Planar PL2010M-BK -Black screen
  • Mishannya
    Badcaps Junior
    • Sep 2010
    • 31
    Planar PL2010M shows picture for about 1/2 second and goes back Black. Power LED remains green until display cable is connected and signal is presents. Caps are looks fine and tested OK. Voltage on PS tested OK. Thanks for you hints.
    • Jul 2011
    • 6033
    Re: Planar PL2010M-BK -Black screen
    Check the fuse and transistors or mosfet in the inverter part of the board
    Also would help if you could post a few photo of all of your boards in this monitor
    • PlainBill
      • Feb 2009
      • 7034
      Two seconds to black. Since you have eliminated the caps as a potential cause, the remaining potential causes are a bad transformer, a bad CCFL or wiring to the CCFL, or a bad component in the protection circuitry.
      PlainBill
      • Mishannya
        Badcaps Junior
        • Sep 2010
        • 31
        Pictures attached.
        • Mishannya
          Badcaps Junior
          • Sep 2010
          • 31
          0.5 seconds and goes black.
          • Mishannya
            Badcaps Junior
            • Sep 2010
            • 31
            Also I tested all transformers. Result is OK.
            • jetadm123
              • 2169
              Did you try checking fuses F1 and F2 on the inverter board as samX3 suggested?
              • Mishannya
                Badcaps Junior
                • Sep 2010
                • 31
                Fuse F2 is open. Thanks.
                • Mishannya
                  Badcaps Junior
                  • Sep 2010
                  • 31
                  Thanks a lo to all of you. It is working now.
                  • TURBORT
                    • Oct 2011
                    Mishannya,
                    I have a Hanns G HG281D that is doing roughly the same as yours. It comes on and then it's like the back light goes off and you have to turn it back on again. If you turn it on, the image might say or it might go black again. You seem to have alot more knowledge than me on this...I live in Ohio, would you be interested in looking at this monitor for me? I would be willing to compensate you for your time and would pay for parts. I was able to save my parents Toshiba projection tv due to alot of studying on the internet, but my time is limited. If you do not wish to to that I understand, just thought I would ask? I appreciate you time. Regards, Matt
                    • bbrtoluch
                      • Dec 2013
                      I know this has been dead for a few years, however, where did you purchase this F2 Fuse at, and what type of tools do you need to replace it?
                      Ive got the board apart and measured the resistance across the fuse1 and fuse2... fuse one gets a 0 reading (good) and fuse2 gets a 1... so I am fuguring i need to un-soldering and solder a new fuse on...
                      Thanks for your time and help!
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4301
                        • Italy - Milan
                        1 ohm is an uncommon value i think for a fuse, so before spend money on a shipping try the voltage a the valley of the fuse soon after power up and after screen goes black.
                        • bbrtoluch
                          • Dec 2013
                          It was my understanding that the fuses read open or close, 0 is open good and 1 is closed bad... or vice versa.... there was a guy on youtube explaining it. If the two identical fuses read different one must be bad! i hope
                          http://www.youtube.com/watch?v=vgn1fN4ixacb
                          I was just following his example =) I just am trying to find where to order a inverter board or some fuses
                          • selldoor
                            Slow Learner
                            • 7870
                            Ok - First is "1" 1 ohm or is it "1" as in off scale or the same as just having th e meter on ohms an probes apart.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4301
                              • Italy - Milan
                              ah ok, the same old thing, i have forgot, so i think he has an open fuse.. some testers show if i remember ".1" as open circuit..
                              • selldoor
                                Slow Learner
                                • 7870
                                I cannot find a fuse with that marking - guessing it is 2a so for TEST purpose you can use any 2a fuse - pico fuse or if you insulate it carefully even an automotive fuse.
                                If the set then works if you tell us the physical size of the fuse we can suggest one
                                • K_K3N
                                  • Feb 2014
                                  • 22
                                  I also just received a Planar 20" flat panel that would not power up at 1st .
                                  It had 2 bad caps on the board the power supply plugs into .. I replaced them , I get a green Light now , then it goes orange .. I see no flash or attempt to brighten on the screen . Using the standard VGA input .
                                  One of the capacitors on the video board Has some goo burnt to the side of it , I tried to see what its UF and voltage was , but when I tried to rub the burnt stuff off so did the numbers painted to the side.
                                  Any idea where I can find out what the capacitor was ?
                                  Boar number is VL-2001-Rev:1a Use all for goggle search or ya wont see it.
                                  I found a replacement board ( used )
                                  http://www.aliexpress.com/item-img/I...417616352.html
                                  But in its picture the cap has a burnt puddle on the board too . Upper left on the Picture only cap on its side .
                                  Would rather try to replace the Cap then order a used board from China .
                                  Thanx ,
                                  K_K3N
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    Ok - what does the cap connect to maybe one of the voltage regulators? .
                                    get the part number of that and look up the datasheet for clues.
                                    A good close up picture of that area on YOUR board might help.
                                    What is the board part number C??? and measure the physical size height and diameter.
                                    • K_K3N
                                      • Feb 2014
                                      • 22
                                      It is a Cap .. I'll get back Sunday with more info . ( my only day/night off work ). ( I work so much during the week , I don't spend much time on the PC )
                                      Sorry for the Late reply .. And Thank you . I did try to find a spec sheet for the board , but no luck yet .. Several other numbers on a sticker on the back .
                                      • K_K3N
                                        • Feb 2014
                                        • 22
                                        its an Lelon A340 (M)
                                        RXK 105 c
                                        I can barely make out the UF .. looks like 100 .. only thing I need to figure out is voltage
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • VcemPzd
                                          Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                          by VcemPzd
                                          Hello everyone !
                                          My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                          04-28-2025, 10:14 AM
                                        • DaniK
                                          Acer Aspire E5-574-52RH - black screen
                                          by DaniK
                                          I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                          Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                          Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                          Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                          The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                          Symptoms are:
                                          - random black screen after displaying Acer logo...
                                          02-21-2024, 06:27 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • Swedishpower
                                          Dell G3 15 3500 black screen
                                          by Swedishpower
                                          Hello
                                          I have search everywhere for a solution for my problem, but cant find it anywhere.
                                          When I was away to trow some garbage i always look in the electronic bin.
                                          and this time i find a laptop.
                                          Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
                                          the lamp for charmig is white.
                                          Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
                                          but no Dell logo.
                                          I tryed with a hdmi cable to another screen, still black.
                                          I started to search solution and tryed...
                                          07-06-2025, 06:18 AM
