Dell 1800FP no 5v standby.
  • triplefour
    • May 2014
    • 1747
    Re: Dell 1800FP no 5v standby.
    the numbers are really small so i cant be sure but its something like
    11NG0C2
    or maybe its
    11N6OC2
    or maybe its
    11HG0C2
    or maybe its
    11RGUC2 (i swear it kinda looks like that too)
    but u get the idea...
    i think its that first one though...maybe
    Don't fear the repair...
    • triplefour
      • May 2014
      • 1747
      on ICE2XS01 i get 73k ohms on pin2 and 28k ohms on pin3
      • triplefour
        • May 2014
        • 1747
        the resistance between pin7 and pin6 on the ic i removed is 0
          "0.3 would mean it is totally shorted" If I read it correctly, that is the resistance between the Negative leg and the Ground pin of the IC which is tied to to the negative leg of the cap.
          • triplefour
            • May 2014
            • 1747
            yeah so .3 would be totally fine in that case
            • triplefour
              • May 2014
              • 1747
              it cant be zero since even the resistance between my 2 probes touching each other isnt
              • triplefour
                • May 2014
                • 1747
                i think he was meaning to say that if the resistance between pin6 and ground were .3 then it would be totally shorted. but that even a resistance of 3.1 is too low
                • triplefour
                  • May 2014
                  • 1747
                  er.. i think that is what he said actually
                  • triplefour
                    • May 2014
                    • 1747
                    theres a fine line between not enough and too many words when describing these things...
                    • bammbammfran
                      • Apr 2014
                      • 476
                      these are right
                      but 7 to 6 is shorted out ,so it is bad
                      the 11n60c2 might be what killed it again
                      Check resistance from 6 to 7 on the board after the chip is removed
                      • triplefour
                        • May 2014
                        • 1747
                        the resistance between 6 and 7 on the board after the chip is removed is hard to measure because it keeps climbing...up to over 1000kohms
                        • bammbammfran
                          • Apr 2014
                          • 476
                          real high resistance is good (no dead short on board at that area)
                          The 11n60 is probably a problem and probably cooked the ICE chip
                          part number SPP11N60C3IN-ND at digikey.com should work as a replacement
                          before removing the old one, check your resistance between the center pin and each side pin and side pin to side pin. write these down
                          then recheck all 3 measurements with your tester probes reversed.
                          then when you install the replacement- see what the differences are
                          since you have the ICE out now, take the measurements of the new one also with the new ice not installed yet
                          also check 7 to 6 resistance on the new ice before you fire it up
                            Check the MOSFET'Gate R/D resistor network to see if it is damaged also.
                            • triplefour
                              • May 2014
                              • 1747
                              burning up a chip is a learning experience...guess i should have tested further up the chain before just replacing it...
                              im sorry i dont know what you mean by mosfet gate r/d resistor network. could you please explain. thank you!
                                For you to learn, trace out the connection on the Gate pin of the MOSFET to see what it is connected to and draw out the Diagram on a piece of paper, you will learn that lots of the Gate drive circuits are basically the same.
                                • triplefour
                                  • May 2014
                                  • 1747
                                  ok i will try that.. i have a hard time seeing where the traces go but if its for my education i will get it done. as for replacing it, i do have lots of old power supplies i could scavenge parts from. what are the odds on finding this 11n60c2 in my pile of junk?
                                  • triplefour
                                    • May 2014
                                    • 1747
                                    ok i dont fully understand but i think it was helpful to do this. bit by bit it starts to make a little sense. but first of all, can you tell me if my interpretation of the resistor network connected to the gate pin is correct?
                                    • triplefour
                                      • May 2014
                                      • 1747
                                      i can see that the drain draws its power from the positive leg of the main filter cap and that it flows through the source pin to the resistor network and the ICE chip and eventually back into the negative leg of the main filter cap.... but i still dont quite understand... it kinda looks like it splits up and goes back into the negative of the filter cap and also to pin4 of the ICE
                                      • bammbammfran
                                        • Apr 2014
                                        • 476
                                        pin 5 on the ice activates on the gate of the 60n11
                                        then the 60n11 completes the circuit through the source and drain
                                        kind of like a light switch
                                        this system is working on switching the neutral/ return of power side
                                        the reason you can read + power on the drain pin is because it travels through the transformers coil
                                        a lot of time the power mosfet (in this case 60n11) shorts or leaks too much power through the gate and it gets to the controllers and damages the controller chips
                                        so you just need to check that all the resistors in that area are showing ok resistance wise
                                        and that the diodes are also working in the right direction drain pin of the 60n11 i
                                        • triplefour
                                          • May 2014
                                          • 1747
                                          and i can test all of these in circuit?
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • F R 2568
                                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                                            by F R 2568
                                            Hello all,
                                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                            If the laptop is only connected to the AC adapter (battery removed):
                                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                            The power/battery...
                                            01-08-2025, 05:45 AM
                                          • Gatolina
                                            Low Standby voltage on Dell PSU
                                            by Gatolina
                                            Hello! I'm trying to fix this Dell ATX PSU H235PD-01 which had a burned tny279 for the 5V Standby.
                                            I've changed it, checked the capacitors and diodes. Now I have 5.8V in pin 2 (bypass), 358V in Drain (pin 4), reaching the primary of the transformer but only 0.7v outputting to Standby purple wire.
                                            What could be the problem? Thank you...
                                            01-28-2023, 06:01 PM
                                          • diamon
                                            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                            by diamon
                                            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                            Pictures of these boards:
                                            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                            Dell...
                                            02-28-2024, 12:51 PM
                                          • OntarioTL
                                            Dell 5410 greyed out BT
                                            by OntarioTL
                                            Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
                                            If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
                                            Dell Lattitude 5410
                                            Service Tag...
                                            07-25-2025, 01:28 PM
