iiyama e2202wsv prolite, stop after 5 sec
  • perette
    • Mar 2013
    • 71
    • france
    Hi everybody
    I have a problem that seems to be common on this monitor (same as a adepia tgl 2020 (service manual there) and AOC TFT22W90PS, plus many other)
    The screen powers on, display a "no cable" if no cable connected and then turn to black with the led to orange. And if i push the power button, it switches of and can restart doing the same again. I do not see any image.
    I haven't find a usable answer on the web (maybe I'm not searching the right way), I ask your help to try to resurrect the monitor.
    I've suspected the PSU (715g2510-1) but no caps damaged (visibly), not trace of burn.
    I've tried to test some key components (as recommended in a previous subject there)
    What can i try to find were the problem comes from.
    thanks (PS, I can play with it only the week end, so this can take a little time)
  • RethoricalCheese
    • Mar 2013
    • 1517
    • Estonia
    Re: iiyama e2202wsv prolite, stop after 5 sec
    For me it seems like controllerboard (where the input cable connects to) is problematic.
    Some say that adding a resistor somewhere could help.
    Maybe someone smarter than me knows where to put that resistor and what the resistance should be.
    • perette
      • Mar 2013
      • 71
      • france
      hi the boss
      looking at the service manual of the adepia TGL 2020A (a clone of the iiyama) they explain that it can be the main board (folowing your recommendation).
      I've tried to test it according to it, but getting no clues on it.
      the board s a 715G2573-2.
      I got a OSD message when switching it on (different message if a cable is or not connected), but a off (and orange led) after 5 seconds.
      if putting a resistor can help to decide if it's dead or not...
        It sounds like SAMSUNG with EEPROM problem, see if you have this EEPROM on your main (logic) board.
        https://www.badcaps.net/forum/showth...155#post246155
        • perette
          • Mar 2013
          • 71
          • france
          Hi Budm
          I see your idea.
          Maybe yes, the same issue.
          The "main board" is a 715G2573-1.
          I've got one from a 19" screen but a version -2, and it does not work on the 22" I have.
          its behavior is the same (goes to orange led after 5 sec), but no OSD message. the short time when the screen is on shows white background and some vertical stripes. the eeprom on the board contains another code I guess made for the 19".
          But all components are the same so..
          Now on the 715G2573, the eeprom is not he same as the one you mentionned.
          So I cannot try the same solution.
          I'm still puzzled between the main board "saying" that there is no signal ans switching the power board off and a bad feedback to the system that switches it off for protection.
          • perette
            • Mar 2013
            • 71
            • france
            Hi everybody.
            actual status : I've changed all caps on the power supply. even if not visibly damaged.
            outcome : now I see a picture on the screen and it does not go to stand by (orange led).
            BUT the backlight turns off after 2 seconds
            As I've changed all caps (low esr ones), I've check CCFl tubes, but none is dead.
            On the back of the board to IC labelled 9945 AA7LDA seems to had some heat traces around. could this be the reason of the 2 secand to black?
            any expert adive?
            thanks.
            • selldoor
              Slow Learner
              • 7870
              Originally posted by perette
              any expert adive?
              thanks.
              Hi - read it as any expert aLive
              Figure you mean advice, not that I am an expert.
              When the picture goes black can you still make out what should be on the screen perhaps shining a flashlight on it? - Set it up with a vivid picture that you can easily recognise. and when it goes black does the standby stay green.
              • perette
                • Mar 2013
                • 71
                • france
                Hi Selldoor
                Oups, little keyboard failure..
                Yes of course, advice is better.
                The image is visible on the screen, it's only the backlight that goes of.
                the led remain blue (not green on this one).
                To help on the heated components. here's a picture of the unit.
                Q802 and Q803 are surrounded by heat traces (both side of the board)
                thanks
                P.
                • selldoor
                  Slow Learner
                  • 7870
                  They do run hot - but may be ok.
                  Have you checked the Inverter transformers Secondary Windings ( Large black Rectangles)
                  On the bottom board picture one is at the top right has six pins on one end and pins 7 and 8 on the other end. Set your multimeter on ohms 2000 and test across those pins 7 & 8 on both transformers.
                  • perette
                    • Mar 2013
                    • 71
                    • france
                    467 on one, 465 on the second one.
                    looks like it's not there.
                    P.
                    • selldoor
                      Slow Learner
                      • 7870
                      Near q802 there is a label F801 That suggests a fuse but it is a zero resistor.
                      Can you test it - meter on ohms 200 There is another jr802 may as well test that as well
                      • perette
                        • Mar 2013
                        • 71
                        • france
                        displays a zero resistance.
                        the multimeter I have is a bit short to read low resistance values.
                        PS : (if it helps) the schematic of the board can be found in my first post pages 26-27. different monitor brand, but same board.
                        P.
                        • selldoor
                          Slow Learner
                          • 7870
                          0.00 is good - same as putting the probes together?
                          I have to go out for an hour or so but will look at the scheme later.
                          Does the scheme have the part numbers of the q 802/3 you mentioned if not can you post
                          a close up picture clear enough for me to read the numbers. (I cant find anything for the number you quoted)
                          • perette
                            • Mar 2013
                            • 71
                            • france
                            hi Selldoor
                            Thanks for you help, there is no emergency.
                            I've attached schematics and a list of components.
                            I can just mention that, when I see the image and backlight is on, the backlight is not really powerfull (same as the spare CCFL I've used to test).
                            best
                            P.
                            • selldoor
                              Slow Learner
                              • 7870
                              Ok the q802/3 mosfets are AM9945N data sheet here
                              http://www.analogpowerinc.com/datash...=DS_AM9945N_F1
                              A quick test for shorts is in this guide by retiredcaps
                              https://www.badcaps.net/forum/showthread.php?t=10419 start at post 19 -power off for tests.
                              • perette
                                • Mar 2013
                                • 71
                                • france
                                Hello selldoor
                                I'll test it probably tomorrow.
                                thanks a lot
                                P.
                                • mikey5791
                                  Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
                                  by mikey5791
                                  Got this working ips led monitor by the brand of
                                  Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
                                  Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
                                  09-04-2023, 03:50 AM
                                • wattage
                                  AOC AG493UCX 49-inch monitor - Firmware request
                                  by wattage
                                  Hello Badcaps Community,
                                  The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                  Yesterday, 04:41 PM
                                • ant3202
                                  HP 27es - LED monitor - Monitor Flashing On - Off
                                  by ant3202
                                  Hi Everyone
                                  Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                  https://www.badcaps.net/forum/troubl...lashing-on-off
                                  The monitor is HP 27es LED Monitor
                                  https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                  The monitor will randomly blackout and display no signal and will recover again.
                                  Sometimes need to power and off again to restore the display but...
                                  03-20-2025, 07:30 PM
                                • Rick_1234
                                  LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                  by Rick_1234
                                  Good evening, gentlemen.
                                  I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                  To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                  https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                  Things I tried
                                  - Bought a new AC adapter thinking that was the problem but the problem...
                                  06-22-2024, 04:44 PM
                                  Wise Wing F199 19'' LCD monitor - recapped
                                  by momaka
                                  Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                  I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                  When I saw the Craigslist post, I wasn't...
                                  08-24-2020, 10:58 AM
