LG Flatron L204WS
    Re: LG Flatron L204WS
    No it does not smell burnt. let me take the picture...
      this is the best that i can take...
        HaHa we generally refer to that as the bottom of the board
          sorry my mistake.
            Hmm - no fuses or anything obvious with it all connected and switched on
            can you test what I think may be two voltage regulators.- bottom left of the pic. ( Pictures are improving )
            Read this, by retiredcaps, on how to test. The bigger one if you post the part number I will check it is a regulator - or you can.
            https://www.badcaps.net/forum/showthread.php?p=261329
            EDIT looks like 1117F 18 xxx which means it is a 1.8v regulator
              will do and get back to you
                Voltage Regulator Test 1:
                Model:
                KIA
                1117F
                18738
                Results:
                Pin 1 -> ranging -1.8 to +1.92
                Pin 2 -> ranging -1.8 to +1.89
                Pin 3-> ranging -1.8 to +1.91
                Voltage Regulator Test 2:
                Model:
                EH16A
                714J92
                Results:
                Pin 1 -> ranging -1.8 to +1.89
                Pin 2 -> ranging -1.68 to +1.81
                Pin 3-> ranging -1.86 to +1.83
                  Well at least we have some voltages!! they should however be STEADY at 1.8.
                  hence the term regulator
                  Wonder if your meter batteries are ok - been getting a lot of work?
                  As there are only 3 caps on the board - Sam Young? - not great! perhaps change them.
                    Hmmmm it has a 9v battery and i dont use it very often. Ill replace the caps and report again. So does it mean that the regulators are bad?
                      Not certain - they generally fail by producing a steady but incorrect voltage
                      or no voltage at all. I know that having a failing cap connected to a VR can
                      produce bad results - I would hope that they are ok and see what replacement caps do. What we need to find is more voltages. A couple of things to try would be test the connector pins on the power supply without the main board connected. Also and you will need to be careful check the voltage on the start up cap - at one point I though it was a bit rounded but then decided it was just the picture. It is a 50v one between the heatsink and the yellow transformer. So you will need power on and meter on v200dc -obviously it should not be more than 50vdc you can measure topside if you can get at it or underneath. Set it all up so you can measure then switch it on careful not to touch the BIG caps.
                        The cap that is between the heatsink and the yellow transformer is supposed to be 50v 33uF and when tested it is ranging between 9.5 to 14.3V. Well I guess it's a bad cap. Can the cap be replaced with a different one as I don't have one that type of uF.
                        I will do the other tests soon...
                          can a 16v 100uF cap be replaced with a 25v 220uF cap?
                          Can you please tell me how to know if a bigger uF is good or not?
                            It depends on how it is used, if it is used for timing circuits, then No. If it is used for simple filter cap, then you can use it for now just for testing the function of the circuit.
                            Higher voltage is OK to use as long as the body still fit the board since higher voltage cap will be bigger than the lower voltage cap with the same capacitance rating.
                              So can this cap be replaced with something else?
                                I believe you could use a 50v 47uf 50v68uf
                                25v 33uf 25v47uf 25v68uf
                                Perhaps even higher u rating for testing but not lower than 25v and not lower than 33uf
                                  i do have 50v 47uf cause u do have that. will try it and keep you posted
                                    i've replaced the cap and it gave me the same results as the old one + i got a shock hehe. well having the same results was not worth the shock
                                      Good to get a few jolts early in your introduction to electronics- makes you more careful
                                      if not dead Perhaps use an RCD device.?
                                      Pity it didnt help - back to the drawing board - when you say same result do you mean the
                                      varying voltage on the cap? At least its another voltage.
                                      Can you check the voltage across the two big resistors on the main board.
                                      Perhaps also test the resistance - Power OFF meter on ohms ???
                                      Type in Hobby Resistance into your browser and you will find a site that
                                      gives you the resistance colour band guide.See on there what resistance to expect and set your meter range accordingly.
                                        yeah we do have an rcd device in our house but it was only a small shock hehe. i meant same voltage results for the cap as it was before.
                                        may i ask which resistors? yeah i know im a little bit of a headache but i'm new to electronics hehe
                                          The Big Blue Bodied ones
