LG W2234S Repair Help...
  • docksteaderluke
    • Jul 2011
    • 39
    #41
    Re: LG W2234S Repair Help...
    Oh snap! Nice find! That's it for sure.
    • nickmatine
      • Jun 2010
      • 48
      hi
      i have the same problem with same monitor
      I'm stuck with lg logo (no power saving mode) all time if i don't have the vga cable from video card
      when i plug the cable 2 sec on (with same lg logo) and 2 sec off.
      please post here if you found the problem
      i suspect the logic board because i changed all caps and checked inverter board
      thanks
      • alexanna
        • Mar 2010
        • 1346
        #43
        Here's another approach
        First try this identify the on/off pin on the front power switch, see if that voltage goes low when the monitor shuts off.
        There are things going on with your monitor that do not make sense.
        #1 is the loss of the front PLED
        #2 is the monitor is able to briefly turn on the back lamps, but they will not turn on when you provide 3 volts to the on off pin.
        If the voltage stay high on the on/ off switch ,I am thinking one problem may be causing the other.
        I know you have already done this, but it can't hurt to check it again.
        The back light controller has to have the proper power and grounds, if the schematic is correct you should be able to identify them.
        The back light controller also has to see an on off signal, it's going to be about 3 volts at the 6 pin connector but it will be much lower at the controller around 1 volt.
        I don't think the dim pin is that critical, unless for some reason it was way higher than 1 volt this would be measured at the back light controller.
        If all of this is correct the backlights should turn on.
        PlainBill suggested loading the power supply; I would suggest using the 1157 tail/turn bulb to ceck the 16 volt rail.I haven't done the math for 16 volts but 12 volts will give roughly between 2 and 2.5 amps,that should be more than enough for the back light circuit.
        PlainBill do you have any sugestions?
        • docksteaderluke
          • Jul 2011
          • 39
          #44
          Hey guys. It's been a while but I got my hands on a replacement power supply and the problem still remains so it seems like that eliminates the power supply. Where am I hooking up the tail light bulb? to the backlight connectors (CN501-CN504)? Is this still necessary if I know for a fact that the power supply is good?
          • PlainBill
            • Feb 2009
            • 7034
            No, not necessary.
            PlainBill
            • docksteaderluke
              • Jul 2011
              • 39
              #46
              So now, if knowing for a fact that this isn't the power board, it seems the only thing left is either the logic board or panel itself. Thoughts?
              • PlainBill
                • Feb 2009
                • 7034
                It's 5:43 AM and I don't really have any coherent thoughts. Well, very few that will help you. It's 99% certainly the signal card is responsible. Both the backlights and the power light are controlled by the signal card. There isn't much that can be done, other than verifying the voltage regulators on the signal card are working properly. Unfortunately, similar problems are reported on other monitors, but I've never seen a solution that didn't involve getting a new signal card.
                PlainBill
                • alexanna
                  • Mar 2010
                  • 1346
                  #48
                  When you replaced the power supply, have any of the symptoms changed? Is anything different?
                  Is the power LED still turning off?
                  • docksteaderluke
                    • Jul 2011
                    • 39
                    #49
                    Symptoms are exactly the same. Both the power LED and the display turn on and off. It only ever gets as far as displaying the LG logo on the screen then shuts off and repeats.
                    • alexanna
                      • Mar 2010
                      • 1346
                      #50
                      I don't know if the symptoms were the same but we have had problems with the front panel switch,Have you verified voltages toggle low as the buttons are pushed?
                      • seanc
                        • Nov 2008
                        • 1319
                        #51
                        Now that we've definitely ruled out the PSU, sub in some known good lamps from another monitor and see if the symptoms change.
                        • PlainBill
                          • Feb 2009
                          • 7034
                          Alexanna brings up a very good point. What happens if the cable to the front panel is disconnected?
                          PlainBill
                          • alexanna
                            • Mar 2010
                            • 1346
                            #53
                            ^ That's kind of what I was thinking, identifying the on/off pin.
                            And then if needed with switch disconnected take the voltage on that pin low, and see if the monitor stays on.
                            • PlainBill
                              • Feb 2009
                              • 7034
                              But even that isn't necessary. LCD monitors usually remember their last state; the power button is just a momentary contact. If the cable to the front panel is disconnected and the monitor still is cycling on and off when you apply power, the front panel switches, pc board, led, etc are not responsible. If it comes on and stays on, or in never comes on, we know the problem is in that portion of the circuit - as you said, probably a stuck switch.
