Fix for Benq FP737s 17" (Q7T3)
  • bizu
    • Oct 2008
    #141
    Re: Fix for Benq FP737s 17" (Q7T3)
    Thanks to Davmax for initiating this thread.
    I have a Benq FP731 and the problem was just the same as most others have found.
    After replacement 4x2SC5707 2xFU9024 and the fuse 3A all was well again. I resolder joints on the inverter transformers.
    • epiman46
      • Oct 2008
      #142
      First, a big thankyou to all on this thread. I had two BENQ 737s that died, more or less simultaneously. I replaced the SC5707s, and the 3A fuse, and they both worked. Yay! For not quite a week. Then they both died.
      One will run for about 5 minutes, fade (get dim) and then croak. The image is visible under inspection with a strong light. Giving it a 10-minute rest will give me about 5 minutes of usable function. The other, just flashed, then died. Again, the image is visible on strong illumination.
      So replacing a few transistors has not solved the problem. I am not interested in going that route again, unless I have a solution that addresses the problem of why they failed in the first place. I have a few questions:
      - Which is the better candidate for repair?
      - has anyone else had any success with Davmax's current-limiting protection circuit?
      - should I be recapping, on general principles? I don't see any bulges, or discharge. All the solder joints looked good.
      • davmax
        • Dec 2005
        • 899
        #143
        Did you resolder all the inverter transformer connections? It sounds as thoughthe 5707s are gone again. There are claims that the resoldering will enable a permanent fix. However as you have seen I have implemented the current limit system on three monitors with no further failures. This method catches all heavy overcurrents FAST (10usec).
        160Gb WD SATAII Server grade
        Nvidia 8500GT 256Mb
        Samsung 18x DVD writer
        33 way card reader
        Windows XP Pro SP3
        17" Benq FP737s LCD monitor
        • ozcar
          • Nov 2008
          #144
          I would just like to thank all of you who contributed to this thread. When my FP737s died last week ago I was about ready to give up on it and get a new monitor. Then I found this thread, and one 2SC5707 and one fuse later I am back in business. I resoldered the transformers too - not that I could see any problem there.
          With a bit of luck maybe it will keep going for another few years. If it dies again I might consider the suggested circuit changes.
          • msubzwari
            • Nov 2008
            #145
            Greetings from Karachi, Pakistan. This thread is a treasure trove for Benq affectees.
            I have a 5 years old Benq 17 incher. Model is FP767-12. It gave up on me couple of days ago. While searching on the net for repair/service centre, I stumbled into these forums & boy am I glad that I did. The board/circuit is the same as being discussed/shown in photographs posted in this thread.
            To cut the long story short, the 3A fuse & one of the 2SC5707 were busted in my board. I could not find 2SC5707 in the market but one shop had 2SC5706. It has slightly lower Collector & Base Current max ratings compared to 2SC5707 but rest of the specs were a close match. So decided to go for it instead of going the TIP3055 way.
            I replaced one pair but the lamps did not work. Thinking the C5706 are busted, I took them out & tested. They were Ok.
            Checked Hfe value of 5706 and it was around 320. Checked the working 5707 and it has Hfe of 380. I bought some extra C5706 and two of those gave me Hfe reading of 400 & 395. So removed the ones I soldered earlier and installed the higher Hfe rating C5706 pair. That brought the life back to the display.
            Packed it up, connected to PC, turned it on.....nothing. Opened it up again, checked all of my soldered components which seemed fine. Double checked any problems in the caps, nothing obvious observed.
            Decided to resolder anyway & while I was at it, resolderd all transformer legs. Powered it up and it was alive again. Packed it up again & it has been working well since then.
            I just turned it off after being used for about an hour..so far its holding.
            My sincere thanks to all the contributors to this thread for sharing their valuable insight into this very interesting problem.
            • enterthehatrix
              • Nov 2008
              • 8
              #146
              Greetings from the UK.
              Our work office is loaded full of these benq monitors (all Q7T3). Needless to say they'll all eventually fall to this problem as we've had 2 die already out of 14 identical models.
              Anywho, I was wondering if anyone could clarify exactly what I should replace in order to get it working (identifier code on board, and part name / code) and any basic and simple preventative measures I could take to stop it happening in the future, if not stop it happening quickly again in the future.
              The reason I ask is that the information I've read here conflicts with some information on another site. However, I trust the judgement from this forum more since there are several of you vs the writer of the article I read.
              • enterthehatrix
                • Nov 2008
                • 8
                #147
                I replaced the 3a fuse, and it instantly blew up along with the SC5707's.
                Smoke was pouring out of it and it stank the house out.
                my guess is that I've blown a bit more than the SC5707, but there are burn marks only around the SC5707s.
                I've ordered replacements they should turn up in a few days. Anything else need replacing besides SC5707 and the fuse?
