What is a normal composite signal range for a C64?
  • Scruit
    • Apr 2022
    • 12
    Hello all,
    Working on my first C64 / Breadbin / 250407. Purchased as non-working. Getting black screen.
    More detail below, but for those that want to get right to the question.... Here are a few waveforms comparing the Pin15 output on the VIC chip (luma/sync) to the pin 4 on the AV socket (composite signal).
    https://imgur.com/gallery/PpqcqPY
    My question is: Is the composite waveform range of 0.1v-1v too low for a c64?
    More detail:
    Symptoms are that that I get black screen on power up. The TV clearly detects a signal as it swtiches from the "no signal" blue background to a black screen. Have tested composite and s-video, same result.
    I went through my typical checks with the schematics and confirmed the voltage rails, all of the ICs are getting power/gnd, the address and data lines all show activity, and the various clock signals are present and are at the expected frequencies.
    - Pin 15 (which I believe to be "luma/sync") on the VIC seems to show a signal of good strength and reasonable for a b&w "composite" signal (0.25-2.5v, sync pulse present, but curiously no apparent back porch).
    - Pin 14 (WIBTB "color") shows what appears to be data but hovers around 6v.
    As I measure the composite pin on the AV socket, though, I see a signal that looks identical to the luma/sync, but with only half the voltage. Only between 0.1v and 1v. This does not seem to be high enough.
    I suspect the composite signal voltage may be too low - was expecting to see closer to the same level that the VIC is putting out on pin15. I also, though, read the pin15 output as looking like it would produce a solid bright line on the left of the screen, and the rest of the screen being medium dark. (If that is the case, which can't I see the bright line? Or maybe that is a "start of screen-visible part of the line" pulse. I will do more research on the composite waveform standards.)
    However, given that screen is all black, and the composite waveform looks like a blank screen, maybe the composite voltage level is fine and the VIC is faithfully producing a blank screen because of an upstream problem that is resulting in there being nothing to show.
    I have a dead test cartridge on the way.
    • 31090
    Re: What is a normal composite signal range for a C64?
    composite video is usually about 0.7v to 1v
    your tv/monitor has an ALC circuit to boost low levels anyway.
    • redwire
      • Dec 2010
      • 3910
      It looks like a blank, black screen coming out of the VIC. I wonder how much initialization it requires from the CPU i.e. what does the VIC make with no data going to it. Your scope looks a bit slow for video, to see frame details.
      The RF modulator schematics show additional circuitry (i.e. #251025 two emitter followers) for the luminance, chroma, composite outputs.
      So the AC voltage amplitude should be about the same, it's just a buffer with no voltage gain.
      I would look elsewhere for the problem.
      http://www.zimmers.net/anonftp/pub/c...c64/index.html
      • AstutePauciloquent
        Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
        by AstutePauciloquent
        Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
        I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
        11-23-2023, 11:02 PM
      • howardc64
        Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
        by howardc64
        Failure Symptom
        No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
        Where is the short?
        Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
        Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
        05-27-2025, 02:56 PM
      • JayPoorJay
        Converting +/- 5v to a Usable Hz Signal
        by JayPoorJay
        Good morning.
        I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
        This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
        The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
        08-07-2022, 08:35 AM
      • supravit2000
        PS4 fat has inconsistent signal after HDMI replacement
        by supravit2000
        Hi, guys!
        I am not a professional, all I can do is solder stuff on the boards, so I would really appreciate it if someone with knowledge shares his experience/thoughts on a problem I have with a PS4 console.
        My friend gave me an original fat PS4, board model SAB-001, with WLOD, that has been previously opened. I changed the HDMI port, couple of pads on the board were ripped, which I connected to the corresponding caps/resistors? Just did so as in a shown diagram (one of the ground pads I ripped off and left it not connected). However, there was still no signal, so...
        12-19-2022, 08:08 PM
      • Ellos
        Samsung s21 sim recognized but no signal
        by Ellos
        I'm just starting out with smartphone repairs and picked up a Samsung S21 to work on. Everything functions perfectly except there's absolutely no cellular signal. The SIM card is recognized, WiFi works fine, but zero network signal.
        I've tested my SIM in another phone and it works perfectly with good signal, so it's definitely the phone.
        From what I've read online, this issue is usually caused by the network chip needing to be desoldered and reballed since one of the solder balls might be cracked.
        I think I've located the SOC that...
        06-27-2025, 01:31 AM
