2 sec to off, 22" LG Flatron, W2252QT
  • Kwolff
    • Oct 2010
    • 5
    Hi guys,
    First post, and first time trying to fix one of these.
    Last night, my screen went dead during a movie i was watching, doing the whole on for 2 seconds, then off for several minutes, and after searching around the internet, i came upon this website.
    Being at least a little knowledgeable, and always wanting to learn new things, i took it upon myself to start pulling this guy apart to take a look at the board.
    The first thing i noticed is the burn marks on the Q305 Transistor, and checking the ohm value, it came up as 126 and 72. Shouldn't they be the same, or depending on what type they are, will the NPN junction show two different values?
    Checking the capacitors, they all look like they are in good shape, and all built by reputable companies, Rubycon and Nichicon. No identifiable expansion or leaking, and no signs of heat or electrolyte.
    When I checked the high voltage transformer, there was a huge difference between the two secondaries, with one being 1798 ohms, and the other being 971 ohms. Is this a clear indication that the transformer is cooked?
    I checked the other transistors on the board, and none of them showed a short, and the ohmic value seems consistent, so i don't think there is an issue there. The diodes seem OK, except for one, D105, which shows ohms both ways, but may be due to the resistor in parallel to it.. R113?
    Hope this is a good start. Any more ideas before i pull the transformer and get a new one?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: 2 sec to off, 22" LG Flatron, W2252QT
    If the diode is in parallel with the resistor it's normal to have a value both ways. But do lift one side of the diode up to make double sure.
    As for the transistor, please mention the exact way that you checked it. A transistor shouldn't show anything on the ohms scale (except for certain Darlington ones). Test it using the diode scale. If it shows values both ways on any two legs, and there are no resistors in parallel, the transistor is shot. Do try replacing it before doing anything to the transformer.
    A working TV? How boring!
    • Kwolff
      • Oct 2010
      • 5
      Forgot to post pictures.. lol
      • retiredcaps
        • Apr 2010
        • 9271
        I beleive it should be within 3% of each other. You may be able to find a replacement at
        http://lcdparts.net/T.aspx
        If you find the correct replacement, it will show the "correct" ohm value for the secondaries.
        Yes, the other components around D105 could be affecting the readings.
        --- begin sig file ---
        --- end sig file ---
        • retiredcaps
          • Apr 2010
          • 9271
          Which, at the moment, i can't figure out how to re-size them to a smaller file size. Have to go out for the evening, any help?
          I believe this site allows 2000x2000 pics with up to 1.7MB per pic.
          I use
          http://www.lview.com/download.htm
          to resize. It is free.
          • Wrog
            • Oct 2009
            • 472
            Use Microsoft Office Picture Manager (if you have Office 2003) or download Paint.NET (it's free) and use the resize function.
            • Kwolff
              • Oct 2010
              • 5
              Done, thanks for quick reply, ill check everything when i get home later.
              • jetadm123
                • 2169
                Hi guys,
                From the looks of it, Q305 and Q308 are possibly mosfets that are probably used to generate the AC sine wave voltage required by the inverter transformer to generate the high voltage required by the CCFL tubes. They DO run hot, hence, the discoloration. However, it's the way you checked Q305, can you describe how you placed the probes when you did the testing? The 2 values you listed are meaningless unless you tell us how you placed the probes. There are 3 leads on Q305, right? Q308 also needs to be tested, since it works in conjunction with Q305. The same logic also applies when you test the transformer secondaries.
                • Kwolff
                  • Oct 2010
                  • 5
                  Th3_uN1Qu3 = I went back, and I had not checked the transistors with the diode check, something I should have picked up on. After diode checking them all, they all measured out fine. I did check the diodes with the diode setting though. The high voltage transformer I checked on a 2000 ohm scale, from EL26 to 1 and getting a reading of 1798 ohms, and from EL27 to 4 with a reading of 971 ohms.
                  Looking into the transformer manufacture, they either don't carry it anymore, or don't list the specs on their website, and the only one for sale is on E-Bay. Any place i can look up the specifications of the high voltage transformer?
                  • Toasty
                    • Jul 2007
                    • 4171
                    A bad or failing tube will cause this too. Will cause the over current protection (OCP) to kick in. How old is the set? Have you opened the panel to inspect the tubes to see if they look burnt? As in regular size fluorescent tubes, if the ends are darkened, they are likely bad.
                    veritas odium parit
                    • Kwolff
                      • Oct 2010
                      • 5
                      The panel is only 2 years old, but has some pretty hard usage, since I game a lot. The ends of the bulbs do look burnt, just like a regular compact florescent, and might be the problem. I'll replace them and see what happens.
                      When I first tried testing the CCFL's, I plugged them into the power circuit, but didn't hook up any of the image circuits. Since the CCFL's didn't turn on at all, does this mean that you need a valid input for them to turn on? Or even flicker? To me, if you have your power circuit cycling your tubes, they should try turning on regardless if your hooked up to a computer tower or not. Must be doing something wrong.
                      • Toasty
                        • Jul 2007
                        • 4171
                        How burnt? A little bit is normal. A blackened 1/4" end is not. Pic?
                        Can you connect the whole thing together with the panel opened and see if one tube doesn't fire as well, or fires TOO well? Check the solder connections to them as well.