                              PlainBill
                              • docksteaderluke
                                • Jul 2011
                                • 39
                                #55
                                Still flashing on and off (LG Logo displayed on the screen for a second or two... then everything turns off) with the front button panel disconnected from the logic board.
                                Any idea where I can source a replacement logic board? I figure I may as well start looking now but can't seem to find anything via google/ebay...
                                Are the voltages coming from the inverter pretty much standard across the board? I have an old 17" Samsung that I might hook up to the LG PSU to see if the display keeps turning on or off. That way I'll know if it's the logic board or the backlight.
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  The key is the power light. With one exception, when the backlights go off the power led will stay on. The power LED is switched off and on by the processor on the signal card.
                                  The one exception is if there is a shorted driver in the inverter, and the short overloads the power supply, causing it to shut down.
                                  PlainBill
                                  • docksteaderluke
                                    • Jul 2011
                                    • 39
                                    #57
                                    k. So I hooked it up to the 17" LCD panel and the backlight turns on (all white) then off. So it must be the logic board for sure now. I don't think it's a short in the inverter since I swapped it for a new one and it still did the same thing.
                                    So any ideas on where to source a new logic board?
                                    • docksteaderluke
                                      • Jul 2011
                                      • 39
                                      #58
                                      Does anyone know if there is any way to test the MX25L1005MC flash IC on the logic board? I can't find a full blown logic board replacement but this IC seems to be an issue with some...
                                      • Rtech
                                        • Jul 2010
                                        • 1095
                                        #59
                                        I got one from Ebay UK at a huge £35,and that was the last one the Seller had, the others he did have were sold out !!!
                                        • PlainBill
                                          • Feb 2009
                                          • 7034
                                          I'm afraid you are SOL on that. Most GPUs bootstrap firmware from an external chip. That chip will usually be identified by marking it with paint. If the contents of the chip gets corrupted, you will get the symptoms you describe. And the MX25L1005MC dies have a blue dot on it.
                                          Someone had a similar problem; he was able to find a copy of the firmware, rig an adapter and reprogram the chip. This could best be described as a non-trivial task. There are a few companies supplying chips preloaded with firmware, however I have only seen this for chips that are in sockets.
                                          I've got a monitor on the shelf with the same problem. What irritates me is the corruption is avoidable. Certain parameters are stored in the firmware chip, rather than in the user eeprom. When the caps go bad a noise spike during a write cycle will corrupt the firmware.
                                          PlainBill
                                          • taslan
                                            Surface 7 Pro wont boot, shows Logo and immediately turns off
                                            by taslan
                                            as stated in the title, my surface 7 pro wont boot anymore.
                                            When i press the power button it shows the square windows logo for a second and immediately turtns off again.
                                            I dont even have a chance to get into bios or boot from usb.
                                            While trying to find help online it was suggested to look for help/repair here on badcaps and it might be a ME Region corruption in bios.
                                            I dont know what that is exactly, but i never tinkered with the bios or windows in terms of hacking/patching etc.
                                            Bought it directly from microsoft and used it now and then and only...
                                            01-16-2025, 01:25 AM
                                          • Super360
                                            Vizio E701i-A3 Vizio logo flashing then turns off
                                            by Super360
                                            Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                                            07-25-2024, 07:06 PM
                                          • USmechS
                                            Hisense 65H6570F Logo shows then turns off
                                            by USmechS
                                            Hello everybody,
                                            I had this Hisense TV since November 2019 (Bestbuy Blackfriday special). Couple of nights ago my dad turned it off normally. In the morning it does turn on, shows the Hisense logo, then the LED light flashes and it turns off. It remains in the same state.
                                            Things I have done:
                                            A. Plug it off and on.
                                            B. Plug it off, pushing the power button for up to 2 minutes, plug it in.
                                            C. Contacted the customer service, They sent me a firmware update, with the file name:
                                            upgrade_loader_no_tvcertificate.pkg
                                            The zip file has this...
                                            04-25-2022, 03:06 PM
                                          • ossroy
                                            Vizio M60-C3 powers on, perfect logo, turns off
                                            by ossroy
                                            Vizio M60-C3 powers on, perfect logo, turns off. If you don't touch anything it will repeat this process by itself until it is unplugged. Not the "button board" since I disconnected the cables to the main board and the problem persisted. So I'm fairly positive something is going on with the main board, but want to know if there is a fix for this other than replacing the expensive mainboard, which may eventually have the same problem. Also, heat sink was hot as hell when this all started. Unplugged for a few days and same thing happens.
                                            My kids are getting antsy waiting...
                                            08-03-2022, 08:11 PM
                                          • Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                            by Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                            03-15-2024, 09:37 AM
