Dell 1707FPt No Power
  • maybenever
    • Dec 2010
    • 158
    Re: Dell 1707FPt No Power
    Update, I was in the hospital a few days, out now. I didn't get the time to cross check all the voltages on the working & non-working logic boards. I did get it all back together and it works fine. I saved 5 monitors from the trash, repaired 4 by replacing bad caps, this Dell by replacing boards, and scrapped a 19” Proview for parts. I really wanted to get this Dell repaired because I'm remolding a roll top desk, & it's adjustable height will allow me to close the roll top to hide the clutter.
    I learned a lot chasing voltage around this Dell board, maybe I'm one notch above “just a cap replacer” for it. You guys do an assume job and spend a lot of time helping everybody with their problems. I'll still be reading and learning, I just have a different project on the bench right now. Thanks to all.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • Mark01
      Dell Optiplex 7490 AIO - red power led after flash
      by Mark01
      Hi guys,
      This is my first post! 🚀
      I have no idea what I’m doing, but I’m learning by trial and error.
      I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
      07-04-2025, 12:54 PM
    • zlr8r
      Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
      by zlr8r
      hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
      Ill try and give as much info as I can.
      Dell Inspiron 17 (7786) Laptop
      Service Tag: 5J0NHT2
      Bios: 1.9.0
      When I received this , it would only flicker on the KB backlight for a second, then off and on.
      Then it started getting weirder!
      Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
      12-12-2023, 09:31 PM
    • LimesKey
      Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
      by LimesKey
      Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
      10-17-2025, 05:33 PM