                • dvorav
                  • Oct 2008
                  • 43
                  #148
                  Hi there,
                  I have two questions: (possibly for Davmax, but of course, everyone's answers are welcomed)
                  1) Have you replaced all/some of Elite Caps? Or did you simply leaved as it is?
                  2) Add to the overcurrent protection - have you replaced the C770 by polyester 1uF one? I did so, but then protective circuit didn't work, monitor not as well. (Probably I have done some mistakes, but I'm not sure.) After I removed main part of the circuit, monitor went on. (It's not a pleasant look on the cut and bridged-again tracks, but anyway...)
                  Thanks for suggestions.
                  • dvorav
                    • Oct 2008
                    • 43
                    #149
                    TO: enterthehatrix
                    Sometimes the IRFU9024N are needed to be replaced. Try to short-circuit-test them.
                    And possible all caps, but I have questioned that in previous reply.
                    • Jacknewboy
                      • Oct 2008
                      #150
                      Hello Badcaps Forums.
                      Thank you for the birthday wishes. They have prompted me to report on my activities with my Benq FP737s-D 17” LCD monitor.
                      The monitor was about two months out of the warranty period when the backlight failed. This was diagnosed because computer Control Panel – Display program still recognised the monitor's existence and, with a torch at a suitable angle and a high contrast picture, the image was identifiable. Without a service manual, I cautiously dismantled the display to look for any obvious problems. The most obvious was that it would not be easy/possible to run the monitor in a dismantled state to make measurements. This would be even more difficult because it would be necessary to connect the monitor to a computer for it to be activated (come out of standby mode).
                      At that time I did a search of the internet looking for a source of a service manual or at least a circuit and stumbled onto Badcaps Forums. With the information that the most likely cause of the backlight failure was the two FETs (2SC5707) of the high voltage inverter, I inspect a couple of catalogues and made a couple of phone calls and found the FETs in stock at The Go Company in Brisbane for a total cost of $3.30 each. (Incidentally, they had had to replace the same components in a Dell monitor on there service counter). At that price, I bought two to install and two more in case another problem had caused the initial failure.
                      At that time I had not registered with Badcaps and so had not been able to download the Forums' diagrams and photos. After a static check of the components around the area of the inverter, I installed the FETs. I had checked the main fuse but did not recognise the existence of the mini fuse. Having registered and downloaded the Forum attachments, I found that the simplest way to replace the fuse was to fit an M205 PCB fuse mount – with slightly extended leads – placed strategically between other components. The unit was assembled and worked correctly and I did not think it worth dismantling again to take a photo of the fuse location.
                      The monitor has now been working many hours almost every day, for between one and two months. It is used as the second monitor on a note book computer which rarely moves from the desk top. As a precaution, I have developed the practice of not pushing the power button on the monitor until Windows is in full operation, and turning the power off after the computer has removed the video signal and the display has gone to standby. At this time I do not intend to include other suggested modifications.
                      Thank you for the information contained in the discussions on your Forum. It has certainly saved me considerable time investigating the monitor failure.
                      • davmax
                        • Dec 2005
                        • 899
                        #151
                        Hi Jacknewboy.
                        Good to see you were successful. A few items for future reference.
                        1. This is a good source for all the components you need: http://cgi.ebay.com.au/ws/eBayISAPI....m=320301193969 I see that this auction keeps renewing.
                        2. The 2SC5707 is a bipolar transistor. The black ones in the link above and the MOSFETs are the blue ones.
                        Hope you resoldered all the transformer connections on the board.
                        Nvidia 8500GT 256Mb
                        33 way card reader
                        Windows XP Pro SP3
                        • epiman46
                          • Oct 2008
                          #152
                          The latest news: One of my FP737s seems to have recovered after having its transformer leads resoldered. This is the machine that would run for about 5 minutes, then fade out. It has now been running for a day or so without any problems. I am very hopeful about the other that may need a some 5705s replaced. I'll do the transformer leads for that one at the same time.
                          • enterthehatrix
                            • Nov 2008
                            • 8
                            #153
                            I've got the one to work (oddly) and the other doesn't.
                            The odd working one has backlight lit up even when the power is off, which means I have to leave it on to turn the backlight off.
                            The other doesn't light up at all.
                            I'm not willing to spend any more money on these than I already have, so I might make a projector out of the one that doesn't turn on.
                            Having said that, the smaller PCB with the VGA connection connects to the power PCB. Could you get the pin out for that for me?
                            • Wragie
                              • Nov 2008
                              #154
                              Just to add another data point and something else to look for.
                              I have a Q7T3 manufactured in June 2004. (Price was free to good home)
                              On mine it exhibited sort of what everyone has described as the inverter section having problems. On mine I always had a display but it would white out or grey out. And I noticed that a tap on the side of the monitor would sometimes clear this up or make it better.
