attempt to repair power supply board
  • R_J
    • 9514
    Re: attempt to repair power supply board
    It seems like the power supply is working and supplying the correct voltage, but when it has a load the voltage drops. It is possible one of those caps are bad, and because they are small they won't look bad.
    • ryn0909
      Professor X
      • 122
      i completely understand what u r saying and i will get them changed out asap and let you know
      • ryn0909
        Professor X
        • 122
        i ordered new caps and ill let you know when they come in
        • ryn0909
          Professor X
          • 122
          So the remaining 3 caps came in the mail today. i installed them and we now have power. power light comes on blue when i press the pwr button. it remains on untill i press it again (just as it should). I see the backlights come on but nothing on the display. i tried it with and without a video cable plugged in and no difference. i know when this monitor (working as it should) is powered on, if i press the menu button the OSD menu should show up on the display. unfortunately it DOES NOT. when i had the vga cable plugged into my laptop and i powered on the monitor, the laptop detects it as HP F2105, which is correct. but still nothing on the display. Any Ideas?
          Just fyi, i have to go to sleep now, i work graveyard shift and i just got home about 2 hrs ago. ill check back here around 4pm hopefully, if not ill check back at sometime aftrer 8pm. thanx in advance for any assistance im excited for making progress with this thing.
          • ryn0909
            Professor X
            • 122
            **********Problem Found***********
            I found the problem and its located on the LOGIC BOARD. Attached are some pics of the problem component. Basically, it needs a new LOGIC BOARD GGRRRrrrr
            • rddube
              Aspiring Expert
              • Jun 2013
              • 908
              How did you identify that that chip is the problem? That chip is on the mainboard, but are you sure the Tcon board works? Did you check the fuse on the Tcon board?
                https://www.badcaps.net/forum/attach...8&d=1518022554
                The chip is blown, you can see the bulging at 0623F marking.
                • ryn0909
                  Professor X
                  • 122
                  WELL, IM BAAAAAAACK. and so i ended up finding a used logic main board on ebay for $15
                  i installed it and i get blue power light on when pressed. the backlights come on but still nothing on the screen. I plugged in a vga cable to my laptop, the laptop identifies the external monitor as the correct model (HP F2105). if i use the FN key on my laptop to switch to external display, the monitor screen will flash once as if its receiving the video signal but still NADA on the screen. i know there is nothing wrong with the lcd screen itself because the monitor worked just fine using the power supply board from my other f2105
                  • ryn0909
                    Professor X
                    • 122
                    i found the tcon board and found the smd type fuse and the fuse is good
                    • will62
                      • Dec 2016
                      • 229
                      • usa
                      #30
                      Follow the lvds cable. You probably have an integrated t-con. It'll be under a metal cover at the top of the panel. You'll have a fuse just past where the lvds cable attaches.
                      • ryn0909
                        Professor X
                        • 122
                        thank you, found the fuse and it is good
                          by sam_sam_sam
                          After all of...
                          07-13-2024, 08:14 PM
                        • Soulzink
                          Samsug washing machine. Power supply DC41-00189a board issue
                          by Soulzink
                          I am trying to fix a samsung washinmachine power supply main board.
                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                          The power supply board reference is the following: DC41-00189a
                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                          04-19-2025, 06:26 AM
                        • penangit
                          Hp v193 monitor power supply board
                          by penangit
                          Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
                          I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
                          I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
                          Steps taken so far:
                          Checked all...
                          02-21-2023, 04:00 AM
                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                          by sam_sam_sam
                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                          Found shorted diodes on main controller relays there are 3 of them that...
                          01-07-2023, 05:43 PM
