Dell E207WFPc
  • killian6pk
    • Apr 2010
    • 502
    Dell E207WFPc
    Could not find anything on this monitor doing a search in the forum. This monitor is really nice so I would like to repair it if possible.
    I have replaced all caps with low ESR good brands Panasonic, Nichicon etc.
    I have checked all fuses and they are good. Also checked all resistors and small diodes. I am down to two Schottky (I think) Diodes and one mosfet (I think) on Heat Sinks.
    I need some help in checking the readings I have gotten, to see if these parts are good or not.
    Diode Setting on DMM
    D906 Schottky #1 Pin 1 - 2 = 1.99v after hitting this reading the meter flips to O.F
    2- 3 = .242v
    D905 Schottky #2 Pin 1 - 2 = 1.621v
    2 - 3 = .148v
    Ohms setting on DMM
    Q901 Mosfet G - S = 9.99 Kohms
    G - D = 8.19 Mohms
    S - D = 8.19 Mohms
    Thanks for the help.
    Have you ever stopped to think and then forget to start thinking again?
    As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell E207WFPc
    2- 3 = .242v
    2 - 3 = .148v
    Ohms setting on DMM
    G - D = 8.19 Mohms
    S - D = 8.19 Mohms
    1) All those readings are good. It looks like your multimeter has a threshold of 2V for diode testing before it reads 0L (out of range).
    2) It always helps if you tell us the problem and symptoms.
    3) Good clear pics.
    4) NR901 (backside) looks like it has dodgy solder cracks?
    --- begin sig file ---
    --- end sig file ---
    • killian6pk
      • Apr 2010
      • 502
      Re: Dell E207WFPc
      Sorry about that. I realized about 1:00 am that I had not given the problem.
      The monitor does not power on at all, no light or flicker or anything. I will check the component on the back of the board and get back to you on what I find. Thanks for giving me the info on the front side components.
      • retiredcaps
        • Apr 2010
        • 9271
        Re: Dell E207WFPc
        1) What is the DC voltage across the big cap? Be careful measuring this as it could be around 165 V DC.
        2) What is the DC voltage across the startup cap (C908)? Is it steady or fluctuating?
        3) On the backside, what is part number for IC901? For bonus points, find the datasheet and provide a link.
        • retiredcaps
          • Apr 2010
          • 9271
          Re: Dell E207WFPc
          4) On the multicolored connector, measure all pins for DC voltage. Report the pin number, its legend (if any), and the voltage.
          • killian6pk
            • Apr 2010
            • 502
            Re: Dell E207WFPc
            Voltage Across Big Cap = 173v
            Connector Label Reads:
            Black = N/F
            Open (no wire) = NC
            Brown = DIM
            Open = +14v
            Open = +14v
            Red = 5v
            Orange = 5v
            Yellow = Gnd
            Green = Gnd
            Voltages from Green Gnd. Readings taken with Power Pluged In and On.
            Reading taken from Power Supply Side Plug
            G - Y = 0v
            G - O = 5.08v
            G - R = 5.08v
            G - B = -288 mv
            Voltages taken from Green = Gnd on Power Supply Side Plug to Main Board Plug
            G - O = 5.08v
            G - R = 5.08v
            G - Y = 0.06mv
            G - B = 1.3mv
            C908 is 10.12v Steady
            IC # is: EA1530A
            DataSheet is at: http://pdf1.alldatasheet.com/datashe...TEA1530AP.html I need all the extra points I can get. Thanks
            • Rtech
              • Jul 2010
              • 1095
              Re: Dell E207WFPc
              At a quick glance, all looks as it should, so probably need to switch your attention to the Logic Board, particulary the Voltage regulators,so if you cannot identify them, then you need photos of the top of the Board
              • killian6pk
                • Apr 2010
                • 502
                Re: Dell E207WFPc
                Ok, I'll get pictures. Cloudy, Rainy and getting dark here. I will post asap in the morning. Thanks.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Re: Dell E207WFPc
                  1) Those DC voltages indicate your SMPS is working.
