Fix for Benq FP737s 17" (Q7T3)
  • oddbodd
    • Mar 2013
    • 121
    Re: Fix for Benq FP737s 17" (Q7T3)
    I'm in the middle of resoldering, and have just come across an unsoldered pin on T601. Is that right?
    Edit: Answering my own question, I've see on post #244 there's a picture of the same board, with the same pin unsoldered.
    • oddbodd
      • Mar 2013
      • 121
      Good news. I now have a working monitor again!
      I was almost ready to call it a day. After desoldering/resoldering everything suggested in the earlier post... it still didn't work.
      So I retested the new C5707s and found that one pair had gone bad. So I removed them and reinstalled 2 of the original 4, all of which had tested OK after they were removed.
      So I got there in the end, even if I did get a bit of a headache using a magnifying glass for so long!
      I just hope it keeps working...
      Thanks to all who helped.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        #303
        Hi -Well done! This often happens unfortunately. The 5707s are shot and are replaced but if the soldering is not redone then they go again as it is the main reason they went bad in the first place.
        To increase its life expectancy you could also replace the middle size caps
        if not all except the BIG one.
        • oddbodd
          • Mar 2013
          • 121
          Yes, I think that should have resoldered first and then replaced later. Lesson learnt.
          I'll bear that in mind, about the caps, too. Thanks
          • Behemot
            • 4845
            • CZ
            #305
            I am just curious, did somebody found the final solution? From what I remember when I've read this through half a year ago, I remember davmax found there are some spikes when the display goes off and back on right again while restarting system (pre-POST). I also think I remember he thought he found the solution but than the 2SC5707 just blew again…
            • R_J
              • Jun 2012
              • 9611
              I just repaired a Dell E173FPb (Benq board) that had one shorted 2sc5707, and the cause was poor solder connections on components in the inverter, (transformer and cap. c735) plus other misc. poor connections.
              • x_orange90_x
                Vizio E55-E1 bad backlights or bad inverter?
                by x_orange90_x
                I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                I don't know how exactly to test the inverter itself. Is it...
                01-29-2025, 09:24 PM
              • Gentian
                APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                by Gentian
                I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                03-06-2023, 07:07 AM
              • valvashon
                Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                by valvashon
                For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                01-04-2024, 01:44 PM
              • eccerr0r
                A modified sine wave inverter + a grid tie inverter?
                by eccerr0r
                If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                Next thing is trying to charge the batteries using solar power, but that's another issue ...
                08-31-2023, 09:14 PM
              • caseyjay_48
                Sony KDL-46BX450 Inverter Troubleshoot Logic
                by caseyjay_48
                I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                09-23-2022, 08:08 PM
