Planar PL2010M-BK -Black screen
  • K_K3N
    • Feb 2014
    • 22
    Re: Planar PL2010M-BK -Black screen
    Well with the Proper power supply , I now get a solid green light when hooked up to a PC .. but still noting on the screen .. Is there a way to test the lights in the panel it self ?
    • K_K3N
      • Feb 2014
      • 22
      Ok its a 10 volt 100 uf cap .. I still get no screen .. the green light stays on now .. is there any way to test the back light tubes .. to see if they are burnt out ?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4326
        • Italy - Milan
        Hi...
        "with the Proper power supply" what do you mean with this?
        "Is there a way to test the lights in the panel it self ?" another monitor/inverter or other known good lamps.. or the trick of disabling the protection temporarily..
        about your supposed bad cap i saw the board on sale's picture, if you mean the black cap put on its side that under it is only normal glue.
        • K_K3N
          • Feb 2014
          • 22
          Originally posted by Davi.p
          Hi...
          The Proper Poser supply I mean .. the original was not given to me .. so I used a 12 volt 2 amp one .. I got the proper one now .. a 12 volt 6.6 amp
          Replacing the * 2 bad caps on the board the power does now make the green light light up , and it stays green when hooked to a PC .. but turns orange after a bit when not .. So I know the monitor is getting a signal and knows it . I just do not get any screen to come up .. I have tried the " 2 finger " Reset but does not help .
          With the other power supply I would not get a green light , until I replaced the capacitors , but after replacement , I would get a green light that went orange soon , even with the PC on . So the lack of proper amps must have caused that .
          * The 2 bad caps were in align with a third that did not blow its top , Do I need to change that one out too ?
          Also do I need to check Fuse's after they are removed ? as all appear OK while on the board .
          Thank you again for any help ..
          K_K3N
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4326
            • Italy - Milan
            "the original was not given to me .. " So i guess that is an external one..(??)
            "So the lack of proper amps must have caused that" Let me understood.. with the original and with the other psu is the led behavior the same (first green then orange..)?
            "Do I need to change that one out too?" there's no picture of psu or board where psu goes .. no schematic, so i can't tell this..
            "Also do I need to check Fuse's after they are removed ?" No.
            • K_K3N
              • Feb 2014
              • 22
              .. The monitor acted different with the 2 different power supplies .
              The one that came with it was no longer putting out power so the guy tossed it after I bought a new one . The one I tested it with was one I had that was lower on amps then what the original had .
              That is the Power board .. The red circle is where I replaced 2 of the three.
              470 uf 10 volt .. I only had 470 uf 25 volt available to use.
              the under side of the board shows that they were all connected parallel .
              Here is the Video board .
              When I bent the dark one in the corner up to read it's size . the leads broke .
              I can put a 25 volt 100 uf in its place . it was by reading the part number and going to the manufacturer web site it was a 10 volt 100 uf .
              If the Panel is dead I am not going to put anymore money into it . ( the guy does not want the monitor now , so If I can't fix it I am out the $'s the new external power supply cost me )
              How can I check to see if the panel it self will light up ?
              Thanks ,
              K_K3N
              • K_K3N
                • Feb 2014
                • 22
                Well fuses are all ok .. a few other caps dont seem to hold steady when I check with ohms on meter.
                I wonder if the CF tubes are broken or non functional .. any way to test ?
                • selldoor
                  Slow Learner
                  • 7870
                  #28
                  Which fuses are ok - the two on the inverter board?
                  • K_K3N
                    • Feb 2014
                    • 22
                    the 6 on the board the power plugs into
                    The monitor power light stays green when I hook up to a system as a second monitor .. Win 7 even recognizes it .. if I disable it , the power light goes amber .. as expected
                      Six fuses? This unit has six lamps so even one or two are broken, at least you should see the working lamps flash on for seconds before the inverter goes into protection mode.
                      We need the straight shot pictures of the inverter board top side and bottom side, the pictures must be clear enough to see traces on the traces.
                      • selldoor
                        Slow Learner
                        • 7870
                        #31
                        Can we have good clear pictures of your boards posted using manage attachments
                        not posted off site.
                        They need to be like the original posters so we can see what you are talking about.
                        Mark up the board with the six fuses you have tested.
                        The problem you are having probably relates to fuses on the inverter board I think I see 1 fuse - its pretty blurred the original poster has 2 so please check They will be labelled F1 and F2 in all probability
                        • K_K3N
                          • Feb 2014
                          • 22
                          Here are the Fuses I checked .. FB1 thru FB6
                            FB = Ferrite Bead (it's basically a very small inductor), they are not fuses.
                              Post 30: "We need the straight shot pictures of the inverter board top side and bottom side, the pictures must be clear enough to see traces on the board."
                              • K_K3N
                                • Feb 2014
                                • 22
                                ok I borrow my daughter digital camera .. Cell phone cam is a little bad at larger pics
                                • K_K3N
                                  • Feb 2014
                                  • 22
                                  I hope these are clear enough ..And Thank you for help
                                    OK, check and report the DC Voltage readings at both ends of these two fuses which feed the B+ to the inverter transformers drive circuits.
                                    • K_K3N
                                      • Feb 2014
                                      • 22
                                      I got voltage on one end of both fuse's and none on the other with unit plugged in
                                      2.0 = .. 2 amp fuses?
                                        They should have 12VDC at both ends of the both fuses, so it means that those 4 SMD POWER MOSFETs (8-leg SMD) above those two fuses may be shorted out that caused the fuses to blow. We will need the P/N as printed on top of those 4 devices.
                                        • K_K3N
                                          • Feb 2014
                                          • 22
                                          Ok I get the numbers I did have 3 bad Caps I replaced could that have blown the fuses ?
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • VcemPzd
                                            Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                            by VcemPzd
                                            Hello everyone !
                                            My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                            04-28-2025, 10:14 AM
                                          • DaniK
                                            Acer Aspire E5-574-52RH - black screen
                                            by DaniK
                                            I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                            Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                            Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                            Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                            The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                            Symptoms are:
                                            - random black screen after displaying Acer logo...
                                            02-21-2024, 06:27 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • seve91
                                            ACER XV340CK 34" black screen
                                            by seve91
                                            I got this monitor with black screen problem.
                                            I thought the problem was in the motherboard, so I bought 2 smashed monitor same model to disassemble boards and swap them, but same issue remains.
                                            After some tries I've found out that connecting LVDS cable on-fly after powering on the LCD panel let me see the whole screen for half sec, then goes black again.
                                            TCON got two output flats, because each flat goes to a tiny board with some COF, each tiny board manages half LCD panel.
                                            I discover that if I leave connected only right side (right flat of the TCON),...
                                            07-30-2025, 02:32 PM
