Dell 2408WFP broken power supply
  • gunnish
    • Oct 2013
    • 33
    • Sweden
    Got this one for free as broke, therefore i do not what did this do it. The monitor did not do anything on startup, I suspected bad caps as always. This was not the case. The power board is defect, the Power Factor corrector is blown and a diode is odd looking.
    Basically: am i correct that the PFC is a L6561D (from these schematics https://www.badcaps.net/forum/attach...7&d=1359307560 in this thread https://www.badcaps.net/forum/showth...hlight=2408WFP However, the blown chip does not look like a ST to me.)
    Which other components should i test?
    Can someone confirm which chip it is?
  • gunnish
    • Oct 2013
    • 33
    • Sweden
    Re: Dell 2408WFP broken power supply
    The diode is a IN5406. It conducts both ways and is physically cracked.
    • bammbammfran
      • Apr 2014
      • 476
      you are going to need to also check the two diodes on that heatsink that is right next to those two parts to see if either one of them is shorted out in any direction. You should remove the bad diode and the 8pin 6561 before you check for shorts on those
      I can not see what those parts are but one if probably a 3 pin and one might be a two pin
      the 2sk3502 is probably one of the numbers of the two that I mentioned
      • selldoor
        Slow Learner
        • 7870
        I think you read it wrong, if you look in the first post by Bicycle228 he has replied to retiredcaps questions to the original poster.
        That is
        2) IC601 is likely your SMPS chip.
        a) What is the part number? = 1203P60
        So he is saying IC601 is a 1203P60 Which is the NCP1200 series chip.
          • 31028
          1n5406 is a slow diode designed as a rectifier.
          it's crap.
          at a minimum i'd use a UF5408
          much faster and a higher max voltage.
          • gunnish
            • Oct 2013
            • 33
            • Sweden
            That is
            Yes, there are two DIP-8 chips in this circuit and the 1203 is still there. The chip for the PFC is blown and as L6561D is a PFC chip, i assumed that this would be the blown chip.
            it's crap.
            Isn't the diode in this circuit just supposed to be a rectifier? Because you are saying this I assume that is not the case. I assume that it is part of the PFC, what frequency does those normally operate at?
            • bammbammfran
              • Apr 2014
              • 476
              your k3502 is almost definitely toast and that is probably what killed the diode and l6561.
              Again, it may have taken out the other 2 leg diode on that heatsink. I would change all 4 and the fuse.
              check the 4 leg bridge rectifier on the smaller heatsink on that end of the board for resistances from + to - once those parts are removed
              • selldoor
                Slow Learner
                • 7870
                Yes I agree the L6561D is likely to be the blown chip as it is the only other
                DIP- 8 chip on the board.
                When I looked at your picture of it I read the IC number next to it as IC601 (sorry)
                For future enquirers perhaps you can confirm what the IC number is, as it is not on the schematic
                • gunnish
                  • Oct 2013
                  • 33
                  • Sweden
                  Status report:
                  Rectifying bridge - OK
                  N_MOSFET K3502 - drain shorted to sources, charging gate does nothing, replaced with K2543
                  TO-220 diode - works
                  L6561D -replaced, now socketed
                  IN5406 - shorted, replaced
                    • 31028
                    they are both rectifiers,
                    but the 1n series is intended for rectifying slow stuff like AC psu's
                    the UF series is designed for high frequency stuff.
                    (UF = Ultra Fast)
                    • bammbammfran
                      • Apr 2014
                      • 476
                      Status report:
                      AND ???? Still not working ??? OR ???
                      Can you post a good picture of the bottom of the board ?
                        How about the Gate drive resistor (R668)/diode (D655) network, the Source resistor R670 (0.22 Ohm) are they OK? When the IC and the MOSFET blown up like that about anything in the path will be damaged.
                        • gunnish
                          • Oct 2013
                          • 33
                          • Sweden
                          Tested now, the monitor does not react at all, not even the power button light.
                          I'll look at the resistors and diodes.
                          • jetadm123
                            • 2169
                            What the voltage at the main cap? Should be around 390vdc. If zero volts, check the main fuse.
                            • gunnish
                              • Oct 2013
                              • 33
                              • Sweden
                              The main fuse conducts.
                              The primary electrolytic capacitor sits at 330 V.
                              Both D655 and R668 are surface mound and I'm not that good with desoldering and resoldering surface mount components, but as they are connected in parallel I seem to have to desolder them to measure them. Will do later.
                              R670 > 20 MOhm, so what will have to be replaced.
                              EDIT:
                              R670 now replaced.
                              The fuse blew when i connected the powersupply.
                                R670 is the resistor for the Source pin of the MOSFET for PFC voltage booster circuit. So either the MOSFET is shorted or the Gate drive signal form the IC is stuck high instead of switching on and off at high frequency so need more troubleshooting.
                                • mustang80
                                  • Nov 2015
                                  • 3
                                  Sorry for posting to an old thread, but need advice relating to the same topic.
                                  2 days ago, my Dell 2408 made a loud pop and is now unresponsive. I tried the main fuse first, obviously, with no luck. So I opened it. Took me a while to spot it as I was looking for blown capacitors. Then I spotted a blown resistor! It's number R670 on the board (22ohm).
                                  My question is, is this something that is likely to just blow, or would a fault earlier in the circuit cause this? Happt to replace myself, but I'm just a bit unsure about finding the right value resistor.
                                  If one of you could be very kind and point me in the right direction from this page:
                                  http://cpc.farnell.com/webapp/wcs/st...&storeId=10180 I'd really apreciate it!
                                  Here is a pic of the blown resistor:
                                  [/URL][/IMG]
                                  All help would be greatly appreciated, and my apologies if I broke any rules! First post.
                                  Many thanks
                                  • mustang80
                                    • Nov 2015
                                    • 3
                                    sorry, that should be 0.22ohm
                                      by sam_sam_sam
                                      03-31-2024, 02:12 PM
                                      by sam_sam_sam
                                      07-01-2024, 06:34 AM
                                    • JimBanville
                                      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                      by JimBanville
                                      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                      Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                      I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                      09-13-2023, 07:21 AM
                                    • CMCM
                                      Russound CA4 Power Supply Repair
                                      by CMCM
                                      Hello Everybody,
                                      Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                      Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                      The outputs marked 12v and 20v are all measuring only 1v.
                                      The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                      The capacitors physically look clean (no bludgesor leaks) and...
                                      07-03-2025, 01:12 PM
