Dell 3008wfp faulty power supply
  • gajones
    • 4
    My Dell 3008wfp screen shut off completely one day. I took it to an engineer who replaced some parts on the power supply, and it worked for a short time before it died again. He replaced some more parts, but the same thing happened again, twice. Unfortunately for me I had bought a refurb model which only had a 1 year warranty.
    The engineer tells me
    your power supply has a fault on the secondary side of the power supply. Diode D22 which is type V30120S (the rectifier diode for the 14 volt rail), is blowing after the monitor has been running for a day or so.
    I've had no luck finding a replacement power supply (I found a site called lcdrepair.us but they no longer have any), or asuitable repair kit (the ones I've found contain capacitors but not the diode). I'm hoping somebody may know where to pick one up, or can offer some insight on how to fix it.
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Dell 3008wfp faulty power supply
    would be odd for it to blow for no reason.
    pics would help..
    datasheet
    • retiredcaps
      • Apr 2010
      • 9271
      findchips.com
      http://www.findchips.com/avail?part=V30120S
      --- begin sig file ---
      --- end sig file ---
      • zen
        • 511
        hi my name is zen.just joined site.
        i am the engineer currently working on this psu.
        as gajones has posted my findings,i will add a bit more info.
        i have about 20 years experience working in the electronics repair industry.mainly tv and audio.
        i'm normally quite good with power supplies,but this one is difficult to work on as the diode mentioned only seems to blow after unit has been re-assembled and then after working for a few days.
        i even managed to source the exact same diode from china as opposed to an equivalent i had replaced with originally.
        i have replaced a few other components on the 14 volt rail which diode D22 is the rectifier of.
        have also checked the electrolytic caps on that rail.they all have good esr readings and are high quality 125 degree ones aswell.
        as i'm not that familiar with dell psu's,i guess i need advice from someone use to working on them.
        will try and post some photo's when i have a chance to strip monitor down again.
        a schematic of the psu may also be useful.
        thanks
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          I think the 120v reverse voltage rating of the diode is a bit tight. If he lives in an area with high mains and the transformer has high leakage inductance then the voltage at the diode could spike higher than that. I would advise a 200 volt replacement.
          A working TV? How boring!
          • multimeter
            • Jan 2011
            • 739
            • united kingdom
            i would try first by checking the resistors linked to the shottky diode,it seems to me that one is gone higher value,thus pushing more current to the shottky ,you will need the schematic,for resistor type and value,also check for any reverse voltage,this will cause the shottky to blow,as it seems this monitor stays ok for a day or so,then pops,suggesting a small voltage that is creeping up and biting the diode on the ass,also if all checks out ok,then consider a higher amp diode that maybe will take more current,as sounds as if it could be a design issue with that power board with current boardering on the amperage of the diode,you can go higher on the amps for the diode,just the same as you can step up the voltage for a cap(higher not lower dont forget!),also double check on the main fuse it should read 1 on a dmm,if higher this will sugest a short somewhere.
            fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
            please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              ^^ Off topic. Totally.
              The diode is 30A. The monitor draws 4A at 14v, if not lower. The high current rating is so that voltage drop can be kept low and they get away with a smaller heatsink. There are no resistors linked to the diode because it wouldn't make any sense, and the power supply only pushes as much current thru the diode as the controller tells it to. And if the controller tells it so it means the monitor needs that current.
              Your only pertinent observation is related to the diode reverse voltage. And that indeed could be the cause.
              • alexanna
                • Mar 2010
                • 1346
                An observation and a question.
                The monitor apparently ran a year without problems, and now after running and getting totally warm the diode fails. Is there a possibility it could be as simple as re-soldering a transformer?
                • zen
                  • 511
                  thanks for the input guys
                  will have another go at it.
                  • gajones
                    • 4
                    unfortunately it hasn't been possible to fix - it runs fine uncovered, but replace the casing and it heats up and blows again.
