LG W2234S Repair Help...
  • krisztian_andre
    • Jul 2014
    • 5
    Re: LG W2234S Repair Help...
    I flashed the 128kB file (had to desolder to program) amd the screen now turns on, but the edid is wrong (appears as unknown display to the computer), the menu buttons don't work just the power button. The first time when I turned it on it kept cycling the primary colors. After a soft reset it displays the LG logo and then the usual floating rectangle saying check signal cable, the time and "inl22w tco03". I think this is either an eeprom problem (maybe I need to erase it to be reset by the microcontroller) or it is the wrong firmware file. I have the w2234s-BN model I think there is an -SN version too.
    Originally posted by krisztian_andre
    I'm having a nice conversation with myself here, but here's a 128kB file I found: http://www.ebastlirna.cz/modules.php...nload&id=23916
    • max001
      • Sep 2014
      • 5
      • EU
      #82
      Hi all. I'm near mars... I havo no components.
      Just some resistors, few wires and a serial port connector.
      How I can rewrite the MX25L1005 with the pinout of serial port connector on the motherboard?
      Any help is appreciated
      • max001
        • Sep 2014
        • 5
        • EU
        #83
        Just to advice. I ordered 2pcs of MX25L1005 (1MB) programmed for W2234S.
        Still no one of those monitors will works, no blue led, no sign of life. It seems the IC are no programmed, because with another logic board (of my 3th W2234S) every panels work well.
        Ebay seller Monitor-09 said me that he can send the firmware via email, but I haven't any programmer, otherwise I'll tried to solving this problem myself.
        This way, has been loose of time and money, for my case.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          #84
          You should have some signs of life on the power supply even with no logic board.?
          • max001
            • Sep 2014
            • 5
            • EU
            #85
            With the working logic board, every panels work good with its own build-in power supply. So it's not a power supply issue. It's really the IC with the firmware corrupted.
            I was hope to solve problem with the programmed IC supplied by monitor-09, but no. May be monitor-09 sent me a non programmed IC, or maybe I damage something during unsoldering/soldering operations. I cheked carefully under lens but it seems all right, both two logic boards.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              #86
              ok what about getting one of these and the file from your ebay man.
              http://www.ebay.ca/itm/EN25T80-Progr.../171122644445?
              pm krisztian and ask if he got it sorted - maybe he will sell you his programmer if he still has it.
              save the long wait from china
              • retiredcaps
                • Apr 2010
                • 9271
                #87
                I repaired this monitor 2 years ago and bought my IC from monitor-09 which worked fine. I originally bought the IC from another seller and while their auction says it was programmed with firmware, it was blank when I received it.
                The monitor has sat in my basement unused for the last 2 years because of all the monitors I have fixed it has the worst color/contrast making it usable for me. Perhaps the firmware isn't 100% compatible, but no matter how much I tried changing the settings, I couldn't find one to make me happy and my standards are pretty low.
                In addition, when working with this monitor, note that the power supply does not discharge itself. You must discharge it before working on it.
                --- begin sig file ---
                --- end sig file ---
                • max001
                  • Sep 2014
                  • 5
                  • EU
                  #88
                  Buy a programmer, wait a month, re-unsolder, program the IC, re-solder and the risk of non-successful operation still rest... maybe its more convenient buy directly new or tested logic board from china, and when it come I'm sure it will work without problems, just connecting the cables.
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    #89
                    Ok, well whatever you decide please let us know how it went.
                    • max001
                      • Sep 2014
                      • 5
                      • EU
                      #90
                      Hello guys, I ordered 2 logic board time ago for 12usd and they work.
                      Just now I begin to use these 3 identical monitors with eyefinity as I had planning.
                      This model default colors tone seems a little bit "old", but with a manual setting it's possible set the tone as in the actual on market. Of course the cfl lamp can't perform the brillance like leds but however... I have a little problem with the 2 monitors I replaced the logic board. They don't go in stand-by when the PC shut-off, so I need to remember every time to push the on/off button. And this is not a good thing.
                      I see the firmware is 1.3.
                      Instead, the monitor never broken, with 1.4 firmware, will shut-off as normal.
                      Some suggestion to fix it?
                      • frank_b45
                        • Aug 2016
                        Hi , this will be my first post since I joined Bad Caps. So hello to everyone out there for starters.After reading many posts I've managed repair a lg 2334 monitor , and two samsung tvs. Thanks to all the people for there advice and experience, it was a great help. I still have 4 more tvs and counting to repair, so I will be reading a lot more posts, and may even ask a stupid question or two a long the line. Thanks again Frank.
                        • herved
                          • Oct 2015
                          • 21
                          • Belgium
                          #92
                          I have now reprogrammed that chip several times and it always gets corrupted again after a few hours of using the monitor.
                          I already replaced some of the caps on the PSU (but not all).
                          What would you recommend? What could be causing the flash chip to get corrupted?
                          Replace all caps on the PSU?
                          Could it be caused by the crystal on the logic board?
                          Could this be a software bug?
                          • taslan
                            Surface 7 Pro wont boot, shows Logo and immediately turns off
                            by taslan
                            as stated in the title, my surface 7 pro wont boot anymore.
                            When i press the power button it shows the square windows logo for a second and immediately turtns off again.
                            I dont even have a chance to get into bios or boot from usb.
                            While trying to find help online it was suggested to look for help/repair here on badcaps and it might be a ME Region corruption in bios.
                            I dont know what that is exactly, but i never tinkered with the bios or windows in terms of hacking/patching etc.
                            Bought it directly from microsoft and used it now and then and only...
                            01-16-2025, 01:25 AM
                          • Super360
                            Vizio E701i-A3 Vizio logo flashing then turns off
                            by Super360
                            Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                            07-25-2024, 07:06 PM
                          • Teban1306
                            [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                            by Teban1306
                            Hello everyone!
                            I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                            System Information:
                            • Model: Lenovo ThinkPad T14 Gen 1
                            • Machine Type: 20S1S4E600 (Intel i7 variant)
                            • Current BIOS: N2XET42W (1.33) - Latest version
                            • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                            What I'm trying to achieve:
                            Replace the default "LENOVO" boot logo with a custom image during POST.
                            🔧 What I've tried:
                            09-14-2025, 11:49 AM
                          • USmechS
                            Hisense 65H6570F Logo shows then turns off
                            by USmechS
                            Hello everybody,
                            I had this Hisense TV since November 2019 (Bestbuy Blackfriday special). Couple of nights ago my dad turned it off normally. In the morning it does turn on, shows the Hisense logo, then the LED light flashes and it turns off. It remains in the same state.
                            Things I have done:
                            A. Plug it off and on.
                            B. Plug it off, pushing the power button for up to 2 minutes, plug it in.
                            C. Contacted the customer service, They sent me a firmware update, with the file name:
                            upgrade_loader_no_tvcertificate.pkg
                            The zip file has this...
                            04-25-2022, 03:06 PM
                          • ossroy
                            Vizio M60-C3 powers on, perfect logo, turns off
                            by ossroy
                            Vizio M60-C3 powers on, perfect logo, turns off. If you don't touch anything it will repeat this process by itself until it is unplugged. Not the "button board" since I disconnected the cables to the main board and the problem persisted. So I'm fairly positive something is going on with the main board, but want to know if there is a fix for this other than replacing the expensive mainboard, which may eventually have the same problem. Also, heat sink was hot as hell when this all started. Unplugged for a few days and same thing happens.
                            My kids are getting antsy waiting...
                            08-03-2022, 08:11 PM
