This is a 19 " HP which powers on OK but the backlights will not light. I tested these lights and they test OK I replaced all the cap on the power board with same results. I am looking at retiredcaps sticky and am thinking that it may be a transistor but I am rather intimidated by these because I am not sure how to identify them for example how can one determine the start/stop transistor? The signalling transistors? etc. This board has quite a number components with the Q designation but look different. Some has E,C,B and some has S,G,D and than there are some with 8 contacts like the 2 (P607 BD5A18)
HP no backlight
Re: HP no backlight
P607 datasheet
http://pdf1.alldatasheet.com/datashe...D/AOP607L.html
Measure to see if S1-G1, S1-D1 and D1-G1 are shorted. Do the same for the "2s" and report your readings.--- begin sig file ---
--- end sig file --- -
Re: HP no backlight
Thanks retiredcaps assuming pin 1 is indicated with a dimple the readings are as follows
Q 104
S1-G1-30 m ohms
S1- D1- 4 M Ohms
G1-D1- 0L
S2-G2-69 M OHMS
S2-D2-0L
G2-D2-0L
Q105
S1-G1-29 M Ohm
S1-D1- 20 M Ohm
G1-D1- 0L
S2-G2-38 M Ohm
S2- D2-0L
G2-D2-0L
where I get a reading the reading is continually decreasing?Last edited by davg; 11-02-2012, 04:01 PM.Comment
Re: HP no backlight
None of those mosfets are shorted.
On the connector to the main/logic board (which is cut off in the picture), is there a legend? If yes, is there a pin that says BL_ON or something. The main board generates the BL_ON and it should be > 2.0V DC.--- begin sig file ---
--- end sig file ---Comment
Re: HP no backlight
Yes there is as follows BRL ON_OFF, +5 volts, +5 volts, GND, GND, GND, +12 Volts. The voltages on these pins read 1.57v, 0v, 5.22v, 5.22v, 0v, 0v, 0v, 12.24v. You say non of these mosfets are shorted!! what kind of readings would I get if they were? (just learning)Comment
Re: HP no backlight
What is the model number of this HP? Can you zoom out a little bit so I can see the whole board, both sides? By the way, do you see the lights even flash on at all?Last edited by budm; 11-02-2012, 07:58 PM.Never stop learning
Re: HP no backlight
ON_OFF = 0V
I'm not 100% sure if BRL is backlight. The "R" is confusing me. Additionally, ON_OFF could be the backlight on/off command.
I define a short as anything less than 30 ohms. AFAIK, there is no industry agreed upon value.--- begin sig file ---
Re: HP no backlight
The model # is HP-VS17 I will upload pictures in the morning. I have it apart now but I can't be sure if it flashes or not but if it does its quicker than the eye. When plugged in the blue power light comes on than goes to amber. I don;t see any flash of the backlights but I can see the image with a bright light.Comment
Re: HP no backlight
On closer look that BRL is actually BRI ON_OFF if that makes any sense??. So is that 1.57v within tolerances for the ON pin? Is the 0V correct for the OFF pin? All others seem OKComment
Re: HP no backlight
BRI is brightness. ON_OFF, then, is your backlight on/off. It is 0V, then the main/logic board is not generating it.
Check the voltage regulators on the main/logic board. My sig file has a how to guide.--- begin sig file ---
Re: HP no backlight
Post a picture of the main board as well.--- begin sig file ---
Re: HP no backlight
Since the LED is AMBER, then that make sense why the ON_OFF is 0V. If the main board does not sense the video signal from the PC, it will turn off the inverter and the power to the LCD T-CON board. So check the regulators on the main board as suggested by retiredcaps.Never stop learning
Re: HP no backlight
Here are the pictures that budm requested and with the unit attached to a pc the blue light stays blue but there is no flash of the backlights at all. I am hearing a humming sound on the power board when everything is hooked up. Is this normal? I have to do some reading before I start testing the regulators.Comment
Re: HP no backlight
The readings on the two regulators I304 and I305 are as follows:
I304
AIC line 1
1084-33PM line 2
328GC line 3
pin #1- 0V
pin#2- 3.29v
pin#3- 4.9v
I305
1117 line#1
-18PE line#2
91OCT line#3
pin #1 - 0v
pin#2 - 1.79v
pin#3 - 3.29
pins numbered left to right with long pad northComment
Re: HP no backlight
Your voltage regulator readings look good. Here's what I think the problem is:
On your photo of the logic board, what is the part number for I308? It's the 3 terminal device right above the 10-wire wiring harness. If it's something like MAX809/810, then it's a reset controller. If yes, with power off, use your soldering iron to lift the VCC and RESET pins off the circuit board. Power up the monitor to see if you get an image. Note: failure of this controller has caused the same problem on various acer models.Comment
Re: HP no backlight
So when the LED turns blue with connection to running PC, do you now get >3VDC at the ON/OFF PIN? If you do, then we need to go back and troubleshoot the inverter circuits.Never stop learning
by triplefourthis tv is throwing me for a loop. do samsung tvs no longer have the backlight self test feature built into the power supply?
according to how ive diagnosed in the past, this would almost always be a bad power supply. replacement power supply was cheap like 20$ from ebay. but still i get not even... -
by DanPokaI bought this p2210f dell monitor to fix. Schematic is the same as p2210.
Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...-
by Comp_ProHello all,
Am trying to figure out this backlight issue with this A1990 Macbook Pro.
Tests performed:
There is no backlight even with a good screen.
Backlight IC is receiving the correct support voltages.
Fuse F8400 ok
Current sense resistor R8400 ok
Backlight IC is receiving 3.3V on enable pin.
Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
Backlight IC receiving 5V from PP5V_G3S
Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
I2C_BKLT_SCL and I2C_BKLT_SDA both measure... -
by cheebsterHello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
Anyone... -
by canadaboy25Hi all,
I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...-
- Loading...
