Identify component on LCD inverter board
  • rawdr
    • 5
    Hi. I've located the damaged component on an LCD panel used in an industrial EDM wire machine. Need help identifying a viable replacement.
    The monitor: NEC NL6448AC30-10
    Inverter board part: NEC HBL015
    The chip itself looks like a DPAK type transistor and has "KI472 4H" on it... unless that I is actually a 1? Does anyone know how to track down this component, or know enough about lcd inverter circuitry to suggest a general replacement?
    This component is on the opposite side of the board from the two inductors and two capacitors, as you'll see in the picture. The damage is showing through, so I may end up replacing these components as well.
    Thanks for the help.
    -Dave
  • jetadm123
    • 2169
    Re: Identify component on LCD inverter board
    Possibly a 2SK1472 N-channel mosfet used in high speed switching applications.
    • R_J
      • 9559
      I agree,
      Part number 2SK1472
      Category Discrete => Transistors => FETs (Field Effect Transistors) => MOSFETs
      Description N-channel MOS Silicon Fet, Very High-speed Switching Application
      Company Sanyo Semiconductor Corporation
        F1 fuse (with 50 on top) is OK?
        Can I see the pictures of the whole board, both sides? That MOSFET looks like it is used for PWM for variable B+ feeding the the MOSFETs that drive the Royer Oscillator circuit.
        • spidey
          climbs
          • Dec 2012
          • 644
          • Cyprus
          just replace that inverter with a universal one.
          • rawdr
            • 5
            Thanks for the quick responses, guys. I uploaded more complete pictures... yes F1 is still passing current.
            Any tips on the important characteristics to match for a more modern replacement? 2SK1472 doesn't seem widely available - I'd rather get a newer equivalent.
            Thanks again.
            • jetadm123
              • 2169
              ON Semiconductor shows a NTD3055-094 as a possible sub.
              • thesame
                DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                by thesame
                Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                02-27-2024, 04:31 AM
              • boosti45
                Macbook pro logic board replacement parts quesion
                by boosti45
                i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                08-21-2024, 05:23 AM
              • jdbird613
                Power Inverter Replacement Circuit Board Question?
                by jdbird613
                So my Ampeak 2000 watt power inverter will receive power from a 12 volt source, and also has a display screen that displays how many volts the inverter is currently using...However, the plug outputs are not producing any power outward...The display screen on the inverter also shows how many volts an item that is plugged in is currently using...Which stays at 0 and no items will power on...I opened the inverter casing and discovered there is some charring and burned areas on one end of the circuit board...What I am trying to figure out is if I can purchase/obtain a new board exactly like the board...
                02-27-2020, 08:37 AM
              • tuner2000i
                Philips 65PUS8518/12 distorted image after main board replacement
                by tuner2000i
                hello everyone,
                I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                07-15-2025, 01:15 PM
