Viewsonic VA2010wb (flashing screen)
  • sabre504
    • May 2010
    • 449
    • United Kingdom
    Re: Viewsonic VA2010wb (flashing screen)
    Hi i will check that tomorrow am off to sleep gotta work in morn
    • sabre504
      • May 2010
      • 449
      • United Kingdom
      Hi yes it is i get continuity to all 4 corners
        That voltage for U3 input is generated by that U6 AAT1164 chip above that inductor, you can down load the spec of that chip and start checking the voltages on those pin.
        http://www.alldatasheet.com/datashee...164C-Q5-T.html
        • sabre504
          • May 2010
          • 449
          • United Kingdom
          Hi
          no power to U6 at all .
          On picture i have attached
          ZD1 is pulsing 0-3.1v
          ZD4 is pulsing 4.56-4.62v
          R24 is pulsing 4.56-4.62v
          Also rechecked the psu with no load 5v output is steady at 5.21v
          but in picture of psu the jumper ringed in green shows 11.8v no load but when connected to the screen it fluctuates betwwen 12.01 and 12.33v .
          Cannot borrow the supply i originally used to test as it appears it is not working so maybe my supply still has a fault so am going to change the
          dm0565r green mode power transistor (one of the few bits not been replaced yet ) and then go from there
          • selldoor
            Slow Learner
            • 7870
            Have you checked D5 and also R41 despite a number of people telling me no
            I am sure I once read that 0 rated resistors could be used as fuses.
            • selldoor
              Slow Learner
              • 7870
              #26
              While your at is are Tvs1 & 2 surge protection resistors - they seem to go in bigger versions stopping sets from working but allow it to work when they are removed.
              (dont really understand how that works)
              • sabre504
                • May 2010
                • 449
                • United Kingdom
                #27
                Hi Selldoor i have seen it once on a board in a TV 0ohm in F1 and it looked factory fit but i wouldnt like to argue the case .
                I will check those parts later when kids are in bed and i get some peace
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  If you find that R41 is still OK, try removing it, and see if the switching smps comes up to voltage.
                  Also, those mlcc's do go short sometimes, perhaps one of them (C47,48,49,50,51) is bad.
                  Muh-soggy-knee
                  • sabre504
                    • May 2010
                    • 449
                    • United Kingdom
                    #29
                    Pulled D5 off the board and measures ok .
                    R41 ok no difference when not in line to PSU .
                    C47-51 all measure the same so assume ok .
                    Changed dm0565r still the same issue .
                    The Tvs not sure what they are so just checked them on resistance and they all measure the same too .
                    Also reflowed the whole of the board just in case any bad joints .
                    I now have laid the whole thing out on my bench and connected it all together and have noticed that the inverter trans is buzzing in sync to the power going up and down ,whether that is because the power is fluctuating or thats whats causing it i am not sure.
                    • selldoor
                      Slow Learner
                      • 7870
                      #30
                      Still seems odd there is nothing in that whole area. I'd test R166 as a fuse then with the power on see what voltage was on every test point in that part of the board.
                      Did you diode test the two zeners.
                      • sabre504
                        • May 2010
                        • 449
                        • United Kingdom
                        #31
                        Hi all
                        well still not got any futher with this as had to put it to one side for a while .
                        Thought i would check all the ic chips but cant find any spec sheets for
                        U8
                        PS25LV010
                        EO553
                        CN1FJW
                        or U10
                        L32
                        6T74W
                        Wondered if anyone had an idea or dealt with them before
                        Other ic's i have if i need to replce them
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #32
                          PS25LV010
                          Likely serial flash.
                          http://www.alldatasheet.com/view.jsp?Searchword=25LV010
                          --- begin sig file ---
                          --- end sig file ---
                          • Duncanbest
                            • Jul 2012
                            • 81
                            • Taiwan
                            #33
                            U10 is a eeprom (BR24L32).
                            Outlook is like
                            http://www.ictradenet.com/BR24L16F-WE2/
                            data-sheet
                            http://www.rohm.com/web/global/produ...ct/BR24L32FJ-W
                            • sabre504
                              • May 2010
                              • 449
                              • United Kingdom
                              #34
                              Hi thanks for the pointers
                              U10 and U10 are both getting voltage in at a steady 3.2v and i cannot find any shorts .
                              Managed to find a sheet for the main logic ic controller and think this may be the problem as 3.3v are going in but the outputs fluctuate from 0 - 3.2v and should be at 3.3 steady
                              • sabre504
                                • May 2010
                                • 449
                                • United Kingdom
                                #35
                                I have removed the large chip U7
                                Now the screen and power are no longer pulsing .
                                Not to say this is the problem but until new chip turns up in a couple of weeks and fitted (again ordered from Hong Kong as cant get here ) will have to see what happens from there .
                                So yet another job in the attic awaiting parts