                  2) Now we need a clear focused picture of the logic/main board.
                  3) Rtech beat me to it.
                  • killian6pk
                    • Apr 2010
                    • 502
                    Re: Dell E207WFPc
                    Ok here are the two Video Board Pictures. Sorry about the flash. It is still a nasty day today. So I had to improvise the picture taking.
                    • trebo
                      • 514
                      • Wales, UK
                      Re: Dell E207WFPc
                      Is that a solder splash across pins 1+2 on U402?
                      also can you post data on the 3 pin component? just under and to the right of U402 as flash has obscured it
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Re: Dell E207WFPc
                        1) Interesting. Did you recap this main board too? Or did it come with Rubycon and UCC KY caps?
                        2) The voltage regulators are circled in red. We want the DC voltage readings from all the 3 pins (Gate, Source, Drain) with respect to ground.
                        • killian6pk
                          • Apr 2010
                          • 502
                          Re: Dell E207WFPc
                          Solder splash appears to only have been on top of U402 not between legs.
                          The component you are referring to is Q401 and the number is AZ1117D. Here is the datasheet: http://pdf1.alldatasheet.net/datashe...1117D-1.8.html
                          • killian6pk
                            • Apr 2010
                            • 502
                            Re: Dell E207WFPc
                            I make it a habit of never touching a main board unless I absolutely have to. They are so hard to remove components from. I don't know if someone tried to work on this board before I got it. Picked it up off of Craigs List.
                            I will get your readings on what you have circled. Get back to you with those soon.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              Re: Dell E207WFPc
                              Hmm, now that I relook at the backside, it looks like the original caps from the soldering.
                              You almost never see high quality caps (especially low ESR) on the logic board since they don't undergo the same stress as caps on the SMPS.
                              • killian6pk
                                • Apr 2010
                                • 502
                                Re: Dell E207WFPc
                                Do you mean for me to take the readings with the power on and the main and power boards connected.
                                • killian6pk
                                  • Apr 2010
                                  • 502
                                  Re: Dell E207WFPc
                                  I believe you are correct. The solder points look just like factory work.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    Re: Dell E207WFPc
                                    Yes.
                                    • killian6pk
                                      • Apr 2010
                                      • 502
                                      Re: Dell E207WFPc
                                      Readings on component (with heat sink)
                                      G = 2.2mv S=5.07v D=3.28v
                                      Q401
                                      G=2.0mv S=3.28v D=1.79v
                                      Just for my knowledge, I thought you read transistors (Q401) by taking an ohms reading between the different legs G-S G-D & S-D.
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        Re: Dell E207WFPc
                                        Q401
                                        The readings for the voltage regulators look good. The "usual" voltages are 1.8V and 3.3V.
                                        Yes, that is one test. Voltage regulators can be shorted. However, the test for a short doesn't verify if it outputting the correct voltage or not.
                                        For example, a AL1117-33 regulator should output 3.3V DC. The suffix -33 denotes the output voltage.
                                        • Akhlz001
                                          by Akhlz001
                                          09-20-2025, 07:15 PM
                                        • master3112
                                          by master3112
                                          07-29-2025, 01:55 PM
                                          Dell Thunderbolt Firmware
                                          by SMDFlea
                                          Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                                          Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                                          The SKU is in brackets (****)
                                          EDIT: NVM65...
                                          01-26-2025, 06:22 AM
                                        • F R 2568
                                          Dell Latitude 5420 does not start (no post) need help to find the reason why
                                          by F R 2568
                                          Hello all,
                                          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                          If the laptop is only connected to the AC adapter (battery removed):
                                          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                          The power/battery...
                                          01-08-2025, 05:45 AM
                                        • diamon
                                          Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                          by diamon
                                          I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                          Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                          Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                          Pictures of these boards:
                                          Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                          Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                          Dell...
                                          02-28-2024, 12:51 PM
