eMachine No Signal
  • itry
    • May 2006
    eMachine No Signal
    Hi, all. I'm getting a bit frustrated with my pc (eMachine, big surprise). It's a T1840 and I started getting a "No Signal" awhile ago but was able to start in safe mode. Now I can't even do that. The cable is okay so I tried to change the video card but now it won't even let me get into safe mode. When I turn it on I get a series of beeps - 1, 3, 3, 1. Everything is plugged in as before. I removed the new video card. I have no idea what to do at this point. I've been reading other threads on this kind of problem but have only gotten more confused. Should I just give up and get a new machine? If you reply, please be easy on the tech-speech - I'm not exactly well versed in it. Thanks!!
  • Galvanized
    • Mar 2006
    • 468
    Re: eMachine No Signal
    Look up the motherboard brand/type, look up the BIOS used, there can only be about three. Award and AMI are two. Look up the beep codes and it will probably indicate a video or RAM problem. Reseat the RAM and try again. Try with only one stick, if you have two in use.
    Close to 30% of comp problems are PSU related. If you have a spare PSU, hook it up and see if it boots...After you clear the CMOS(Google it or use the manual).
    Here's a basic but VG flow chart: http://www.fonerbooks.com/pcrepair.htm
    Since this is badcaps, has the motherboard been closly examined for them? The PSU would have to be opened up to have a look-see.
    Best of luck itry with your problem & first post.
    • MD Willington
      • Sep 2004
      • 702
      Trigem Imperial mainboard:
      http://www.emachineupgraders.info/di...imperial.shtml
      System BIOS Core Brand: Phoenix
      Ya'll think us folk from the country's real funny-like, dontcha?
      The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        the bestec psu often kills these boards.i have seen +5stby at 11v!
        dump it now.
        if you get a replacement board dont try it on the old psu!
        • Galvanized
          • Mar 2006
          • 468
          itry, mark this site: http://www.computerhope.com/beep.htm
          Note: Do not discount what kc8adu has to say above this post, the man has cred.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            he has done more rework than we have had hot dinners.
            • Spacedye69
              • Nov 2005
              • 698
              • US
              Got the same code on a board I just recapped. Someone had "de-capped" the board by just pulling the caps off the board , so I didn't see the bulging ones. I replaced the missing caps, and 1-3-3-1 was all I would get. Replaced the rest of the caps at vrm, which looked ok, and everything is fine! I had never seen Sanyo caps before, but apparently they can be bad without bulging. Pheonix/Award bios btw.
              • AstutePauciloquent
                Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                by AstutePauciloquent
                Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                11-23-2023, 11:02 PM
              • CoinCoin88
                Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                by CoinCoin88
                I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                09-15-2025, 03:36 AM
              • howardc64
                Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                by howardc64
                Failure Symptom
                No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                Where is the short?
                Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                05-27-2025, 02:56 PM
              • JayPoorJay
                Converting +/- 5v to a Usable Hz Signal
                by JayPoorJay
                Good morning.
                I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
                This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
                The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
                08-07-2022, 08:35 AM
              • Scruit
                What is a normal composite signal range for a C64?
                by Scruit
                Hello all,
                Working on my first C64 / Breadbin / 250407. Purchased as non-working. Getting black screen.
                More detail below, but for those that want to get right to the question.... Here are a few waveforms comparing the Pin15 output on the VIC chip (luma/sync) to the pin 4 on the AV socket (composite signal).
                https://imgur.com/gallery/PpqcqPY
                My question is: Is the composite waveform range of 0.1v-1v too low for a c64?
                More detail:
                Symptoms are that that I get...
                04-28-2022, 05:33 AM