                        Please show what your mean by "burn marks on Q305". Do you mean on the transistor package surface or discoloration of the board it's mounted to, or...?
                        The fact that the unit works for a few seconds and shuts down is what is pointing me towards an over-current (or voltage) condition on the inverter. Can you swap connections to the tubes? If so, does anything change?
                        It very well could be the transformer. Without another unit for comparison it would be impossible to verify that it is good/bad/weak. Check to see if you get any resistance readings from one secondary to the other, and any from secondary to primary. You will have to pull the transformer to get the readings. Do you have a ring tester or can you perform such test? Oscilloscope?
                        Yes, there is a signal that comes from the video board to turn on the inverter. It actually goes from the inverter to the video and back. When you press the on button, the video board sends a signal to the inverter. I think it's typically a 5v line. One of them is also a lower volt line that controls the brightness.
                        Toast
                        veritas odium parit
                        • 901THECAT
                          • Oct 2011
                          • 7
                          I have this exact same model(lg w2252qt) and I disassembled it and got to the power supply board and noticed it had 4 blown caps
                          So I could get the right specs off of them I removed all 4 at 1 time not taking in account the order I took them out
                          There is 2 1000uf 16 volt and 2 470uf 35 volt and I was wondering if it matters the order I solder them back onto the board
                          I know that the - and the + have to be correct but what about the position of the 2 different types of caps
                          • PlainBill
                            • Feb 2009
                            • 7034
                            They have to go into the proper positions. The 16 volt caps are for the 5V supply, the 35 V caps for the 12 volt supply.
                            Attach a sharp, well lit picture of the bottom side of the supply; it should be possible to determine which is which. Do not post inline; use 'Manage Attachments' - below the text entry area.
                            PlainBill
                            • Rtech
                              • Jul 2010
                              • 1095
                              Sometimes on Boards, circles are shown on the top where the caps go,and they usually vary in size dependant on the Cap value...ie 1000Uf will have a larger circumference then the 470uF.......but in your case due to the Cap Voltages being so different 16v and 35v, it may not apply !!!!
                              • 901THECAT
                                • Oct 2011
                                • 7
                                I got a really great closeup of the ones I;m going to replace but I'm a newbee and don't know how to do it
                                I read the tutorial but I don't have anything saying manage attachments
                                • Rtech
                                  • Jul 2010
                                  • 1095
                                  Click the 'Go Advanced' below, and then click Manage Attachments.
                                  • 901THECAT
                                    • Oct 2011
                                    • 7
                                    There is nothing listed as 'manage attachments'
                                    Is it because I never had an original post of my own and only replied to other members post?
                                    Here are my choices when I hit 'go advanced'
                                    Miscellaneous Options
                                    Automatically parse links in text
                                    Disable smilies in text
                                    Attach Files
                                    Valid file extensions: bmp doc gif jpe jpeg jpg pdf png psd rar txt xls zip
                                    Thread Subscription
                                    Notification Type:
                                    Rate Thread
                                    If you like, you can add a score for this thread.
                                    It won't let me click on any icons above the letter head either
                                    i
                                    • alexanna
                                      • Mar 2010
                                      • 1346
                                      see if this helps.
                                      YOU will need to resize your photos to under 2000x2000 Pix. and click on manage attatchments
                                      • 901THECAT
                                        • Oct 2011
                                        • 7
                                        I finally figured it out
                                        the ones circled are the ones I need to replace
                                        Two of them are 1000uf 16 volt and the other 2 are 47OUF 35 VOLT
                                        Is there anyway to know which go where by the numbers on the board?
                                        • learnmore
                                          Help choosing replacement transformer for Levoit 600S SMPS
                                          by learnmore
                                          Hello Community,
                                          I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                          Peace
                                          LM...
                                          11-04-2025, 09:35 AM
                                        • narf
                                          Epson EB-U42 projector / Caps with 0.7 ohms ?!
                                          by narf
                                          hi all,
                                          first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                                          i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                                          what i've found so far:
                                          - the PSU does its job and supplies 12V to the mainboard via the connector.
                                          - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                                          - not far away, there's the first cap with a resistance of 0.7 ohms....
                                          07-02-2024, 03:53 PM
                                        • mikey5791
                                          Is it possible for transformer substitution?
                                          by mikey5791
                                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                          My questions are
                                          1. How do i test to see if the transformer is in good working condition?
                                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                          Hope you guys understand what i was asking. My intention is...
                                          11-03-2022, 02:11 AM
                                        • ohren
                                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                          by ohren
                                          Hello!
                                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                          Measured voltages with no load:
                                          After rectifier diodes
                                          12V: 6.17 V
                                          5V: 5.67 V
                                          Secondary transformer pins AC measurement (really don't know if this says anything)
                                          12V: 2-2.5 V
                                          5V: 1.04 V
                                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                          03-18-2023, 10:33 AM
                                        • dennis_elx33
                                          3PHASE STEP-DOWN Transformer in Check
                                          by dennis_elx33
                                          Hello All,
                                          i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                          Problem statement: Power tripped Off
                                          Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                          Action Done:
                                          1) Replaced the faulty parts with good spare.
                                          2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                          12-02-2024, 06:52 AM
