LG W2252TQ transformer
  • paulstef
    • Dec 2013
    • 724
    maybe somebody can help me with this. I got a W2252TQ monitor from someone whose backlight doesn't turn on. I was told somebody has already tried to repair it but had no success.
    The monitor turns on very dim for about half a second and then goes black, when shining light on it I can see that it is just the backlight that is missing, the picture is there.
    On the attached pictures you can see the transformer which is a QGAH02098. The transformer has apparently two output windings, there are cables connected to all four connectors that go inside the screen.
    Now something strange. The transformer measured open on one output side. I took it out to see if the winding is visibly burned. The corresponding (open) output doesn't even have a coil (see picture)!!
    Why would they connect cables to an output winding that doesn't exist?
    The transformer has already been soldered and my guess is maybe that the person who tried to repair it put the wrong one in.
    Can somebody with the schematic at hand tell me what's the correct transformer for that board or how many output windings it's supposed to have?
    thanks for reading
  • selldoor
    Slow Learner
    • 7870
    Re: LG W2252TQ transformer
    I dont have time right now but board number is EADp-42F if you search for that you will find images and see what transformers they have.
    Look for your transformer on lcdparts.net. click on buy it now (it doesnt )
    My guess would be its a hard to find one and someone has taken it off to see if they could rewind it, failed and just put it back.
    • paulstef
      • Dec 2013
      • 724
      Thanks for that info.
      The transformer looks like new though. I also find easily some on ebay and amazon for 10 to 15 bucks.
      I'm not particularly experienced with computer display repairs, do these transformers have in general two secondaries?
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        The pins are there for mechanical reason, to hold the transformer firmly into place. It is possible that there was no winding there in the first place.
        A working TV? How boring!
        • paulstef
          • Dec 2013
          • 724
          The transformer is being offered as a replacement for Samsung BN44 00264B.
          Now, I did find the schematic for BN44 00264A. The transformer definitely has two secondaries.
          I get the impression that the cheaper options we get over the internet are fake components. So the person that replaced the transformer bought one of these and put it in and it didn't work.
          I don't see why any manufacturer would put in extra unused components (the cables) into a $200 product.
          Maybe I open the display itself to see if the cables are indeed connected to something.
          I still would appreciate if anyone has a schematic for that board or at least part of it, the part with the transformer.
          • selldoor
            Slow Learner
            • 7870
            Well if your not going to follow advice?
            I say again
            It clearly does not have a second winding
            Did you look for other boards as suggested
            • paulstef
              • Dec 2013
              • 724
              I say again
              Ok, after some more research I've seen that the transformer is obviously not the right one. The board EADP-42AF uses the TMS93137CT. And this one has two secondaries. And the TMS93137CT is sold on ebay as the right one for the W2252.
              So my guess is the person repairing it was confused and put the wrong transformer in. I'll order the TMS and see if it works.
              Thanks for your input.
              • selldoor
                Slow Learner
                • 7870
                Correct - its this one
                http://www.lcdparts.net/TransformerD...ProductID=3697
                so we will have to wait now and see if that fixes it could be more than one problem.
                Have you anything else you can test the bulbs on
                • paulstef
                  • Dec 2013
                  • 724
                  What exactly would I need? Several kHz of 1000V? I don't have that...
                  Or is there a simpler way?
                  • selldoor
                    Slow Learner
                    • 7870
                    Hahahahaha you might have - its called "another monitor" one that works- you just sub one bulb for another. I think you can also get bulb testers from that
                    lcd place or ebay but the transformer may be just as cheap.
                    • paulstef
                      • Dec 2013
                      • 724
                      I have one other good monitor , not sure if I want to open it and risk doing any damage. I will wait for the transformer for now. Unless I find some other way to test the bulbs.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4291
                        • Italy - Milan
                        Hi, some ps boards are used for different monitors even with less inches so maybe that trasformer type is made also for boards/monitors with only 2 lamps (i know it's difficult.. 2 lamps are for 15 inches only maybe) with only 1 winding, so the part is wrong, if you want to test the lamps post here the label of the biggest ic under the board, i can try to read its datasheet to disable the protection and you can test each couple of lamps with the part of the onverter with the winding present (resolder the wrong one).
                        • paulstef
                          • Dec 2013
                          • 724
                          Thanks I'll have a look at it later. What is strange is that there are wires connected to the in-existent transformer winding. I think somebody tried to repair it and put the wrong one in...
                          • paulstef
                            • Dec 2013
                            • 724
                            That`s what happened, I was right. Someone tried a repair and put the wrong transformer in. The monitor works with the transformer TMS93137CT.
                            • selldoor
                              Slow Learner
                              • 7870
                              Well done - good fix - not seen anyone put a totally wrong transformer in before
                              well worked out.
                              • Behemot
                                • 4845
                                • CZ
                                Similar problem: backlight goes on for a brief moment, than of, few seconds, one and off again and than it stays the same. Customer tried two new transformers before he sent it to me so transformers are NOT the problem.
                                The board is from Delta as you can see, FAN7314 is the inverter controller. I got 3.3 V on enable pin.
                                Tested the blue output caps, they seem OK. There are some GP sHitanos and Samxon GF used as replacement for the original ones but I guess this should not be the source of the problem…or should it? Voltage seems fine, well, at least with the inverter off there is 21 V.
                                • cpt.charlie
                                  • Sep 2013
                                  • 270
                                  • Spain
                                  Overconsuption maybe?
                                  • Behemot
                                    • 4845
                                    • CZ
                                    Should also add I've tried a pair of different lamps. It is possible though that there is one bad on each side and I have actually just replaced it Can test lamps in different panel to rule that out…
                                    • Behemot
                                      • 4845
                                      • CZ
                                      With different panel and 4 different lamps same problem so it's somewhere in the inverter itself.
                                      • mauda
                                        • Mar 2016
                                        • 24
                                        • Czech republic
                                        Behemot: I am having the same problem. New transformer and lamps, but the problem is still the same.
                                        Did you find the solution?
                                        • FrancescoV
                                          Onkyo HT-R390 no sound output, video output ok
                                          by FrancescoV
                                          Good morning everyone,
                                          I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                          The firmware reported is the following:
                                          M:1.00/11107BLP
                                          D:?.??/????????
                                          O:1.00/11107AL
                                          The DSP firmware given the question marks seems corrupt.
                                          On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                          05-11-2025, 02:59 AM
                                        • bauto601
                                          KDM 480W PSU upgrade succes! (opinions?)
                                          by bauto601
                                          Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                          A "nice" YoungYear unit? - Badcaps
                                          The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                          12-26-2023, 03:05 PM
                                          NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                          by sam_sam_sam
                                          I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                          I bought this from an eBay seller but unfortunately they only had one
                                          I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                          I bought three of from them to also make battery packs with this output power limit in mind
                                          I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                          04-23-2025, 05:50 AM
                                          KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                                          by momaka
                                          For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                                          http://www.rmac.kingwin.com/products.../abt_650MM.asp
                                          I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                                          What mostly drew me into buying it is its 2x PCI-E power connectors...
                                          03-29-2022, 11:34 PM
                                        • CoppellTVRepair
                                          Troubleshooting PFC with SPC1012T not raising output
                                          by CoppellTVRepair
                                          It has been a long while since I posted here to ask anything....hope you can help.
                                          I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
                                          I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
                                          03-09-2025, 10:38 PM
