Dell E207WFPc
Re: Dell E207WFPc
The resistance reading for C15 is 34.6 ohms. I still can't get a DC reading on the caps because the DMM display is bouncing around so much. I think it is because I can't find a ground spot for the black probe. Would that be the problem. With the boards hooked up inside their cage they are not available to use as a grounding point. I have tried every piece of bare metal without any luck. For me to be able to get to the caps etc. on the TCon it must be opened. It's normal position is component side down. on the back of the LCD. Any ideas.Have you ever stopped to think and then forget to start thinking again?
As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."Comment
Re: Dell E207WFPc
At this point I'd suggest measuring the resistance across each cap that measured in about the same range and remove the one that reads lowest. If you are lucky you will get it on the first try. If none are shorted, keep looking.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Re: Dell E207WFPc
Thanks Bill, Sorry I am so thick headed. I tried measuring the voltage with both probes on the same cap and I am still not getting a readable number because the DMM display is bouncing around so much. I will do what you suggest and go one by one. Once i find a cap like you are describing how do I determine its value. I am guessing that these are smd ceramic caps and from what I have been reading there are no codes to determine UF or PF etc. If they are shorted will I get a useable capacitance with say my ESR meter?Have you ever stopped to think and then forget to start thinking again?
Re: Dell E207WFPc
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
Channel: BIOS Requests ONLY!
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
by SMDFleaDell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
Some models have a choice of 2 different firmwares, it depends on the dell SKU.
The SKU is in brackets (****)
EDIT: NVM65...-
by F R 2568Hello all,
this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
If the laptop is only connected to the AC adapter (battery removed):
When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
The power/battery... -
by diamonI have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
Pictures of these boards:
Dell Latitude 5520 https://www.ebay.com/itm/256052956663
Dell Latitude 5530 https://www.ebay.com/itm/125844181534
Dell...4 Photos - Loading...
