Dell 1703FPt Flashes on then off
  • iusvir
    • Jan 2012
    • 5
    I have a Dell 1703FPt that will flash on for a second then off. The image is still there just the inverters appear to be shutting down.
    With an ESR meter I found c809 to be bad. I have also replaced the caps that are green (this was before the esr Now I am stumped would appreciate the help.
    No apparent burns on the inverter xfmers
    This is the one piece psu/inverter design. See attached pics.
    Keith
  • jayoung
    • May 2011
    • 172
    Re: Dell 1703FPt Flashes on then off
    Sounds like 2 seconds to black. The following post is a Guide to Troubleshooting "2 Seconds to Black."
    https://www.badcaps.net/forum/showthread.php?t=10419
    Issues can include bad capacitors, bad transformers, bad ccfl's or ccfl wiring, bad transistors, etc.
    • sabre504
      • May 2010
      • 449
      • United Kingdom
      Have you checked the pico fuse ?
      • selldoor
        Slow Learner
        • 7870
        I agree .read the guide. Personally I would try and check the inverter transformers first. I was trying to read the numbers off the one on the right to advise you which were the secondaries but couldnt quite make it out. Nor could I read the power supply board number. It is usual to have pictures looking straight down so that these can be read along with other board information. You should also post a picture of the underside.
        • iusvir
          • Jan 2012
          • 5
          I found it!!!!! shorted wire on one of the CCFL's
          Thanks for the input guys!!!
          • selldoor
            Slow Learner
            • 7870
            Well Done!! Dont break it putting it back together
            • smason
              • 1652
              I HATE it when that happens.
              • pedro
                • 199
                • AUSTRALIA
                ??? if the backlights flash then the fuse is obviously intact.
                Friends don't let friends buy Samsung ....
                • sabre504
                  • May 2010
                  • 449
                  • United Kingdom
                  Had it happen to me before backlight flash pico on its way out changed and cured the fault .
                  Since then just change them anyway to play safe
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • master3112
                    by master3112
                    07-29-2025, 01:55 PM
                  • F R 2568
                    Dell Latitude 5420 does not start (no post) need help to find the reason why
                    by F R 2568
                    Hello all,
                    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                    If the laptop is only connected to the AC adapter (battery removed):
                    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                    The power/battery...
                    01-08-2025, 05:45 AM
                  • diamon
                    Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                    by diamon
                    I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                    Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                    Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                    Pictures of these boards:
                    Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                    Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                    Dell...
                    02-28-2024, 12:51 PM
                  • lalle-
                    Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                    by lalle-
                    Hello!
                    I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                    [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                    I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                    The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                    I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                    08-11-2024, 02:01 PM
