Fix for Benq FP737s 17" (Q7T3)
  • enterthehatrix
    • Nov 2008
    • 8
    #161
    Re: Fix for Benq FP737s 17" (Q7T3)
    Originally posted by davmax
    Thanks. That actually worked out cheaper than some I bought from another ebay seller (that haven't arrived still)
    • Jacknewboy
      • Oct 2008
      #162
      Hello Davmax.
      Thank you for your response. Yes I did solder all the transformer connections. Coincidentally, in the last couple of days, an old Kriesler television set (1976 - 59/3), that normally operates in my work area, has failed – the power supply has hiccups indicating an overload. I would bet on the failure being a faulty horizontal output transistor caused by cracks in the solder around the pins of the horizontal output transformer – probably caused by mechanical vibration. So not much is new!
      Also, I must have been sleeping when I typed FET - I had the data sheets of the 2SC5707 bipolar transistors on the table beside me when I wrote the last note.
      • enterthehatrix
        • Nov 2008
        • 8
        #163
        Had no luck so far with replacing the fuse, FU9024N and 5705 , and I still haven't received those other 5705s I originally ordered.
        Do you know what voltage the backlights take? I might try to power it externally as an alternative solution.
        The bright side is that I can use these to make a multitouch screen.
        • afo
          • Dec 2008
          • 8
          #164
          hello all,
          some very interesting reading, i like many others stumbled upon this thread when searching for a fix for the monitor i'm currently looking at. to be precise, a benq fp767-12 (Q7C3).
          I've got a couple of hopefully easily answered questions and also some professional advice please...
          The symptoms are that when connected the backlight flashes momentarily and a message in a small box in the middle of the screen also appears but it's too quick to make out what it's saying. The blue ring stays on and this action can be replicated by pressing the power button to off then on again.
          On close inspection of the board, there seem to be no issues at all. No bulging caps, loose tracks..even the transformer joints look as good as the rest of them.
          I used a multimeter on the 2SC5707's and got some form of reading over all 6 connections (BC, CB, BE, EB, CE, EC) - admittedly my knowledge of caps, trans and resistors isn't as good now as a few years back when I did Electronics GSCE haha.. but am i mistaken thinking i shouldn't have had readings from ALL polarities and pins? Or am i making an obvious error!?
          Can someone confirm that this problem is most likely to be caused by the transistors/fuse/solder points? I know that may sound like a silly question on this thread, but i just wanted to ask seeing as there are a few different symptoms mentioned in the various posts.
          the link provided by davmax to the US supplier on ebay will work out to be cheap so I will most likely try this out anyway. especially seeing as the owner of the monitor said if it's not a simple fix then to chuck it!
          on to some advice...
          having stripped the monitor and seeing that the screen itself is actually fairly slim, i thought of some more artistic uses for it if fixed. I was wondering whether it would be ok to mount the screen in some other form and then have the circuitry away from it? I would look into extending the two connectors for the backlights and can only see a problem with the ribbon cable...!?
          the monitor has built-in speakers, which I wouldn't use...so i'd only use the power button mounted next to the rest of the circuitry.
          thanks for reading!
          • afo
            • Dec 2008
            • 8
            #165
            not sure if anyone is even reading this, but i have now replaced the 6 components (3x 5707's, 2x9024's and 3A fuse) and re-soldered the transformer legs. I am happy to report the monitor is working fine...it's going back to it's former-owner rather than my plans for a designer piece lol...i have something else in mind now requiring a smaller lcd
            thanks to the contributors of this thread who pointed me in the right direction from their work.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Congrats!
              Mann-Made Global Warming.
              - Dr Seuss
              • davmax
                • Dec 2005
                • 899
                #167
                Yes well done afo. Just read thread today. Your original meter reading description indicated transistor failure. Glad you fixed it so quickly with parts kit.
                Extending the ribbon cable is not a great idea as you no doubt concluded.
                160Gb WD SATAII Server grade
                Nvidia 8500GT 256Mb
                Samsung 18x DVD writer
                33 way card reader
                Windows XP Pro SP3
                17" Benq FP737s LCD monitor
                • kopper
                  • Jan 2009
                  #168
                  davmax, just want to say a big thanks for your input. I have a faulty 17" FP737s (QT73) monitor. I have a bit of experience and can fix most monitors myself, but this one had me stumped. I had replaced the transistors (Q739, Q740, Q759 and Q760) but still not working. Replaced IC751 and a few other sus parts, including most of the caps, but still not working. I was just about to give up and chuck this monitor when I thought I would have a search on the net.
                  I found the site, read your posts about the problem causing transistors and then read about the FUSE (PF751 on my board). Because it looks like any other capacitor on the board I completely overlooked it. I will have to get a fuse next week, but Im sure that Im going to have this LCD working again (thanks to yourself).
                  Just want to say thanks again. Your work is really impressive and I hope that one day Im as good a tech as yourself.
                  All the best to you and your family, you made my day!
                  • vinbar1
                    • Jan 2009
                    #169
                    Hi everyone i am very new to this and My father-in-law is an electical enginare. He is teaching me some things. I was hoping someone had a skematic for this board so he can go more in depth with fixing this moniter. I have look everyplace I could on my own and came up short. Any help would be great.
                    When I first got the moniter it would power on but no back light. I could only see an image if it was plugged in to computer and at the right angle.
                    We so far have found that the bel 3a fuse is bad and 1 of the c5707s are bad.
                    Just to see what would happen we pulled the bad trannie and used a jumper for the fuse .
                    We were only able to get the Benq splash for about 2 sec and then it would go into standby. This is differant then what first was happening, as before the moniter would stay on just no back light and I never saw the benq logo. The only way to see anything was to have it plugged into the computer.
