philips 170s turns on for 1s and than dead
  • mihovilko
    • Feb 2018
    • 17
    • Croatia
    #41
    Re: philips 170s turns on for 1s and than dead
    Here you go.
    • will62
      • Dec 2016
      • 229
      • usa
      #42
      Any markings on the side? Maybe like TK.2006M.101 or 080GL19T 8DN1.
      • mihovilko
        • Feb 2018
        • 17
        • Croatia
        #43
        Here it goes:
        IT-E19-NB4004B
        DCWM0541(02)INV
        • will62
          • Dec 2016
          • 229
          • usa
          #44
          If you read post #44 from the following thread, it sounds like the secondary should measure ~550 ohms:
          https://www.badcaps.net/forum/showth...NB4004B&page=3
          The IT-E19-NB4004B is available on ebay for about $5.
          • mihovilko
            • Feb 2018
            • 17
            • Croatia
            #45
            Thank you guys for your help so far.
            I'll try to get a transformer and I'll get back to you with the results.
            • mihovilko
              • Feb 2018
              • 17
              • Croatia
              #46
              Ok, here's the deal. The transformer came in, the resistance is very close to the one on the board. I installed it dilligently, however, other problems emerged.
              Pls halp.
              https://www.youtube.com/watch?v=aUEk...ature=youtu.be
              • mihovilko
                • Feb 2018
                • 17
                • Croatia
                #47
                Come on people! Anyone?
                The screen turns on and then the backlight fades away.
                No visible image on screen.
                Does anyone have an idea?
                Video is in the last post.
                  Recheck the LVDS cable connection between the logic board and the T-CON PCBA on the LCD panel.
                  Did you do any disassembly of the LCD panel? That looks like LCD panel problem.
                  • mihovilko
                    • Feb 2018
                    • 17
                    • Croatia
                    #49
                    First and foremost, thank you all for your patience.
                    The patient has recovered and working fine.
                    But besides the screen working, I want to thank you all
                    for helping me acquire new skills and understanding.
                    Forums like this are really the reason why Internet is a good thing.
                    All my love to you guys. (but not the gay kind)
                    • R_J
                      • 9532
                      Good to here you have it working.
                      So what is that you did to get it working finally? What you found might help someone else.
                      • mihovilko
                        • Feb 2018
                        • 17
                        • Croatia
                        #51
                        I guess budm was right.
                        I disassembled the entire screen down to the lamps,
                        tested the lamps and they were good.
                        I put everything back together and it works.
                        But I strongly suspect it was a loose cable, as budm suggested.
                        But nonetheless, the crucial part was
                        troubleshooting that transformer. That was key.
                        That and replacing all the bad caps.
                        • Rav_tangle
                          MacBook Pro 2011 turns on with keyboard light , screen dead
                          by Rav_tangle
                          Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                          I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                          Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                          is this...
                          05-31-2024, 04:09 PM
                        • kew1701
                          Philips taw6205 ambilight speaker STM32 mcu dead
                          by kew1701
                          Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
                          04-09-2025, 03:59 AM
                        • alpersen
                          Philips 40 PUK6809/12 Backlight turns off after 10-20 seconds
                          by alpersen
                          Hello
                          Mother called and said TV turns off after switching on. So after turning on Philips logo shows and probably 10-20 seconds image disappears, sat receiver is connected and sound is heard from source. So I turned on my phones light and I can see the image it seems backlight was off after some time. I dis assembled the cover hoping to see a distinc cap blown or leakage. Here are photos I took (I was after 22:00 pm and maybe some of them are dark). Should I order and change caps on the power circuit or what would you recommend? Thanks...
                          07-25-2024, 12:50 AM
                        • ressof
                          Philips 47PFL4606H/12 turns off after 10 minutes
                          by ressof
                          Hi
                          I have a Philips LCD 47PFL4606H/12 that turns off after around 10 minutes and then i cant turn i back on again without removing the power cord and attach it again. Then it turns itself off again after some minutes. When this happens the red led that usually indicates standby mode is off.
                          Can it be the same problem as in this thread?
                          https://www.badcaps.net/forum/showth...ght=47pfl4606h
                          01-23-2023, 12:52 AM
                        • Stephen
                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                          by Stephen
                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                          03-15-2024, 09:37 AM
