VX 724 black screen green light flashing
  • Nocta
    • Mar 2012
    • 117
    • Argentina
    #101
    Re: VX 724 black screen green light flashing
    DMM 2k Ohm
    U1:
    SMD 331: .325
    SMD 308: .146
    U3:
    SMD 308: .197
    SMD 308: .146
    I can't read the numbers of the resistors but that's what I think it's written. I used a magnifying glass.
    Thanks again and sorry for the delay. I've been a bit busy.
    • Nocta
      • Mar 2012
      • 117
      • Argentina
      #102
      I won't give up with this monitor.
      I've been looking closely at the diagram and you were right, some caps were 10uFx16. Exactly 8 caps (of 12). LOL.
      Image is now even worse than it was before. Now I have some red and green vertical lines on the display. I checked again the VR and output voltage is 4v (which should be 3.3).
      Should I order a couple of AMS1117-3.3 instead of AS1117-3.3 (the ones I used to replace the original VRs)?
      Thanks.
      • Nocta
        • Mar 2012
        • 117
        • Argentina
        #103
        Sorry for bumping this thread but I just wanted to update it.
        I fixed it. It was the ribbon cable just like you mentioned once.
        Best part is that I learnt my lesson. I was given a Viewsonic display with same symptoms (red lines, bad colour) and now it's fixed too
        Thanks for your help and patience!
        • Jorge.ar
          • Jul 2014
          • 6
          • Argentina
          #104
          Hello!! Its been 4 years since last post in this thread...
          Yesterday my VX724 died. Started with the power led blinking, and then died. After disassembling I noticed that the main cap had some fluid leakage.. changed the main cap, the 220uF caps and the 330uF caps. The others seems OK.
          The main cap is charged but there is no 12v at the output. I disconnected the PSU and disconnected the inverter (opened the jumper 9 that connects +v from 220 caps to +v of 330uf cap)
          I checked VIN of SG6841 and it's ok, but there is no PWM output and no signal in the gate of the mosfet (checked with oscilloscope, GND = negative of the main cap)
          I don't know what else to check.. I will desolder the mosfet and check it.
          Thanks!!!
            What do you have on VDD pin, it can be that the startup cap on the VDD pin is bad.
            From spec sheet, the Vdd must reach 16VDC for it to atsrt up:
            The turn-on and turn-off threshold of SG6841 are
            fixed internally at 16V/10V. During start-up, the hold-up
            capacitor must be charged to 16V through the start-up
            resistor so that SG6841 will be enabled. The hold-up
            capacitor will continue to supply VDD before the energy
            can be delivered from auxiliary winding of the main
            transformer. VDD must not drop below 10V during this
            start-up process. This UVLO hysteresis window insures
            that hold-up capacitor is adequate to supply VDD during
            start-up.
              • 31094
              if sg6841 has a small startup cap then replace it.
                • 31094
                lol - simultanious post
                • Jorge.ar
                  • Jul 2014
                  • 6
                  • Argentina
                  #108
                  Thanks to both of you
                  Bad news.. I replaced the mosfet (CER 541) with a IRF 540 and somethin exploded...
                  I remember that the SG6841 VIN pin was something like 3.2V.... I will try to fix the board and try again.
                  • Jorge.ar
                    • Jul 2014
                    • 6
                    • Argentina
                    #109
                    here a pic of the damaged part.. I think is R628
                      IRF540 has Vds of 100V, your power supply if it is 230Vac, it will be exposed to about 330VDC. You may have also damaged the SMPS IC due to blown Gate drive network parts as shown in your picture.
                      • Jorge.ar
                        • Jul 2014
                        • 6
                        • Argentina
                        #111
                        Damn,.. so CET541 (original mosfet) is not IRF 541...
                        • Jorge.ar
                          • Jul 2014
                          • 6
                          • Argentina
                          #112
                          start-up.
                          I didn't find any capacitor in the startup circuit.. From +V of the main capacitor, there is four 390K resistors in series then to VIN.. and no cap to gnd.
                          Maybe the SMPS IC was damaged before the blown..
                            the cap will be on the VDD pin not at Vin pin. See the spec sheet of the IC and how it works, But at this point the IC is probably damaged by now.
                            • selldoor
                              Slow Learner
                              • Dec 2010
                              • 7870
                              #114
                              Id suggest R327 as a description R325 doesnt look too happy either
                              By the way where is this part CET541 - doesnt get a mention in the rest of the thread and doesnt google??
                              • Jorge.ar
                                • Jul 2014
                                • 6
                                • Argentina
                                #115
                                the cap will be on the VDD pin not at Vin pin. See the spec sheet of the IC and how it works, But at this pint the IC is probably damaged by now.
                                OK, found it, and also replaced before killing the SMPS ic.
                                • HTR-Informatique
                                  Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                                  by HTR-Informatique
                                  YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                                  I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                                  On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                                  I also changed the screen because the PC fell and the screen was broken.
                                  I changed the battery with a new and original battery.
                                  I also had corrosion/oxidation on the...
                                  02-09-2025, 06:51 AM
                                • jimjoe123
                                  LCD TV Green/Pink screen problem
                                  by jimjoe123
                                  I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                  Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                  Then each time...
                                  02-23-2020, 01:29 AM
                                • kokos
                                  LG 55EG910v (Green Nosie Screen) BURNT on NOT ?
                                  by kokos
                                  Hi ! to all fellows out there!
                                  I have an LG 55inch 55RG910V-ZB Curved TV. With the following problem: When I turn it ON with Remote I get a Green noise Screen (attached foto).
                                  I have tried reseating all ribons, Checked PSU 24V,12V,3v ,etc voltages.
                                  The TV opens on the first Green noise screen and it freezes there -no respone of menu keys ,etc -only on/off via Remote. (I also noticed carefully that except from green noise screen there is a ghost image at bottom and left vertical side)
                                  I tried connected the lan and I can seee TV via local lan (as a device I...
                                  02-26-2024, 10:48 AM
                                • MOSSEP
                                  Monitor Audio RSW12 - Green light, but no sound
                                  by MOSSEP
                                  Hi
                                  Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                  Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                  The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                  I have already tried replacing all of the...
                                  01-26-2025, 08:33 AM
                                • MOSSEP
                                  Monitor Audio RSW12 - Green light but no audio
                                  by MOSSEP
                                  Hi
                                  01-26-2025, 08:18 AM
