PI-190DTLB 5v earthing out
  • sabre504
    • May 2010
    • 449
    • United Kingdom
    #41
    Re: PI-190DTLB 5v earthing out
    Have you checked Q201
    • SuperDuty
      • Mar 2011
      • 299
      • France
      #42
      Just checked, no problem there either.
      Once again, did some soldering, powered up the thing, it worked (no panel on), unplugged it several times and now it worked each time. Checked the voltages, I got 4.98V at the +5V and around 15V at the +14V.
      But I put it aside to plug the VGA cord to see if it was detected by my computer and the power wouldn't come back...again.
      • selldoor
        Slow Learner
        • 7870
        #43
        Hi - in an earlier post R 233 and R234 were mentioned and yo said you had replaced the
        resistors. Whilst you may gave soldered the new resistors to the pads I am wondering if the pads should be soldered together - as your picture is posted in line I cannot easily enlarge it enough to tell) It could be that as you move / heat the board the pads are touching then as it cools/moves it is not touching. Please check again and if they should be connected re solder them and if they shouldnt then make sure there is a gap.
        I am assuming the loose screw shown at the side of the board has been removed
        • SuperDuty
          • Mar 2011
          • 299
          • France
          #44
          I've just removed the two resistors and they're joined, so they're supposed to be soldered together. Resoldered them and no go.
          And yes, the loose screw is back where it's supposed to be
          Could it be a bad transformer ? AFAIK, those are pretty simple and there's not much that can go wrong with these parts.
          • selldoor
            Slow Learner
            • 7870
            #45
            I have read today a thread where the pson pin had become unsoldered from the
            board but connected from time to time. - Long shot (very) but worth a look?
            • SuperDuty
              • Mar 2011
              • 299
              • France
              #46
              Well I reapplied a bit of tin on the PS on pins and transformer pins, and it worked. I plugged it to my computer and could see that the backlighting is not working, but I could see the windows on the panel.
              Then I let it sit off and unplugged while I looked for another panel, and it wouldn't turn on...
              So I melted the solders at the transformers pins and it came back. And it seems to have done the trick, so far I've let it sit much longer than before and it turns on as it should.
              Now the other problem is the backlighting that doesn't work : i've tried with another 19" panel and several spare CCFLs I have and none would light up.
              Maybe it's the same problem as with the main transformer. I will melt the solder around the two smaller transformers.
              EDIT : didn't work again after letting it sit, melted the solder, and it's back on. WTH is that ! Did the same to the solder point where the transformer for the CCFL are...and it works fine now.
              So I'm guessing either the original solder was of extremely poor quality, or I don't know really. It's flickering pretty bad after about 30seconds, capacitors ?
              • selldoor
                Slow Learner
                • 7870
                #47
                Does the screen flash at all?
                EDIT ok see your edit. - Great
                1. Try and turn the brightness down see if that helps.
                2. test it with your other bulbs /panel to see if it is bulb/wiring related
                • sabre504
                  • May 2010
                  • 449
                  • United Kingdom
                  #48
                  Have you tested the two components ringed in yellow as you have some bad scorching on the upper face of the board
                  • SuperDuty
                    • Mar 2011
                    • 299
                    • France
                    #49
                    Yeah it seems to be working fine now, no dead pixels, no flickering, there's a gentle hissing sound on start up but it's slowly vanishing.
                    The brightness of the screen is a bit dull though, not sure if it's the screen itself or the power board. I'll try with another panel to see if it changes anything. And I'll let it sit too, hopefully the problems are gone for good now.
                    EDIT : I have tested them on the board (I haven't removed them) and the results were fine and identical for both. But I guess since the screen works now, all the components should be fine.
                    EDIT : doesn't work with the other panel at all, I guess they're not compatible. Put back the original one an it started just fine. It has some trouble starting up though, it takes about 30sec before the hissing and flickerings go...
                    • SuperDuty
                      • Mar 2011
                      • 299
                      • France
                      #50
                      To all the ones with the same power supply in their screen, if replacing the dead components doesn't work, just resolder all the transformers with new tin. It has done the trick for me. These seem to heat up a LOT (seeing how the PCB turned black in some spots), the original solder must have become porous or at least not fully conductive. Kinda weird.
                      EDIT : AHHH, spoke too fast, I let it sit for about 20minutes, and no power Heated the solder on the transfomer, and it's back alive. I'll remove it, clean the solder and put it back with brand new tin.
                      • throwaway327
                        by throwaway327
                        Model No: RC72LA
                        Serial No: SBNVKD001014459
                        06-18-2025, 05:52 PM
                      • panoss
                        Samsung LS19A100, slowed down, colors changed, lines not very crisp
                        by panoss
                        In the above mentioned monitor, I removed the plug a few times and this resulted no power.
                        I opened it, soldered the dc jack and worked again.
                        But since then colors have changed, too bright (or something like this) and lines, eg letter, are not very crisp as they used to be, they are vague, like faded out.
                        I checked voltages on the main board, they look ok (according to the service manual. It' attached at the bottom):
                        IC600 (D9329)
                        pin 1 (BST) 9.6V
                        pin 2 (VIN) 13.5V
                        pin 3 (SW(Switching output)) 4.8V
                        pin 7 (EN)
                        pin 8 (SS) 2.6V
                        IC601...
                        10-13-2024, 10:21 AM
                      • ivtec
                        Win 10 home edition changed to Win 10 pro help
                        by ivtec
                        Hi guys; i have installed win 10 Home Edition from a DVD iso and it changed to Win pro ,how i change it back to Home edition without reinstall again ?Thanks
                        06-21-2024, 08:43 AM
                      • Ferimonka
                        Dell Latitude 7420, 7320 voltage changed
                        by Ferimonka
                        Hi there,
                        I got 2 Dell laptops with a locked bios (dell management protection).
                        When I sent the dumps to this forum I got unlocked .bin files.
                        The issue I am getting the voltage on the bios chip pins has changed once I soldered the chip back (with the unlocked even original bios file) and doesn't turn on anymore.
                        Before I started to re-program the chip the voltage on the pins were 3.3V almost on each pin. Once I soldered the chip, voltage changed to 1.9V or 1.3V on few pins. No 3.3V anymore.
                        I appreciate any help to get me this...
                        07-18-2022, 02:11 AM
                      • link626
                        TCL 43s405 power board 81-PBE045-M02 (PLE100-2A) changed out the cheap caps
                        by link626
                        changed out the cheap HEC caps on my tv power board to a mix of nichicon chemicon and panasonic caps below.
                        now there's louder buzzing noise from the yellow thing in the upper left corner. (anyone know what that yellow thing does? is that the transformer?)
                        and the screen flickers in brightness. It's a light flicker, but noticeable.
                        the buzzing ebbs and flows, like cicadas buzzing.
                        in similar fashion, the brightness flickering ebbs and flows. the flicker might stop for a minute or two.
                        these are all low esr caps, and I'm wondering if that might...
                        08-08-2021, 11:11 AM
