Samsung 920NW 2 Seconds to Black
  • Jasgriff
    • Feb 2012
    • 578
    Re: Samsung 920NW 2 Seconds to Black
    New caps arrived today to recap the rest of the Power supply. Plugged it in and woo hoo it worked.
    Extremely happy I started to put it all back together again powered it up and its playing games again. Back to black after 2 seconds with the display in the background very faint.
    Im going to open it up again.
    Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
    How to resize your pictures guide click HERE
    Retiredcaps Ideal post example click HERE
    • Jasgriff
      • Feb 2012
      • 578
      Tried the CCFL's again and it turns out that one of the 4 is not working.
      I have had a good look and it doesnt seem to be damaged?
      • retiredcaps
        • Apr 2010
        • 9271
        The return wiring (the thinner guage) can often be frayed or charred, but you can't see it with the silicon ends covering them.
        --- begin sig file ---
        --- end sig file ---
        • Jasgriff
          • Feb 2012
          • 578
          retiredcaps after snapping 2 ccfls yesterday trying to repair them I almost gave up. Giving it one last bash I took the end off and the smaller wire came off in my hand I have spent about an hour trying not to break anything and I have managed to get another wire soldered on the end and it works! only thing I need to do now is join the 2 smaller wire neatly so that they fit back in. Are they ok with insulation take on them?
          • retiredcaps
            • Apr 2010
            • 9271
            That is why I only do preharnessed replacements as per
            https://www.badcaps.net/forum/showpo...5&postcount=10
            Alexanna is the king of these repairs.
            I estimate about 50% of the people who try ccfl replacements are successful. Most don't have the patience do it.
            If you mean insulation tape (not take), I'm sure alexanna uses Kapton tape. I think Toasty recommended silicon caulk at the tips where the solder joint is, but right now I can't find that thread in my bookmarks.
            • Jasgriff
              • Feb 2012
              • 578
              Guess what!
              Finally up and running!
              • jayoung
                • May 2011
                • 172
                #27
                Guess what!
                Congratulations! Now you have an idea what it's going to be like to possibly replace the ccfl on the packard bell.
                • Jasgriff
                  • Feb 2012
                  • 578
                  Yep picking up a 19" faulty tv tomorrow for 99p. I will steal the CCFL's from it
                    Good job, but the statement below is confusing:
                    "CCFL's have been tested.
                    I connected each of the CCFL's into another Power supply and tested them one by one and they all light up and stay on for more than the 2 seconds.
                    I also tried all 4 CCFL's from another monitor on the Samsung Power supply and they light up only for a split second each time after being turned on."
                    • Jasgriff
                      • Feb 2012
                      • 578
                      Well I learnt alot from repair this one.
                      When I first tested the CCFL's in another monitor they did work ( The fact it worked must have just been luck, as it was loose every now and again it must have made a connection maybe when the corner had been push a little? ).
                      So I though thought right I have another monitor with its back off I will try all 4 in the Samsung rather than one at a time and that still went off in 2 seconds ( I didnt verify properly that all 4 CCFL's in this good monitor were not intermittent )
                      What I should have done is had a loose known working CCFL and tried each socket not all at once.
                      Lesson learnt here is that its not a check box exercise you really need to check and re check what your doing then have a think before you move on to testing something else. Ohh and always have a at least 1 good CCFL to hand.
                      Thanks for your patience bubm and everybody else's help and thoughts including retiredcaps who encouraged me not to give up on bad CCFL connections (my Fluke still hasn't arrived!)
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #31
                        Yes, that is the best and easiest. I have one lying around from a botched repair.
                          I have lots.
                          • Jasgriff
                            • Feb 2012
                            • 578
                            lol How did that keyboard make its way into your CCFL tub?
                              Ran out off space for laptop parts.
                              • djman
                                • Dec 2012
                                • 3
                                hello everyone 1st post here I was following this thread and did all the testing and i had the same results, so now i would like to get the preharnessed replacements ccfl's Where can I purchase these ??? any help or guidance would be deeply appreciated.
                                (budm you have any lying around in that pile )
                                • Lumberjack777
                                  • 464
                                  #36
                                  www.ccflwarehouse.com - I didn't see any kits for your model. You might have to measure the length and diameter and order them that way. Good luck. ~L-J-7~
                                  • djman
                                    • Dec 2012
                                    • 3
                                    Thanks Lumberjack, I looked there also, will order per your suggestions. Happy Holidays and Thanks
                                    • Phlox321
                                      • Jan 2014
                                      • 37
                                      • South Africa
                                      #38
                                      Hi all, ive got the same monitor, same problem, 2seconds to black, recapped whole board, no difference, checked resistors and diodes and almost have same values as in this post, also voltages are okay, but ive found two of those little blue caps at inverter side which doesnt show any ohm value no matter on what setting dmm is, and also the two inner ccfls only light halfway then dies
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        #39
                                        Try plugging the lights into different sockets and see if the problem moves.
                                        Have you any lamps in anything you could try - perhaps make some test lamps
                                        See post by budm and in his signature there is a guide.
                                        Blue caps are almost impossible to test with normal equipment they are usually cheap to buy and if thought bad should just be changed. Again if you have others on the board you could move them round and see if the fault moves.
                                        • Phlox321
                                          • Jan 2014
                                          • 37
                                          • South Africa
                                          #40
                                          Ive swopped out one blue cap with another monitors one, no change, and ive tested the 4 sockets each with one test ccfl i have lying around which still works , i have noticed that the bottom socket, the ccfl shines the brightest, then next socket it lights up about halfway, third socketbit lights about three quarters, and last socket lights fully but not as bright as first socket
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • HTR-Informatique
                                            by HTR-Informatique
                                            02-09-2025, 06:51 AM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • totof
                                            Samsung UE50KU6070 black screen
                                            by totof
                                            I have my TV model UE50KU6070 which I am trying to repair.
                                            BN41-02528A / BN94-10800C motherboard.
                                            If I disconnect the motherboard from the power board, the backlight works. When the motherboard is connected the backlight works but the screen remains black.
                                            When I plug the TV into the electrical outlet, the standby LED lights up but no reaction to an attempt to start it with the remote control for about 1 minute. During this minute the TV consumes about 20W.
                                            After one minute the consumption drops to 0W and the TV can turn on with the remote control but...
                                            09-26-2022, 02:34 PM
                                          • VcemPzd
                                            Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                            by VcemPzd
                                            Hello everyone !
                                            My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                            04-28-2025, 10:14 AM
