Dell 1707FPt No Power
Re: Dell 1707FPt No Power
The only time I have heard KY fail is in the infamous Hanns-G 28 inch monitor. That monitor runs temperature hot and bakes all the caps on the power and main board.
My "downstairs" computer has an used Corsair PSU with KY caps inside.--- begin sig file ---
--- end sig file ---Comment
Connected boards together, AC power connected, my 5.25vdc fell like a rock to zero. Took them back apart, powered up, got the 5.25v, then it started falling to zero like in the beginning. What next?Comment
Well, either something is dragging down the 5V or something is failing, but not outright failed.
You could try replacing the caps, but I don't know if that will fix it.
I spent 20 months tracking down a shorted 5V rail. See
https://www.badcaps.net/forum/showthread.php?p=114994--- begin sig file ---
budm Re:
Please test Q107, 108.
What does D802 do? Markings are U4K8 80R K468. When my voltage is steady at output pin, I can track 123vac from power cord connector to this rectifer (I think that is what it is), beyond it I get 185v (I assume it's ac). When the 5.25v output starts droping, this voltage also drops, to like 75v, also the voltage across the large filter cap drops to 48-50 volts. Am I on to anything here.Comment
It is a bridge rectifier.
http://en.wikipedia.org/wiki/Diode_bridge
All your measurements at the bridge rectifier should be DC volts. When you are on the hot side of the power supply, the negative leg of the large filter capacitor is ground.
Bridge rectifiers, when not working, are usually shorted and will blow the fuse right away.--- begin sig file ---
Budm
Test on Q108,""""""""""""""""""""""""""""""", pins 1 thru 4, all = 1610ohmComment
"When the 5.25v output starts droping, this voltage also drops, to like 75v, also the voltage across the large filter cap drops to 48-50 volts. Am I on to anything here."
Is the voltage on the large cap being measured right at the two legs of the cap? Fot it to drop that much, the load has to be tremendous which should have blown the main fuse, that large cap should be able to hold staedy since the inverter is not even running. The voltage on that cap should be around 165~170vdc.Never stop learning
Is my mosfett bad Q107?Comment
I expect that large cap top be bad, if it is is bad MOSFET that draws too much curent, it will be either shorted out or not switching, but it is able to drive the transformer to produce 5v out put, it means it is swithcing but the 168V power supply is not steady to supply the constant voltage.
Is your meter True R.M.S? If it is, put it in AC mode and measure AC ripple voltage on the two legs of that large cap.Last edited by budm; 02-08-2013, 03:22 PM.Never stop learning
Is your meter True R.M.S? If it is, put it in AC mode and measure AC ripple voltage on the two legs of that large cap.Comment
OK, so now the 5V is steady and the 168v is also steady, then it is OK, you had indicated that it was dropping like a rock. Now we need to find out if you do have 12~18vdc feeding the inverter section or not. Check the voltage on jumper J117 (or on C811 LEGS) and ground to see what you have.Never stop learning
OK, so now the 5V is steady and the 168v is also steady, then it is OK, you had indicated that it was dropping like a rock. Now we need to find out if you do have 12~18vdc feeding the inverter section or not. Check the voltage on jumper J117 (or on C811 LEGS) and ground to see what you have.Comment
I need to know if we do have B+ for the inverter circuit first.Never stop learning
I fixed a Dell 19 inch once by simplying reflowing the solder joints at the AC plug.
Do more testing before changing out the caps. As I said before United Chemi-con KY and Rubycon are generally good caps.--- begin sig file ---
I made a mistake on this report, those reading were 1715 ohm & 1710 ohm. Q107 is not a good reading, right.Comment
At least now we know we have steady but voltage for the inverter seems high for 17" monitor. But at this point we need to get your main board working again. I would retrace your works to find out what happen now that you have no control, no LED.Never stop learning
I haven't done anything to it for a few hours. When I tried to turn it off earlier, it wounld't power off, I had to ulplug it. Now it won't turn back on. May be a button think as all voltages are steady with boards connected.Comment
Assuming...7 Photos -
by PantherDaveHi all!
I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. π
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by Mark01Hi guys,
This is my first post! π
I have no idea what Iβm doing, but Iβm learning by trial and error.
Iβm currently working on a Dell Optiplex AIO 7490βone of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...07-04-2025, 12:54 PM -
by zlr8rhey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
Ill try and give as much info as I can.
Dell Inspiron 17 (7786) Laptop
Service Tag: 5J0NHT2
Bios: 1.9.0
When I received this , it would only flicker on the KB backlight for a second, then off and on.
Then it started getting weirder!
Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has... -
by seppdeHello everyone,
I've recently gotten my hands on a defective XPS13 9380. I will attach a zip of the schematics and boardview.
My first discovery on the Board was that the reverse current Diode PD103 of the 1st USB-C was blown.
Nothing to worry about, the board got 3 USB-C ports which support Power/Charging. On I go.
Next I inspected the power-rails to see why the diode blew up and found a short on the 3V3 rail which I traced back to the Power-IC for the LCD (UZ2). I desoldered it and the very low-ohmic short is gone. I checked on the LCD-connector that there's no short... - Loading...
