway does anyone maybe have schematic diagram of this mag/proview inverter board, as maybe i can bypass protections so inverter will work all time and CCFLs will light till total dead
                        • EGuevarae
                          • Nov 2008
                          • 1336
                          Thanks for advice!
                          I don;t think that's a good idea. No protection will mean over voltage (someone correct me if I'm wrong ) as soon as the lamps die, causing damage to the transformers or other components. The protection is there for a reason. I which I can give a more detailed or technical reason, but I can't. Just using common sense.
                          If you have a inverter to test with, do you have LAMPS to test with?
                          find out what lamp is the bad one, and maybe you can replace just one instead of the four (would be best, but if money is a concern or price is too high).
                          • GeForce GT1050
                          • marketta
                            • Nov 2007
                            • 70
                            the panel lcd HT190WG1-100 is compatible with the panel lcd PV190WLCM?
                            I attend your answer
                            THANKS
                            • Bobdee
                              • Jun 2008
                              • 461
                              THANKS
                              Thanks Marketta
                              Thats good info that you posted, I was too dull to do the same thing when I swapped a pannel about 6 Mnths back, I did not even keep notes now I dont even remember what unit it came out of and what it went into
                              I should keep notes like Eguevare does, but I have never been very organised got every thing, cant find anything when I want it
                              Good job BTW
                              • triplefour
                                by triplefour
                                09-13-2023, 10:43 PM
                              • DanPoka
                                by DanPoka
                                02-15-2025, 05:05 AM
                              • Comp_Pro
                                No Backlight Macbook A1990 820-01041
                                by Comp_Pro
                                Hello all,
                                Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                Tests performed:
                                There is no backlight even with a good screen.
                                Backlight IC is receiving the correct support voltages.
                                Fuse F8400 ok
                                Current sense resistor R8400 ok
                                Backlight IC is receiving 3.3V on enable pin.
                                Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                Backlight IC receiving 5V from PP5V_G3S
                                Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                05-06-2024, 10:23 PM
                              • cheebster
                                iPad Pro 12.9 5th Gen Backlight Issue
                                by cheebster
                                Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                Anyone...
                                05-20-2025, 09:17 AM
                              • canadaboy25
                                LG Flatron 24EN33TA No Backlight When Cold
                                by canadaboy25
                                I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                                I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                                03-07-2023, 12:23 AM
