Hi, all. I'm getting a bit frustrated with my pc (eMachine, big surprise). It's a T1840 and I started getting a "No Signal" awhile ago but was able to start in safe mode. Now I can't even do that. The cable is okay so I tried to change the video card but now it won't even let me get into safe mode. When I turn it on I get a series of beeps - 1, 3, 3, 1. Everything is plugged in as before. I removed the new video card. I have no idea what to do at this point. I've been reading other threads on this kind of problem but have only gotten more confused. Should I just give up and get a new machine? If you reply, please be easy on the tech-speech - I'm not exactly well versed in it. Thanks!!
eMachine No Signal
Re: eMachine No Signal
Look up the motherboard brand/type, look up the BIOS used, there can only be about three. Award and AMI are two. Look up the beep codes and it will probably indicate a video or RAM problem. Reseat the RAM and try again. Try with only one stick, if you have two in use.
Close to 30% of comp problems are PSU related. If you have a spare PSU, hook it up and see if it boots...After you clear the CMOS(Google it or use the manual).
Here's a basic but VG flow chart: http://www.fonerbooks.com/pcrepair.htm
Since this is badcaps, has the motherboard been closly examined for them? The PSU would have to be opened up to have a look-see.
Best of luck itry with your problem & first post. -
Trigem Imperial mainboard:
http://www.emachineupgraders.info/di...imperial.shtml
System BIOS Core Brand: PhoenixYa'll think us folk from the country's real funny-like, dontcha?
The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.Comment
itry, mark this site: http://www.computerhope.com/beep.htm
Note: Do not discount what kc8adu has to say above this post, the man has cred.Comment
Got the same code on a board I just recapped. Someone had "de-capped" the board by just pulling the caps off the board, so I didn't see the bulging ones. I replaced the missing caps, and 1-3-3-1 was all I would get. Replaced the rest of the caps at vrm, which looked ok, and everything is fine! I had never seen Sanyo caps before, but apparently they can be bad without bulging. Pheonix/Award bios btw.
Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...11-23-2023, 11:02 PM -
by howardc64Failure Symptom
No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
Where is the short?
Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but... -
by JayPoorJayGood morning.
I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions... -
by ScruitHello all,
Working on my first C64 / Breadbin / 250407. Purchased as non-working. Getting black screen.
More detail below, but for those that want to get right to the question.... Here are a few waveforms comparing the Pin15 output on the VIC chip (luma/sync) to the pin 4 on the AV socket (composite signal).
https://imgur.com/gallery/PpqcqPY
My question is: Is the composite waveform range of 0.1v-1v too low for a c64?
More detail:
Symptoms are that that I get... -
by supravit2000Hi, guys!
I am not a professional, all I can do is solder stuff on the boards, so I would really appreciate it if someone with knowledge shares his experience/thoughts on a problem I have with a PS4 console.
My friend gave me an original fat PS4, board model SAB-001, with WLOD, that has been previously opened. I changed the HDMI port, couple of pads on the board were ripped, which I connected to the corresponding caps/resistors? Just did so as in a shown diagram (one of the ground pads I ripped off and left it not connected). However, there was still no signal, so... - Loading...
