Samsung 2693HM white screen
  • xscp
    • Aug 2014
    • 20
    • Hungary
    Hi.
    I have a Samsung 2693HM that only displays a white screen when it's turned on.
    I took it apart and reseated the cables and it worked fine for a day or two, but then it came back. Reseating the cables don't seem to help anymore.
    I would like to try to fix it, or at least diagnose the problem to see if it's worth getting parts for it.
    I have no experience with electronics, I have access to a simple multimeter and can do basic soldering if needed.
    Any help would be appreciated.
  • selldoor
    Slow Learner
    • 7870
    Re: Samsung 2693HM white screen
    Pictures are really good apart from the first one - can you re take it.
    In Pic 5 right in the middle at the top below the connector ther is a small white fuse that looks to sat ?T 3A on it - can you test it.
    No power to the board meter on ohms 200 one probe to each side
    • xscp
      • Aug 2014
      • 20
      • Hungary
      I tested the fuse and the reading was going down from around 10 to 0.
      Also, when i move the main board it makes strange sounds, like if some small metal object would move around inside, i can't really locate where it comes from.
      • selldoor
        Slow Learner
        • 7870
        The ohms reading should not fall away - have you good battery in meter?
        Result should be the same as touching probes together.
        "Also, when i move the main board it makes strange sounds, like if some small metal object would move around inside, i can't really locate where it comes from."
        That is exactly what it is - I think it is the rectangular component to the right of the main processor. cant make it out - perhaps 530s or something.
        The screen can be turned from landscape to portrait and the little ball switches the picture.
        Suggest you read these to threads if you have not done already
        https://www.badcaps.net/forum/showth...ghlight=2693HM
        • xscp
          • Aug 2014
          • 20
          • Hungary
          I think I had the meter on wrong settings or something, I checked again and now it was 0 for both the fuse and the probes touched together.
          My t-con seems to be different than the one in the other thread. I followed what momaka wrote and measured VDDA, VEEG and VDDG, they were 5K, 41.9K and 99.8K in that order. I will measure the capacitors and voltages tomorrow.
          Are the highlighted components the ones he mentioned (D502, Q503, and Q504, and D504)? The labels are a bit cluttered.
          • selldoor
            Slow Learner
            • 7870
            Yes I think they are - it is not too critical as he is not testing those he says to test the
            capacitors part numbers C??? in the area around them - they are the buff/brown ones.
            Maybe as it is a slightly different board the caps may be better.
            Next time the board is in the machine can you try to remember to test the voltage on each side of the fuse with respect to ground.
            Hopefully Momaka will join in when you have the voltage tests and tell us what he thinks.
            • xscp
              • Aug 2014
              • 20
              • Hungary
              The capacitors on the t-con seem fine, none of them had low resistance. The lowest was around 0.4K iirc.
              Both side of the fuse was 5.27V. VDDA, VDDG and VEEG were all 0.
              I checked the voltages on the psu at the connectors (5.3V / 18V / 24V) and they were ok.
              • selldoor
                Slow Learner
                • 7870
                Cant actually see the fuse? anyway can you test the voltage regulators - left hand side of the board one is a1117 18 the other ends in 33
                • xscp
                  • Aug 2014
                  • 20
                  • Hungary
                  I meant the fuse on the main board.
                  I tested the voltage regulators (the outer pins to the middle/ground, right?), 17-18 was 0 / 0.1-0.6V, 33 was 0 / 0.6-0.8V
                    Please report in this format:
                    Big tab up, Black probe on chassis.
                    Left (1, GND)) = xxx V
                    Middle (2, or tab, output) = xxx V
                    Right (3, input) = xxx V
                    • selldoor
                      Slow Learner
                      • 7870
                      Wrong - If you re doing a voltage test then black probe to chassis ground
                      and probe each pin, meter on vDC20
                      • xscp
                        • Aug 2014
                        • 20
                        • Hungary
                        J384 1117-18
                        Left = 0 V
                        Middle = 0 V
                        Right = 0.45 V - 0.75 V
                        J164 G1084-33
                        Left = 0 V
                        Middle = 0.45 V - 0.75 V
                        Right = 0.85 V - 1.05 V
                        The voltages were jumping up and down.
                          For the light of me, I cannot see the fuse on the T-CON board, I expect it to be close to the right side of the LVDS connector.
                          • mmartell
                            • Oct 2013
                            • 3189
                            It *may* be on the left side of the lvds connector, on the top right of the barcode sticker labelled "FU10" but hard to tell.
                            • mmartell
                              • Oct 2013
                              • 3189
                              Here..
                              • xscp
                                • Aug 2014
                                • 20
                                • Hungary
                                Is that a fuse? I can't make a better picture at the moment, it has UD written on it if that helps.
                                Its resistance was 100 ohm (at first), voltages were 5.28V and 1.04V, with the latter jumping down to 0.8-0.9V and occasionally to 0V. When i checked the resistance again it was 245 ohm.
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  Ya I can't be sure and I'm not familiar with that marking either.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    A good fuse should measure less than 1.0 ohms.
                                    UD code suggests 3.15A 24V as per
                                    https://cdn.badcaps-static.com/pdfs/...7263e74802.pdf
                                    --- begin sig file ---
                                    --- end sig file ---
                                      That is why I am confused because you indicated that it has 5.27V on both ends of the fuse but the regulators show almost nothing.
                                      So which FUSE did you test on the T-CON to get that 5.27V on both ends and now you have 5.28V on one end and 1.04V on the other end?
                                      • xscp
                                        • Aug 2014
                                        • 20
                                        • Hungary
                                        I thought he meant the fuse on the main board (picture 5), because that's what he mentioned in post 2. This one had 0 resistance and 5.27V on both sides.
                                        In my last post I wrote about the one on the t-con, the one pointed out by mmartell, this had 100 / 245 ohm resistance and 5.28V and 1.04V on its ends.
                                        • harp
                                          White screen repairs
                                          by harp
                                          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                          05-13-2024, 03:43 AM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                          by JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                          No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                          Please help. Thanks in advance!
                                          08-12-2025, 11:45 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • valvashon
                                          Samsung UN60JU6500, stripe on left side of screen
                                          by valvashon
                                          Friend sent me this picture of what their 60" Samsung from 2015 is doing. I didn't have any luck getting rid of a vertical stripe in another TV that developed one so I'm not too excited about trying to fix this one. It's mine for the asking; wish it had a dead power supply or bad backlights instead.
                                          Is this most likely to be a connection at the circuit board or where the ribbon cable hits the screen itself?
                                          Update: was just informed that this stripe comes and goes and has been doing this for a couple of months.
                                          Thanks, Val
                                          Yesterday, 03:01 PM
