Hi All,
I have about 10 Gateway 900G 19" LCD monitors with the same problem.
They make a slow ticking and the 5V bounces in time with the ticking.
If I had a camera here I would take a pic of the guts, but I don't have one so I'll give a description.
It is a 4 lamp 19" LCD with the power supply (100-240AC in) and inverter on one board. It has your basic 12V 5V switching power supply with 12V going to the inverter section.
Here's what I know so far:
It is not caps. I replaced all the electrolytic caps even though they look fine. Same problem.
It's not the inverter section. I remove the jumpers to the inverter, same problem.
It's not any of the power semis (switching transistor and rectifers ok, rectifies AC in OK)
It's not the logic board. (Swap know good power supply and it works fine)
The biggest clue I have so far (least I hope it's a clue) is that the 5v bounces from 0 to 5 in time with the ticking, but the 12V barely bounces at all! I have double checked the rectifier and the caps on the 5V.
The 5V does this even when the logic board is disconnected.
Any ideas?
Much thanks-
Michael
Any ideas?
Much thanks-
Michael
Cellphone cam??
Thanks to your information my Grandson now will have a 17" LCD monitor.
