XFX XPS 650w 3XS PSU making Ticking/clicking sound
  • Solvik
    • Feb 2025
    • 4
    • Norway
    Hello
    i have a older powersupply from XFX that makes this wierd electronic ticking /clicking noise. Its not the fan thats making the sound. See video below. Is anyone familiar with what component this sound can come from?
    https://www.youtube.com/shorts/L6ZC5eAiXas
    https://www.youtube.com/shorts/6kLxjjyNP1w
    All voltages are normal.
  • Solvik
    • Feb 2025
    • 4
    • Norway
    The ticking sound changes as i draw more power from it, lets say i put 3 fans on one of the connectors, the sound gets faster and more quiet.
      • 31284
      maybe the PFC circuit has a loose coil that is moving with the pulses
      • Solvik
        • Feb 2025
        • 4
        • Norway
        You where absolutly right. Glue was cracked on multiple coils, glued em all down and now its all silent.! TY
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Interesting, I have a few APFC units that are also starting to get noisy, so maybe I need to do the same.
          Fingers crossed this was the issue. I always feed uneasy when APFC PSUs make strange noises.
          • Sisko
            Onkyo-593 No power and now clicking sound
            by Sisko
            Hi all!!
            Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
            10-03-2025, 02:18 PM
          • B0r1s
            Samsung UE49KS7000SXXH - fast clicking sound in standby mode
            by B0r1s
            PSU - BN44-00878A
            Symptoms:
            The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
            A weak clicking sound was coming from the transformer.
            Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
            Progress:
            After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
            01-17-2023, 04:58 PM
          • slimmy182
            [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
            by slimmy182
            Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
            I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
            Looking on google I found this:...
            01-14-2023, 11:55 AM
          • ChaosLegionnaire
            by ChaosLegionnaire
            09-13-2022, 09:02 AM
          • nbnb
            Vizio VO47L FDHTV30A Picture but no speaker audio, clicking sound
            by nbnb
            I have a Vizio VO47L FDHTV30A. The picture works well, but the sound only works through the RCA output jacks. The sound does not work through the internal speakers or the headphone jack. The TV has a rapid clicking sound when the tv is on that occurs about 4 times per second. The clicking sound volume is fairly low and is not affected by adjusting the internal speaker volume level. The clicking occurs whether or not I disable the internal speaker through the Vizio setup menu. The clicking only occurs while the TV is on.
            Any idea what is causing the clicking sound? Any easy way to...
            11-23-2019, 12:03 PM