                    I've come to the conclusion that the only way to fix it will be to replace the whole power supply, but I just can't find anywhere that sells them. Any ideas where I could try?
                    • ezdy
                      • Jul 2011
                      Hi bro...i have the same problem with you ....btw i just done searching for the part...by the way, u could buy the part for psu 3008 wfp the link below
                      http://item.taobao.com/item.htm?id=6930940343
                      its from china i think..by the way becareful shopping..try find trusted middle men to handle the shopping for you since its chinese website
                      hope u can fix ur 3008 wfp...i waiting for mine technician to fix mine.
                      i did follow ur thread @ dell support page seems they are helpless! ..there is still hope update ur thread when ur 3008 already fixed...
                      • gajones
                        • 4
                        hi, thanks very much for the info - well done for finding the part, i've spent hours searching for it! Have you actually bought it from that website?
                        • Lumberjack777
                          • 464
                          I like your suggestion. I'm going to take a chance and not replace the Schottky Rectifier with the Vishay V30120S 120v reverse voltage. I'm going to try the STMicroelectronics Schottky Rectifier rated at 170v reverse voltage instead. http://search.digikey.com/scripts/Dk...5-ND&x=23&y=16
                          Hopefully this one won't burn out after a couple of days. I'll let you know how it goes. Thanks for the suggestion.
                          • Lumberjack777
                            • 464
                            Worked! And still running strong. The 170v STMicroelectronics part did the job.
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              Thanks for the report! We're always happy to hear success stories.
                              • mardon1975
                                • Jan 2012
                                My monitor as well just died the power supply is the issue, the problem is dell will not give them what they need to try and fix it. Any chance you would be ok if i share this information with them to try, and fix my issue. After this experience i am not sure i will buy from dell anymore.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  Originally posted by mardon1975
                                  Any chance you would ok if i share this information with them to try, and fix my issue.
                                  Anyone who finds this via search engine is welcome to the info. It is good etiquette to credit the person with the solution.
                                  • Jetset
                                    • Mar 2012
                                    • 10
                                    • U.K.
                                    Hi Guys. I'm new to this board having just found it, after having just had my Dell 3008 monitor fail 3 months outside it's 3 year warranty
                                    I'm pretty certain my PSU has the same problem described here, and I've already bought some much higher rated diodes (STPS40170CT) to fix it. No-one's posted an image showing the D22 diode location (it isn't marked on my board), so I'm posting an attached image of where MY faulty diode is located and wonder if someone could confirm that this is the infamous D22 on the 14V rail?
                                    I also thought it would help others to know where to look after they'd managed to open up the Dell monitor (now that was one hell of a difficult job. How on earth do Dell repair them - maybe they just scrap and replace in-warranty items?).
                                    If anyone can confirm I'm looking at the right device then it would help enormously before I start dismantling the heatsinks to get at the failed device (which isn't all that easy even for an experienced elec. eng.). I have visually confirmed that the faulty device marked in my photo is a 30120S.
                                    Thx.
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Is there a marking on the front side of the pcb for the red circled component?
                                      • Jetset
                                        • Mar 2012
                                        • 10
                                        • U.K.
                                        Ahhh...Yes, I can just about read the silk screen using a bench magnifier. The component is definitely D22!
                                        One other question if I may: Do you know if this diode blowing is likely go have damaged anything further down the 14V line (I can't see any fuse or fusible link that would normally be present in a SMPS to protect against such failure, and I'm using the old mains plug from the UPS to power the new 3011, so nothing has blown externally)?
                                        Thanks for your response.
                                        Colin
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • Borse2008
                                          Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                          by Borse2008
                                          Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                          I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                          • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                          • There’s
                                          07-15-2025, 04:55 AM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • F R 2568
                                          Dell Latitude 5420 does not start (no post) need help to find the reason why
                                          by F R 2568
                                          Hello all,
                                          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                          If the laptop is only connected to the AC adapter (battery removed):
                                          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                          The power/battery...
                                          01-08-2025, 05:45 AM