                    We are going to replace the trannie with a TIP3055 thats what i could find localy and I think we will just for now replace the bel fuse with a slow burn glass fuse and holder to see if that will realy solve the problem.
                    This is realy fun let me know what you think about what we are attempting and I will let everyone the results.
                    Thanks for this thread its awsome.
                    • Bobdee
                      • Jun 2008
                      • 461
                      #170
                      Hello vinbar1
                      Much better to go with kit, heres a link,
                      http://cgi.ebay.co.uk/2SC5707-C5707-...3286.m63.l1177
                      there are many on ebay just search (2sc5707)
                      all the info you require to fix monitor is in this thread have a good read, pay paticular attention to bad solder joints on board especially the inverter transformers, Good Luck.
                      bob
                      • afo
                        • Dec 2008
                        • 8
                        #171
                        hello all,
                        i received a call today from the friend whose monitor i fixed a little over a week ago - he gave me the news that after a couple of days usage it has stopped working again with the same problem!! i have said i would look at it again but i don't see much point in replacing the parts again if it's gonna blow again (!)...so i'm hoping for some more help from the experts...
                        is it likely that i need to put in the extended 'protection' mentioned in this thread, or does only a few days of usage imply other problems?! as previously mentioned, there were no bulging caps on the board at the time i did the first repair.
                        look forward to hearing back, Afo.
                        • vinbar1
                          • Jan 2009
                          #172
                          Thanks Bob,
                          I am still intersted in the skematic so that I can learn more using this board as a teaching aid. I will get the kit after I test to see if what we fould was the problem.
                          Thanks again
                          • Bobdee
                            • Jun 2008
                            • 461
                            #173
                            Hello again vinbar1
                            Did you see these they may help
                            https://www.badcaps.net/forum/showth...atic#post38917
                            https://www.badcaps.net/forum/showth...atic#post38612
                            https://www.badcaps.net/forum/showth...atic#post38239
                            the links they give may help you, if you have not seen them
                            . bob
                            • Bobdee
                              • Jun 2008
                              • 461
                              #174
                              hello all,
                              Hell0 Afo
                              https://www.badcaps.net/forum/showpo...&postcount=141
                              https://www.badcaps.net/forum/showpo...&postcount=143
                              The aboye 2 links may help
                              The resoldering of inverter transformers seem to be your issue, it may take out a 2sc5070 again, also check whole board for cracks in solder joints some are hairline, use about 8 x magnification,I spend a good half hour or more looking, you will find some.
                              Good luck bob
                              • afo
                                • Dec 2008
                                • 8
                                #175
                                Originally posted by Bobdee
                                Hell0 Afo
                                Good luck bob
                                thanks for your reply Bob, however if you look here:
                                https://www.badcaps.net/forum/showpo...&postcount=165
                                ...you'll see that I did re-solder the joints but the problem has arisen again - hoping someone can comment on further possible causes.
                                thanks
                                • Wizard
                                  • Mar 2008
                                  • 2296
                                  #176
                                  UL-94V-0 is a tag that says the PCB substance met the inflammability that it snuffs out by itself when heat source is removed. Same for the components as well.
                                  This is major reasons this prevented so much fires when a part or circuit board burns out.
                                  I have seen results of burn craters (as in complete burnt through) in the circuit boards when this happens.
                                  Cheers, Wizard
                                  • Bobdee
                                    • Jun 2008
                                    • 461
                                    #177
                                    Hello afo
                                    Im sorry but your post I quote,
                                    (not sure if anyone is even reading this, but i have now replaced the 6 components (3x 5707's, 2x9024's and 3A fuse) and re-soldered the transformer legs.)
                                    says ONE transformer to me and does not mention the TWO inverter transformers, so there was misunderstanding, sorry about that
                                    .. bob
                                    • tanguy
                                      • Dec 2008
                                      #178
                                      davmax,
                                      Thanks for your hard work in figuring out what's wrong with these BenQ LCD monitors! I followed the discussion in this thread and...
                                      I just successfuly repaired a BenQ T701 a few minutes ago!
                                      The hardest part was getting the bezel apart .
                                      Thanks again, everyone!
                                      • jtan
                                        • Dec 2008
                                        #179
                                        My HP 1955 has blinking problem, I wonder where I can get information on how to locate the fuse... Thanks!
                                        • Bobdee
                                          • Jun 2008
                                          • 461
                                          #180
                                          hello jtan
                                          you do not say whether to buy, or find on board,if buy this may help
                                          http://cgi.ebay.co.uk/LOT-OF-4-Bel-3...742.m153.l1262
                                          seller also has 4A+5A fuses, good luck
                                          also this thread would be better for you
                                          https://www.badcaps.net/forum/showth...light=hp+l1955
                                          bob
                                          • x_orange90_x
                                            Vizio E55-E1 bad backlights or bad inverter?
                                            by x_orange90_x
                                            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                            I don't know how exactly to test the inverter itself. Is it...
                                            01-29-2025, 09:24 PM
                                          • Gentian
                                            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                            by Gentian
                                            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                            03-06-2023, 07:07 AM
                                          • valvashon
                                            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                            by valvashon
                                            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                            01-04-2024, 01:44 PM
                                          • eccerr0r
                                            A modified sine wave inverter + a grid tie inverter?
                                            by eccerr0r
                                            If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                            Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                            08-31-2023, 09:14 PM
                                          • caseyjay_48
                                            Sony KDL-46BX450 Inverter Troubleshoot Logic
                                            by caseyjay_48
                                            I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                            I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                            09-23-2022, 08:08 PM