                              I took it apart when this got annoying enough and didn't see anything obvious. I soldered the transformers as they had stress cracks around the pins. Anyone know when Benq went to low lead or lead free solder? This looks like lead free done using lead temps etc. Anyway this fixed it for about a week and it started acting up again. My wife said she caught a wiff of hot/burnt electronics. So I took it apart to see what popped. NADA, no smells on parts.So this time I went through and soldered a few more things including of the caps. Plug it back in and I have a solid green power light but no image.
                              This time I took it apart and checked just what I had soldered. One capacitor C710 hadn't looked like it was soldered right so I had cleaned off a bit of solder and soldered it again. So I took it out and checked it. It was well within specs. However looking at the board I see that the pad looked like it was lifting but the trace looked ok. Thought I had cooked it or it was part of the poor quality a few people had mentioned. Put the cap back in, soldered it, no continuity. So I solder on a jumper put everything back together and the monitor is now working again flawlessly.
                              The trace and pad must have just had enough connection to work. Judging by the tapping having an effect on it I would say a very slight contact connection. When I soldered I must have moved it or removed what was making the connection. This one is hard to spot and I only saw it (about the third time) as I was using a magnifier. The pad and trace look that normal.
                              Dave
                              • davmax
                                • Dec 2005
                                • 899
                                #155
                                Yes Wragie you have described the poor quality of the PCB of the lamp inverter circuit. Certainly great care is required when reworking this board.
                                Nvidia 8500GT 256Mb
                                33 way card reader
                                Windows XP Pro SP3
                                • enterthehatrix
                                  • Nov 2008
                                  • 8
                                  #156
                                  Another one bit the dust today at work, so I'll have to give this a shot using parts from the failed one. The parts still work, my guess is the fault it elsewhere.
                                  • enterthehatrix
                                    • Nov 2008
                                    • 8
                                    #157
                                    Oh, and I can't find a supplier for IRFU9024N in the UK. Any suggestions?
                                    • davmax
                                      • Dec 2005
                                      • 899
                                      #158
                                      Try these.
                                      http://cgi.ebay.com.au/LOT-OF-TWO-2-...3286.m63.l1177
                                      http://cgi.ebay.com.au/KIT-4-PCS-2SC...3286.m63.l1177
                                      Nvidia 8500GT 256Mb
                                      33 way card reader
                                      Windows XP Pro SP3
                                      • Wragie
                                        • Nov 2008
                                        #159
                                        Just thought I'd reply here as well so if anyone else runs across this.
                                        When I had pulled the cap to check it, thinking it was toast I noticed that just a part of the pad was lifted. What was strange was at this point there was no crack separation or lifting of the pad from the track or the track itself. ie it was just a small portion of the pad. At this point I thought perhaps I had been a bit too hot on the iron (thinking of previous bad board comments). I was looking at this under good magnification so I should have seen anything else. What I did see was that the edge of the pad was actually resting on top of the track. And as I mentioned to Dave off list, my board has a fair amount of hand written marks on it such as using a grease pencil.
                                        What I am wondering is that if Benq was reworking boards and then shipping them out? The overlapped edges show that there was something added or fixed (but not too well). So far since my discovery the monitor is working perfectly. And it is running quite a bit cooler than before which is quite interesting.
                                        Cheers
                                        Dave
                                        • davmax
                                          • Dec 2005
                                          • 899
                                          #160
                                          Please note that the unmarked capacitor in the diagram is a 1uF polycarbonate. This cap can be seen in the top of board view at top right posted on 15th October. It can replace C770 in so doing cut the PCB track effectively to the right of this capacitor as shown on the circuit diagram, not where to cut is XXX.
                                          I read somebody had problems with the mod. make sure you use the latest diagram posted 14th Oct and note the above.
                                          Nvidia 8500GT 256Mb
                                          33 way card reader
                                          Windows XP Pro SP3
                                          • x_orange90_x
                                            Vizio E55-E1 bad backlights or bad inverter?
                                            by x_orange90_x
                                            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                            I don't know how exactly to test the inverter itself. Is it...
                                            01-29-2025, 09:24 PM
                                          • Gentian
                                            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                            by Gentian
                                            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                            03-06-2023, 07:07 AM
                                          • valvashon
                                            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                            by valvashon
                                            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                            01-04-2024, 01:44 PM
                                          • eccerr0r
                                            A modified sine wave inverter + a grid tie inverter?
                                            by eccerr0r
                                            If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                            Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                            08-31-2023, 09:14 PM
                                          • caseyjay_48
                                            Sony KDL-46BX450 Inverter Troubleshoot Logic
                                            by caseyjay_48
                                            I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                            I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                            09-23-2022, 08:08 PM
