Dell Monitor blinking LED
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell Monitor blinking LED
    See if picofuse PF751 (right above the big filter cap) is blown after you replaced the c5707s.
    See if Q743 and Q751 are shorted. These may the FU9024s I refered to as per post #18 and post #2 by UniT3d.
    If the above are all good, then you will have to check the main board and make sure that BL_ON is > 3.0V DC.
    --- begin sig file ---
    --- end sig file ---
    • Lumberjack777
      • 464
      Yes. I have fixed about 7 of these: and in most cases it was the c5707's. But, in one instance it was the FU9024. And once it also had a blown picofuse. I'm betting its one of those FU9024's you mentioned.
      • selldoor
        Slow Learner
        • 7870
        Originally posted by Pentium4
        I replaced those transistors, replaced all the caps, and re-soldered all the joints of the 4 inverter transformers. Now it will turn on but I have to use a flashlight to see a picture. Could one of the inverters be bad?
        Does the screen flash at all when you switch on?
        If it does then it could be one of the transformers though they dont often fail on this
        board - meter on 2000ohms check the secondary windings ( Think it is the two pins on one end there are 3 but 2 are conneted)
        • Rtech
          • Jul 2010
          • 1095
          On many occasions,when one of the Fu9024s go short,you get a situation where the screen is totally white when you apply Power WITHOUT the On button being pressed, and then it works normally when the On button is pressed.If they test good I suspect one of the CCFLs has failed.
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Thank you very much for the replies PF751 is good
            Testing between pins C and E on Q743 and Q751, they are both shorted
            When it first turns on I don't get a flash at all
            • retiredcaps
              • Apr 2010
              • 9271
              #26
              Capking sells the fu9024 (post #18). I would get a few for future Benq boards.
                That fu9024 is driven by the PWM IC, the output is Variable DC depends on the pulse width of the drive signal from the PWM IC, the wider the width the more DC feeding the Royer Oscillator, the brighter the lamps get, if the fu9024 has shorted Source to Drain, the Oscillator will run at full power (max DC feeding the oscillator, max LAMP brightness) as explained by RTECH.
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Interesting I ordered 10 of those FU9024N's, hopefully it will fix the issue!
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    Okay so I replaced both of those FU9024N's and it's still having the same issue. Not even a brief flash when it powers up
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #30
                      What are the DC voltages on the connector between the power and main board?
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        I know, I suck with paint
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #32
                          Verify that you have DC voltage on pf751 (both sides) wrt to cold ground. What is reading for both?
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            I'm only getting 0.0125V on both sides of PF751
                            • Pentium4
                              CapXon Be Gone
                              • Sep 2011
                              • 3741
                              I'm not sure if it means anything but R615 reads 0.4Ω both ways and all the other resistors around it get an actual reading (Around 70-100Ω)
                              • selldoor
                                Slow Learner
                                • 7870
                                #35
                                You usually have to lift one leg of a resistor to check it properly.
                                The measured resistance should equate to the the colour bands.
                                http://www.hobby-hour.com/electronic...calculator.php
                                • Pentium4
                                  CapXon Be Gone
                                  • Sep 2011
                                  • 3741
                                  Ohhh okay thank you. It's a 0.22Ω resistor
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #37
                                    What is the DC voltage for each of the three ICs mounted on the heatsinks in the upper right hand corner?
                                    Report each pin (BCE) with respect to ground.
                                    • Rtech
                                      • Jul 2010
                                      • 1095
                                      #38
                                      You show you are getting 3v and 5v,so the only thing missing is the 12v,which feeds the Inverter via the PF751.This is rectified by D701,which is a Schottky,and you should be able to measure it across C703,C704 and C712.
                                      • Pentium4
                                        CapXon Be Gone
                                        • Sep 2011
                                        • 3741
                                        Thanks for the persistent replies! Here are the readings
                                        E = 0.00V
                                        C = 17.26V
                                        B = 0.00V
                                        B = 0.00V
                                        C = 5.00V
                                        E = 0.00V
                                        1 = 2.12V
                                        2 = 0.00V
                                        3 = 3.30V
                                        4 = 5.00V
                                        I will check those other pins too and see what I get!
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #40
                                          E = 0.00V
                                          C = 17.26V
                                          B = 0.00V
                                          So the 12V is there. That 17.26V is unregulated and should drop down once the backlights are on.
                                          Let's confirm you are measuring the DC voltage on the picofuse correctly.
                                          1) Put your black probe on a ground screwn.
                                          2) Put your red probe on one side of the picofuse? What is this reading?
                                          3) Put your red probe on the other side of the picofuse? What is this reading?
                                          • Borse2008
                                            Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                            by Borse2008
                                            Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                            I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                            • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                            • There’s
                                            07-15-2025, 04:55 AM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • DanPoka
                                            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                            by DanPoka
                                            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                            02-15-2025, 05:05 AM
                                          • artvandalai
                                            Help identifying voltage regulator on this concept 2 pm5 monitor pcb board?
                                            by artvandalai
                                            This Concept 2 rower pm5 monitor doesn't shut down. It keeps turning on and stays on after being turned off. I read on another forum by another user that replaced the same component to check the voltage regulator.
                                            The monitor should pull around 35mA when turned on and in shutdown it should drops to around 0.060mA. Any advice on finding the voltage regulator on this board to check if it needs to be replaced?
                                            11-05-2024, 07:38 AM
                                          • Jesus Coder
                                            Issues Reviving Old Dell 2408WFPb Monitor
                                            by Jesus Coder
                                            I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                                            06-25-2023, 02:33 PM
