Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
  • lalle-
    • Aug 2024
    • 11
    • Sweden
    Hello!
    I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
    [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
    I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
    The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
    I tried updating to a custom BIOS from Reddit user Satori_Nori https://www.reddit.com/r/GamingLapto...5_custom_bios/ with the help of a CH341A programmer.
    The programming was successful, but the status LED blinks 2 red and 5 white, indicating "Invalid memory installed".
    Then I tried extracting a binary from the Dell 1.20.0 bios and programmed the chip with that - same thing "invalid memory".
    I have tried swapping the RAM sticks, trying one at a time in each slot, and even tried a different RAM stick to no avail.
    There's another thread on this forum where someone was having a similar issue with a similar laptop (Inspiron 5505 instead of G5 SE 5505) https://www.badcaps.net/forum/troubl...5-19852-1-bios
    If anyone can help me save this PC I'll be very greatful!
    I'll end this with a bonus question: Is it possible to turn off the Dell support assistant warnings at startup? I'm tired of being warned that there's no LCD connected.
    Thanks in advance!
    / Lalle
    System info:
    Laptop: Dell G5 SE 5505 (can't find any more detailed number other than "option #2".
    CPU: Ryxen 4800H
    GPU: Radeon RX5600M
    RAM used: Micron MTA4ATF1G64HZ (2x8GB PC4 2300MHz CL22)
    Service tag 2MJDB63 (No match on Dell's webpage)
    Motherboard model number (i think): CN-0JT83K​
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    After bios flash from that reditt link,do you still get display on screen? I think NO.
    The dell bios update dont have the full bios inside and you need to rebuils the bios from original backup+bios update.
    If you dont know how to do it,post your original backup in bios section and make a request for clean me bios from dell update.
    PS: Programming with CH34 is highly unreliable.
    • lalle-
      • Aug 2024
      • 11
      • Sweden
      Thank you for your reply!
      Your answer gives me a bit of hope
      I see that I left out that important piece of information: When booting, the screen is black, nothing shows on screen.
      It seems that I don't know enough about BIOSes these days. I don't have a backup since the BIOS update failed, I assumed the BIOS on chip was corrupt and went straight to reddit. Perhaps this was a mistake.
      What should my next steps be to get things running again?
      I found a thread with a BIOS file on this forum: Dell g5 se 5505 - Badcaps​ - would this work?
      Kind regards
      Lalle
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Yes you can try bios from that thread.
        • lalle-
          • Aug 2024
          • 11
          • Sweden
          Thanks for your reply.
          Progress (or not really, but I've tried things):
          I have now tried them both. I programmed the chip, read back the contents and verified that the programmed file and the read back file were identical.
          I still get the same symptoms:
          No image on screen.
          LED Blinks "Invalid memory": 2 red, 5 white
          If I remove the RAM I get "No memory or RAM detected": 2 red, 3 white.
          Since I'm running the motherboard out of the chassis, I don't have the CMOS battery plugged in - Is that a problem?
          I think next step will be to request a virgin BIOS in the appropriate part of the forum.
          If anyone has any pointers for me I'd be very happy
          Cheers
          / Lalle
          • lalle-
            • Aug 2024
            • 11
            • Sweden
            Found the motherboard model number on the PCB:
            Selek MLK AMD
            19802-1
            FGRDN$JA
            • mikeybass
              by mikeybass
              04-23-2025, 04:30 PM
            • trix11
              Dell Precision T1650 MT Workstation bricked after BIOS update
              by trix11
              I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
              - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
              - Dell Precision T1650 mid tower Workstation
              - Xeon E3-1225 V2
              - 32Gb PC3-12800E RAM
              - 4Tb SATA HDD
              - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
              I see now that others have experienced like issues e.g.:
              - https://www.dell.com/community/Prec...
              10-24-2022, 10:35 PM
            • zenius
              by zenius
              12-08-2024, 06:13 AM
            • Akhlz001
              by Akhlz001
              09-20-2025, 07:15 PM
            • Julian Bailey
              BIOS update wont complete - Dell Latitude 7420
              by Julian Bailey
              Hi all
              Anyone come across this issue where a BIOS flash will only part complete?
              It will update the system BIOS and Primary EC BIOS fine but fails to update the Intel TBT Retimer, Intel TBT Retimer 2 and ME Firmware.
              NVMe m.2 drive isnt detected in the BIOS, but you can get into the BIOS fine and it all works in there as intended.
              The drive works fine in another laptop.
              Link to a video I made of what its doing here:
              Any ideas on how to overcome this?
              Cheers...
              06-02-2025, 01:39 PM
