Samsung 920NW 2 Seconds to Black
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    #41
    Re: Samsung 920NW 2 Seconds to Black
    Did you just try the test bulb on its own? try again using it to replace one original at a time.
    Also - if your board is same as post1 ,set off (unplugged) for 5mins test the secondary resistances on the two inverter transformers - see attached pic Meter on ohms 2000 test S1 to S2 and S3 to S4
    and post results
    • Phlox321
      • Jan 2014
      • 37
      • South Africa
      #42
      yes i used it just on its own, but will try it like you suggested, my boards the same but what i saw yesterday after checking voltages again, is that one rectifier/mosfet/transistor,cant really remember which is which, number d803, thos three legged ones with heatsink, the one reads 15v as it should according to spec sheet, other one reads 5v-6v and should also read 15v acording to its specs sheet, so looks like i neet to find a replacement?
      • Phlox321
        • Jan 2014
        • 37
        • South Africa
        #43
        I got results from test, i get about 626 on s1-2 and about 628 s3-4, i then connected the original lamps and the one test lamp like suggested, think i found the problem, a failing ccfl , with the one original disconnected and my test connected in its place the screen stays on but has a slight whining noise
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          #44
          ok so transformer secondary windings are good. Perhaps the whining could be due to the test bulb being different size/resistance. I am busy right now but will read up on whining back lights. Perhaps others will chime in with ideas.
          • Phlox321
            • Jan 2014
            • 37
            • South Africa
            #45
            Thank you so far for the help
            • Phlox321
              • Jan 2014
              • 37
              • South Africa
              #46
              And yes the backlight is a bit smaller, came from a 17" square monitor if i recall correctly
              • Phlox321
                • Jan 2014
                • 37
                • South Africa
                #47
                What i also have noticed is that when the screen stays on with the test lamp, the backlights flicker a bit and then go steady or normal
                • Rtech
                  • Jul 2010
                  • 1095
                  #48
                  You have one that has failed, and also one that is very close to failing.
                  • Phlox321
                    • Jan 2014
                    • 37
                    • South Africa
                    #49
                    Thank you for the help so far, ill see tommorrow where i can buy ccfl tubes, or maybe salvage from another screen and see what it does then
                    • Phlox321
                      • Jan 2014
                      • 37
                      • South Africa
                      #50
                      Hi all just want to let you know i fixed the screen, yay, as i was stripping the lcd panel toe put in a different ccfl tube that didnt fit anyway and was a tiny bit short, i removed the old original tube which was faulty and as i looked at it, i sal on of the white small wires looked like it been burned or sumthing and upon closer inspection the white wire came loose, so opend it, resoldered and all is well again, oh and the slight humming noise seemed to go away or is just much more quieter
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        #51
                        That is good news - well done
                        • Phlox321
                          • Jan 2014
                          • 37
                          • South Africa
                          #52
                          Thank you all for your help, much appreciated .
                          • C152Heavy
                            • May 2014
                            • 66
                            • CA
                            #53
                            Add me to the list of 920 NW veterans, the thing would work fine (until it warmed up?) then 2 seconds.
                            Thanks to those who went before me and diagnosed this and posted up.
                            This evening I dismantled the guts of the panel, re-soldered the fine wires on one set of tubes and it's back up and running. Probably should have done both sets but it "burned in" fine on the bench with everything apart and twisting the backlight assemblies some to look for intermittents.
                            That's the deepest I've had to go into a monitor to get it back on its feet.
                            D
                            • HTR-Informatique
                              Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                              by HTR-Informatique
                              YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                              I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                              On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                              I also changed the screen because the PC fell and the screen was broken.
                              I changed the battery with a new and original battery.
                              I also had corrosion/oxidation on the...
                              02-09-2025, 06:51 AM
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                            • totof
                              Samsung UE50KU6070 black screen
                              by totof
                              I have my TV model UE50KU6070 which I am trying to repair.
                              BN41-02528A / BN94-10800C motherboard.
                              If I disconnect the motherboard from the power board, the backlight works. When the motherboard is connected the backlight works but the screen remains black.
                              When I plug the TV into the electrical outlet, the standby LED lights up but no reaction to an attempt to start it with the remote control for about 1 minute. During this minute the TV consumes about 20W.
                              After one minute the consumption drops to 0W and the TV can turn on with the remote control but...
                              09-26-2022, 02:34 PM
                            • VcemPzd
                              Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                              by VcemPzd
                              Hello everyone !
                              My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                              04-28-2025, 10:14 AM
