LG Flatron L204WS
  • matthmal
    • Nov 2012
    • 306
    • Malta
    #41
    Re: LG Flatron L204WS
    No it does not smell burnt. let me take the picture...
    • matthmal
      • Nov 2012
      • 306
      • Malta
      #42
      this is the best that i can take...
      • selldoor
        Slow Learner
        • 7870
        #43
        HaHa we generally refer to that as the bottom of the board
        • matthmal
          • Nov 2012
          • 306
          • Malta
          #44
          sorry my mistake.
          • selldoor
            Slow Learner
            • 7870
            #45
            Hmm - no fuses or anything obvious with it all connected and switched on
            can you test what I think may be two voltage regulators.- bottom left of the pic. ( Pictures are improving )
            Read this, by retiredcaps, on how to test. The bigger one if you post the part number I will check it is a regulator - or you can.
            https://www.badcaps.net/forum/showthread.php?p=261329
            EDIT looks like 1117F 18 xxx which means it is a 1.8v regulator
            • matthmal
              • Nov 2012
              • 306
              • Malta
              #46
              will do and get back to you
              • matthmal
                • Nov 2012
                • 306
                • Malta
                #47
                Voltage Regulator Test 1:
                Model:
                KIA
                1117F
                18738
                Results:
                Pin 1 -> ranging -1.8 to +1.92
                Pin 2 -> ranging -1.8 to +1.89
                Pin 3-> ranging -1.8 to +1.91
                Voltage Regulator Test 2:
                Model:
                EH16A
                714J92
                Results:
                Pin 1 -> ranging -1.8 to +1.89
                Pin 2 -> ranging -1.68 to +1.81
                Pin 3-> ranging -1.86 to +1.83
                • selldoor
                  Slow Learner
                  • 7870
                  #48
                  Well at least we have some voltages!! they should however be STEADY at 1.8.
                  hence the term regulator
                  Wonder if your meter batteries are ok - been getting a lot of work?
                  As there are only 3 caps on the board - Sam Young? - not great! perhaps change them.
                  • matthmal
                    • Nov 2012
                    • 306
                    • Malta
                    #49
                    Hmmmm it has a 9v battery and i dont use it very often. Ill replace the caps and report again. So does it mean that the regulators are bad?
                    • selldoor
                      Slow Learner
                      • 7870
                      #50
                      Not certain - they generally fail by producing a steady but incorrect voltage
                      or no voltage at all. I know that having a failing cap connected to a VR can
                      produce bad results - I would hope that they are ok and see what replacement caps do. What we need to find is more voltages. A couple of things to try would be test the connector pins on the power supply without the main board connected. Also and you will need to be careful check the voltage on the start up cap - at one point I though it was a bit rounded but then decided it was just the picture. It is a 50v one between the heatsink and the yellow transformer. So you will need power on and meter on v200dc -obviously it should not be more than 50vdc you can measure topside if you can get at it or underneath. Set it all up so you can measure then switch it on careful not to touch the BIG caps.
                      • matthmal
                        • Nov 2012
                        • 306
                        • Malta
                        #51
                        The cap that is between the heatsink and the yellow transformer is supposed to be 50v 33uF and when tested it is ranging between 9.5 to 14.3V. Well I guess it's a bad cap. Can the cap be replaced with a different one as I don't have one that type of uF.
                        I will do the other tests soon...
                        • matthmal
                          • Nov 2012
                          • 306
                          • Malta
                          #52
                          can a 16v 100uF cap be replaced with a 25v 220uF cap?
                          Can you please tell me how to know if a bigger uF is good or not?
                            It depends on how it is used, if it is used for timing circuits, then No. If it is used for simple filter cap, then you can use it for now just for testing the function of the circuit.
                            Higher voltage is OK to use as long as the body still fit the board since higher voltage cap will be bigger than the lower voltage cap with the same capacitance rating.
                            • matthmal
                              • Nov 2012
                              • 306
                              • Malta
                              #54
                              So can this cap be replaced with something else?
                              • selldoor
                                Slow Learner
                                • 7870
                                #55
                                I believe you could use a 50v 47uf 50v68uf
                                25v 33uf 25v47uf 25v68uf
                                Perhaps even higher u rating for testing but not lower than 25v and not lower than 33uf
                                • matthmal
                                  • Nov 2012
                                  • 306
                                  • Malta
                                  #56
                                  i do have 50v 47uf cause u do have that. will try it and keep you posted
                                  • matthmal
                                    • Nov 2012
                                    • 306
                                    • Malta
                                    #57
                                    i've replaced the cap and it gave me the same results as the old one + i got a shock hehe. well having the same results was not worth the shock
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      #58
                                      Good to get a few jolts early in your introduction to electronics- makes you more careful
                                      if not dead Perhaps use an RCD device.?
                                      Pity it didnt help - back to the drawing board - when you say same result do you mean the
                                      varying voltage on the cap? At least its another voltage.
                                      Can you check the voltage across the two big resistors on the main board.
                                      Perhaps also test the resistance - Power OFF meter on ohms ???
                                      Type in Hobby Resistance into your browser and you will find a site that
                                      gives you the resistance colour band guide.See on there what resistance to expect and set your meter range accordingly.
                                      • matthmal
                                        • Nov 2012
                                        • 306
                                        • Malta
                                        #59
                                        yeah we do have an rcd device in our house but it was only a small shock hehe. i meant same voltage results for the cap as it was before.
                                        may i ask which resistors? yeah i know im a little bit of a headache but i'm new to electronics hehe
                                        • selldoor
                                          Slow Learner
                                          • 7870
                                          #60
                                          The Big Blue Bodied ones
                                          • corrize
                                            A funny fuse story – Lumix LX100 II
                                            by corrize
                                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                            10-19-2023, 09:58 AM
                                          • jesterace
                                            Samsung UE46ES8000 Blown fuse but no other signs of short
                                            by jesterace
                                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                            09-11-2024, 03:14 PM
                                          • jshhh
                                            Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                            by jshhh
                                            Hi guys,
                                            I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                            How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                            Anybody know how to remove this type of fuse?
                                            (The fuse is toward the bottom of the image labeled F2)...
                                            06-17-2025, 01:35 AM
                                          • Babbar
                                            by Babbar
                                            04-12-2024, 01:12 AM
                                          • drykid
                                            Matsui 175S microwave fuse replacement
                                            by drykid
                                            I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
                                            Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
                                            12-21-2020, 01:15 PM
