Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
  • LimesKey
    • Oct 2025
    • 5
    Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely not an issue with the battery; the battery connector on the motherboard shows the correct voltage (~19v) during the no power state. The laptop also does not turn on when plugging in an AC power cable with the battery disconnected.
    I believe it's likely something to do with a FET not turning off completely and/or something with the power regulation chip. I've done some research, and it seems to be a relatively common problem on the 7000 series line of Inspiron laptops; however, there are very few fixes available. This Reddit post, and more specifically the comment, seemed to describe my exact problem, but their fix did not work for me. For additional context, I've had the laptop for about 3 or 4 years now, and in that time I've replaced the battery and upgraded the RAM & SSD. Physically, there is nothing wrong with the laptop due to damage/drops.
    Let me know what I should try or what the next steps will be. I have good general electronics knowledge and access to a good multimeter, oscilloscope, and SMD soldering station, but I'm not experienced with laptop repair specifically. To make it easier, here's the link to the board schematic I found on another Badcaps thread.
  • LimesKey
    • Oct 2025
    • 5
    Bump
    • Andreasbest
      HP LA-H32AP motherboard power on for 5 secs
      by Andreasbest
      Hello.
      Received a LA-H32AP motherboard with AMD cpu, only reaction is the power led (LED1) that lights up for 5 secs, nothing else.
      Summary↓
      The laptop was working normally the previous day.
      When pressing the power button, LED1 (Power LED) turns on for a few seconds and then turns off. The motherboard does not boot.
      Some power rails remain active for several seconds after LED1 turns off.
      Troubleshooting already performed:
      • Tested different RAM modules.
      • Tested without RAM.
      • Tested again with RAM installed — exactly the same behavior.
      • Removed
      10-19-2026, 03:11 PM
    • calebtree33
      Nitro 5 AN515-58 Power Up Sequence Failure
      by calebtree33
      Device: Acer Nitro 5 AN515-58-5046
      Board: LA-L973P HH514
      Context: I bought this from a guy hoping to fix it and resell it as I am learning motherboard repair. He said that the laptop would start powering up, fans would spin, and keyboard backlight would turn on. When the screen turned on, the time was wrong. Eventually it stopped turning on altogether. I am confused as to how this could be a gradual failure.
      Problem: When pressing the power button the LED showed for about 5 seconds before shutting off. The laptop would charge with the charging light. I cannot find...
      09-24-2026, 08:18 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • Scaff
      Dell Inspiron 7506 2-in-1 HELLCAT 19859-1 - No power
      by Scaff
      I've had trouble with the power on this device since I got it. It always shut down with no warning and would often fail to power up. Dell's advice has been to disconnect the power and battery, wait, then reconnect and boot. Letting the battery run down completely also helped. I had them come out at one point and they said they replaced the board. This helped for a while but then it just stopped powering on. At this point it's well out of warranty. I missed the chance to get them to come out again because life. Current situation is it shows zero signs of life with both barrel...
      06-08-2025, 01:46 AM
