Nuova Marea MV-1501 (Unicont) Blink and off at power on
+ More Options
Posts
  • sententia
    • Oct 2013
    • 269
    • Greece
    I have this Nuova Marea display, which i found is manufactured by Unicont, that is a marine LCD. It can be supplied with 10-36VDC.
    The problem is that when power is supplied to it it blinks and then is dead. The output of the DC-DC converters is 11.6V and stays there when the monitor look dead, so i doubt it is that the problem. I also tried to supply 12V straight to the cables but no go.
    I tested one filter capacitor on the inverter board which is a HITANO ECR 330uf 50V and measures OK.
    Any ideas of what to check/measure next?
    Do you think the problem might be with the lamp connection on the lamp side?
    A lot of gables are glued so i am trying to be as less invasive as possible.
    Any help greatly appreciated!
    Thanks!
  • sententia
    • Oct 2013
    • 269
    • Greece
    Re: Nuova Marea MV-1501 (Unicont) Blink and off at power on
    some more pictures of the bottom side of the inverter.
      • 31015
      try it with the invertor unplugged.
      • sententia
        • Oct 2013
        • 269
        • Greece
        Hmmm .... unplugging the inverter does not make any difference. Then power light does not blink... do you think i should check the logic circuit?
        • sententia
          • Oct 2013
          • 269
          • Greece
          I have taken some more pieces apart from the monitor and have done some more testing.
          By the way the LCD panel is a LG Philips ....
          I have replaced some capacitors from the logic pcb as the big 220uf 25V Chengx cap that measured around 195uf and 4ohms ESR but didn't seem to help. That logic board has a lot more smaller cap also from Chengx that make me worry if i should check all the small ones.
          Also i found that the power led is connected to the inverter board.
          If it is of any importance the monitor draws about 0.25 Amps with the inverter connected and about 0.11 without it.
          Does anyone know if the monitor would operate without the lamps connected?
          Or at least if the power led would be on??
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            It is an unusual setup - it is unlikely to "work" without bulbs as it will go into protection and shut down.
            With it all connected up can you anchor the black lead of your monitor to ground and with
            your meter on 20vdc put the red probe on each of the 12v pins (red and yellow) on the inverter as you switch the monitor on
            • sententia
              • Oct 2013
              • 269
              • Greece
              Yep, the inverter gets steady 11.6V at power on and stays there.
              The On/Off white wire get 0.03V at power on. When power supply is switched of it jumps to 0.3V and goes to 0.
              The only sign of life at power on is a faint blink of the backlight.
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                OK - Are the bulb leads soldered to the board? as against having plugs on? crazy!!
                Next test is for 5 v on the other connector on the inverter board same as before as you switch on.
                • sententia
                  • Oct 2013
                  • 269
                  • Greece
                  Yes although the board does have plugs soldered to it! But on the other hand because it is a marine monitor they try to be as secured as possible, hence they are soldered to inverter plus hot glue on top!! (a bit of a pain to remove!).
                  Now the other connector. The 5V line is not used however the inverter outputs the 5V steady as soon as power is connected.
                  Also Pot+ and Pot have 0.25V both.
                  I start to think that i should make some cfl test lamps to get the lamp connection problem out of my head ... (i fixed some time ago two monitors with loose lamp cable on the lamp side.)
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    Can you first do the same voltage test again on the LED pin.
                    Other queries - On the "Main?" board is the brown gunk flux or glue- can it clean off with
                    IPA to check its not corroding the traces. And its probably ok but in the bottom right corner of that board pic 7 there is a fuse F1 - can you test it?
                    Yes test cfl lamp is good - link in any budm post - I can find it if you cant.
                    Also can you unplug the two white plugs on the inverter and turn it over for a picture of the bottom of it.
                    • sententia
                      • Oct 2013
                      • 269
                      • Greece
                      the voltage on the power led pins is 0.01V at all times. I have removed the brown glue under the coil and fuse is OK.
                      I have budm's ccfl tester link, thanks for the suggestion!
                      Check post #2 it is the bottom in two photos.
                      Thanks for the help really appreciated!
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        Sorry - missed them totally - not that they help much. cant see through glue!
                        You are going to have to remove the glue or at least some of it.
                        In pic 1 the joints dont look good - but you my be able to tell better.
                        Next test is to work out which joints are the secondary winding posts on the
                        transformers- You measure both transformers ( meter on ohms 2000)
                        and the results have to be within 3%.
                        Is there a part number on the side or top of the transformers
                        • sententia
                          • Oct 2013
                          • 269
                          • Greece
                          Transformer is CTX410805 ... I have the datasheet attached to this post.
                          As for the joints of the transformer it looks like soldering residue or paste.
                          I am trying to remove the glue to take some more measurements and i will get back to you! ....
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            Ok I see from the pdf there are two secondary windings on each transformer ( should have been obvious but see below) one to the socket and one to the wired posts. So you need 4 to compare.
                            What does seem odd is that normally if there are 4 places to attach a lamp they must all have a lamp connected else the feedback picks it up as an error and switches off the
                            lamp circuits. I can only guess that they have disabled the no lamp detection.
                            • sententia
                              • Oct 2013
                              • 269
                              • Greece
                              Transformers test ok in secondary. The secondaries are connected in series.
                              Each secondary is about 55ohms ...
                              Both are 110ohms ...
                              Now i took apart a cfl lamp but i see that there are four connections and i don't know how to proceed to connect it to the inverter. Are those two separate lamps or are they connected together??
                              Thanks!
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                See budms pic https://www.badcaps.net/forum/attach...0&d=1333950677
                                Each pair are twisted together and it is one lamp.
                                solder a wire to each pair then unsolder one ccfl and solder the now 2wires from the cfl in its place.
                                Whoops - see next post
                                • selldoor
                                  Slow Learner
                                  • Dec 2010
                                  • 7870
                                  STOP - may be wrong yours is a stick bulb may have 2 tubes
                                  • sententia
                                    • Oct 2013
                                    • 269
                                    • Greece
                                    thanks for pm ... I have not tried anything yet.
                                    it does look like two separate bulbs but they do seem to interconnect at the end.
                                      His CFL is one lamp, just twist the two wires on each end together just like what I show in my pictures.
                                      • sententia
                                        • Oct 2013
                                        • 269
                                        • Greece
                                        thanks budm!
                                        so it doesn't matter that the board has separate connections for each wire?
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
                                        • EazyBone
                                          Un50cu7000 2 blink oddity *partially solved
                                          by EazyBone
                                          I write this to maybe help another with this TV.
                                          So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                                          The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                                          03-18-2024, 10:24 PM
                                        • Vebririon
                                          panasonic TX-P50V10E 6 blink led problem
                                          by Vebririon
                                          I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                          Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                                          I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                          05-17-2025, 10:16 AM
                                        • mikey5791
                                          Help on Samsung Syncmaster T220 dead ccfl lamp
                                          by mikey5791
                                          This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                                          Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                                          10-18-2020, 03:17 AM
                                        • khelane
                                          test active pfc power with lamp test
                                          by khelane
                                          Hello
                                          I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                                          Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                                          Is there a way...
                                          06-03-2025, 01:00 AM
