LG Flatron L204WS
+ More Options
Posts
  • matthmal
    • Nov 2012
    • 306
    • Malta
    #81
    Re: LG Flatron L204WS
    basically i'm trying to learn and it is costing me to buy unfixable monitors/tvs.
    better not buying it then.
    If you had to buy monitors and tvs with which particular symptom would you buy them and at what price?
    • matthmal
      • Nov 2012
      • 306
      • Malta
      #82
      ok so forget about the monitor, is there any possibility of at least fixing anything of the three other TFT's?
      • corrize
        A funny fuse story – Lumix LX100 II
        by corrize
        Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
        I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
        The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
        There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
        And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
        10-19-2023, 09:58 AM
      • jesterace
        Samsung UE46ES8000 Blown fuse but no other signs of short
        by jesterace
        Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
        09-11-2024, 03:14 PM
      • jshhh
        Help replacing fuse on my Mimaki CJV300-160 vinyl printer
        by jshhh
        Hi guys,
        I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
        How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
        Anybody know how to remove this type of fuse?
        (The fuse is toward the bottom of the image labeled F2)...
        06-17-2025, 01:35 AM
      • Babbar
        by Babbar
        04-12-2024, 01:12 AM
      • drykid
        Matsui 175S microwave fuse replacement
        by drykid
        I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
        Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
        12-21-2020, 01:15 PM
